Question about Dryers
After starting my GE gas dryer , the burner fires and everything seems fine . The burner stays on for a few minutes and shuts off like it's supposed to . After a few minutes , the glow element turns on to fire the burner again but the burner doesn't ignite and the glow element just shuts off again . This goes on the entire drying cycle . This model has 2 coils on the gas valve and don't understand why . I'm thinking my problem is in one of the coils . Any help would be greatly appreciated .
    President:
  • 1,714 Answers
Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Posted on Aug 01, 2009
Dryer heat stays on for a few seconds and then
the clicking noise is the gas valve opening,but it isn't firing due to either a bad gas valve boost and secondary coil,a bad thermal fuse,or a bad ignitor bar that glows white hot to ignite the gas,or the radiant senser is weak or bad on the burner tube body
May 24, 2010 | Dryers
Maytag Gas Dryer, heats for a few minutes, then flame goes out
Service Manual for Dryer similar to yours will cover disassembly and troubleshooting:
MDG5500
It's likely one of the coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. The number for the coil kit, which will replace ALL the coils, for your machine is 12001349
Service on gas appliances should be undertaken by professionals only due to the danger of gas leakage which can cause fires, explosion or death by asphyxiation.
Sep 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
I have a Fisher & Paykel DG08 gas dryer that will get hot and shut down after 5 minutes. It will not start if you try hitting the start button right away, but will if you wait a few minutes. It did...
The thermal overload is bad and will need to be replaced,This is there to prvent overheating and when it fails and overheating happens,a secondary overload kicks in to prevent a fire.
Jul 29, 2009 | Dryers
GE Gas Dryer Model #dbvh512gfoww heat problems
Hi, It sounds like the coils on top the gas valve are bad. If the ignitor glows but shuts off before a flame, the coils need changed.
I hope this helps. If I can assist you further, please let me know.
Thanks
Vic
May 24, 2009 | GE 7.0 Cu. Ft. Super Capacity Gas Dryer -...
Dryer problem
HI thanks for your question. the problem is with the 2 coils on the gas valve. replace the coils. thanks
Oct 12, 2008 | Whirlpool Dryers
Dryer heat shuts off after a few minutes.
replace the 2 black solenoids on the gas valve ..after heat up they sometimes will go bad and burner will not reignite even though the ignitor glows
Sep 23, 2008 | Dryers
Gas dryer
be sure burner is firing off every time it is supposed to if ignitor glows then shuts off without burner firing replace the coils on burner (2 black round things) if burner ok remove rear vent hose and try load without connected if works ok suspect flattened hose behind dryer or line to outside restricted
Jul 16, 2008 | Whirlpool LGR5636PQ Gas Dryer
Gas dryer fires up once and that's it
suspect coils on burner once burner fires and heats up area coil may fail on next firing 2 coils are present.. whirpool sends both in kit
Apr 26, 2008 | Whirlpool GGX9868J Gas Dryer
Dryers Logo
176 people viewed this question
Top Dryers Experts
