Question about LG CHOCOLATE VX8500 Cellular Phone
Downloadin music to the phone
But i get ''unknown error 3'' what do i need to do to fix the problem?
  • estevens003 Dec 22, 2008
    I have the exact same error when trying to trnsfr music from my rhapsody subscription. I chatted online with rhapsody for over an hour, and spent another 1/2 with verizon rep to find out that I need to replace the phone. I was able to use my WFG to get another new phone.
Fuckin verizon pieces of **** cannot release a simple break free ******* music player, how hard is it to make some software that doesnt ******* break? its not hard. TAKE SOME ******* REPONSIBILITY FOR YOUR PRODUCTS VERIZON
Posted on Nov 04, 2008
I Have error code E000007 - 001 on Canon C9060 pro
Fixing belt full displacement error (Displacement
direction is unknown.)
Full displacement of the fixing belt was detected, but the
displacement direction (front, rear) was unknown.
1. Forgot to clear the counter at the fixing belt
replacement -> clear the counter
2. Check physical relationship between the fixing belt
position sensor 1, 2 (PS71, 72) and the sensor flag
A. In case that both sensors are blocked from light
A-1. Faulty fixing belt unit -> replace the fixing belt
unit
A-2. Faulty fixing belt displacement control drive ->
replace the displacement control drive assembly
B. In case that both sensors are not blocked from light
B-1. The connector on the fixing belt position
sensor 1, 2 (PS71, 72) is physically removed,
or the cable is disconnected -> connect the
connector, or replace the harness
B-2. Faulty fixing belt position sensor 1, 2 ->
replace the sensor
B-3. Faulty fixing belt unit -> replace the fixing belt
unit
B-4. Faulty fixing feed driver PCB -> replace teh
B-5. Connection error of drawer connector (J8023)
-> clean or replace drawer connector
B-6. Short-circuit or open-circuit of harness
between fixing feed driver and DC controller
PCB -> replace harness
Jan 02, 2018 | Canon Office Equipment & Supplies
Unknown error
Consider the following scenario:
1. You install an antivirus scanner for Microsoft SharePoint Server 2013 for scanning documents.
2. The antivirus scanner is unavailable for some reason, or it times out during a scan.
3. Your document is corrupted.
As a temporary workaround, if you need to access to infected file immediately, the SharePoint administrator can enable the Allow users to download infected documents option in the Central Administration portal.
Also you could try to open the file with the help of Open Office or recover Word file here: https://www.docxrepairtoolbox.com/
Oct 30, 2017 | The Computers & Internet
My playstation 3 won't let me sign in...(error code 80710A06
Usually, when PSN server is down, it makes this type of error to occur. I believe they are working on the servers.
There is no easy fix to this, you just have to wait for an unknown amount of time till the network server comes back again.
You can reset your network and try again. Or If you have a friend that uses PS, check if that of your friend has this same error.
Regards...
Apr 21, 2011 | Activision Video Game Consoles & Games
Error code for sony 3 807
"Hey, here is a list and a reason of some of the error codes you may encounter whilst connecting your PS3 online, also the required ports need to be opened in order to play online.
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation 3 Error Code List
0710102 - DNS Error; No DSN server available.
8001050B - Will not play demo hard drive games, when blue-ray disc is inserted - Cause unknown
80010510 - Will not play hard drive games - Cause unknown
8002b241 - DVI has no audio.
80028EA5 - Unknown
80029023 - Exchanging Key Information exchange has timed out
80029024 - The attempt to obtain an IP address has timed out
80029564 - Downloaded Game will not install - Cause unknown
8002F997 - Can not update XMB firmware
8003051E - Game will not Save
80031150 - System Settings Fail to Save - Possible Blue Screen "Setting information is corrupted.Press the x button to repair and restore default"
80130203 - PS3 connects to internet but not to network - Typically means that the required ports are not open to connect to store but PS3 can connect to internet.
80710092 - "An error has occured. you've been signed out from the ps network" - (connection dropped?)
80710102 - PS3 Cannot connect to the router with current IP information - Try rebooting your router
80710541 - The connection to the server timed out.
80710B23 - PS3 Network is Down or PS3 Network is too busy to respond"
http://community.us.playstation.com/thread/2996553?start=0&tstart=0
Apr 17, 2011 | Sony Playstation 3 (PS3) Console
Can I fix a C00D11CD: Unknown error for free ?
This problem has to do with codecs
(compression/decompression schemes) needed by Windows Media Player in
order to play back specific file formats. Try DL VLC PLayer see if that helps, plays just about everything.
Mar 16, 2010 | Microsoft Windows XP Home Edition
JVM Error 545 - Blackberry Pearl 8110
to correct this issue try this method
You need to reflash the OS on the phone you should take the battery out first then connect it via the usb cable to the laptop/pc you are using then open the blackberry desktop manager,click on the apploader, then install the OS.
pls not that when u click on the apploader the pin should be PIN:UNKNOWN you make need to do this like 4x before the pc sees the pin:unknown but it will work once it see the pin:unknown you can re-insert the battery and continue with reflashing the phone
Aug 23, 2009 | AT&T Blackberry Curve 8300 Smartphone
Transport error (#12031) while retrieving data from endpoint `/aj
This type of errors are errors from the server side. Actually AJAX fails to load correctly sometime so you ll get errors lik these. Some solutions are: 1.Restart the browser 2.Try using different browser 3.if it is not fixed let it happen. It ll get fixed automatically.
rate this!!
Aug 09, 2009 | Facebook Social Network
Please help! My Dell Inspiron Mini will not start up!!
There is a hardware problem with the laptop causing it not to boot up, if you have only had this laptop for 3 weeks then i recommend you take advantage of the manufacturers warranty and sent it in for them to deal with as a hardware failure within 3 weeks is quite rare.
Regards
Jun 29, 2009 | Dell Inspiron 1000 Notebook
Error 2 (net::ERR_FAILED): Unknown error.
I had the same problem. Works fine by running Chrome with this switch
chrome -winhttp-proxy-resolver
Nov 23, 2008 | Google Chrome
LG CHOCOLATE VX8500 Cellular Phone Logo
62 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
