Question about La Pavoni Professional Black Base
La Pavoni high pressure also, but all of a sudden
The pressure on my Professional is also running high, like 1.4, but the difference is my pressure suddenly changed in the last few weeks. It used to hover around 0.9 since I got it a couple of years ago, but suddenly changed. I'm guessing the pressurestat is going bad? Any thoughts? Thanks.
  • haziqs Aug 01, 2009
    I don't understand what you are saying. How do I check the pressurestat without the gauge?
  • 80 Answers
Check pipe for pressurestat and pressurestat,maybe just gauge is not corect
Posted on Aug 01, 2009
La pavoni
Remove the bottom panel and check the thermostats and element.
Jul 06, 2010 | La Pavoni "PROFESSIONAL Chrome" 16Cup
La Pavoni pressure switch
Hi there, i am Mr La Pavoni based in Glasgow, Scotland and i will be able to help you. If you know the parts you require then i think you would be best to replace them as if it keeps blowing fuses then it may cause more damage than you would like. If you go to www.theespressoshop.co.uk you can buy every individual part for the lever models online and they send very quickly too. If you need further assistance please don't hesitate to get in touch with me at domesticespresso@live.com
All the best
Mr Pavoni
May 14, 2010 | La Pavoni "PROFESSIONAL Chrome" 16Cup
Unregulated pressure then safety valve releases pouring out steam
It seems to me that your pressure stat which is inside the base of your machine needs replacing. I would try to give it a good descale and if this doesn't do the trick then a new pressure stat is what you need. Prob around £20 if you buy it and do it yourself. www.theespressoshop.co.uk and just click on the little la pavoni machine for full parts list.
All the best
LaPavoniBoy
Apr 13, 2009 | La Pavoni PC-16 Espresso Machine
Adding pressure gauge to Pavoni Europiccola
  1. in the boiler water is heated and presured up to 1.5 bar
  2. when water gets in lever and non return valve closes becouse you press the lever down, your energy is used to get high pressure, it should be frpm 7 up to 9 bar.
  3. SOLUTION==if you search way for modifying, you must consider that you must pump directly to group, not to boiler. in this case water will be cold (becouse comes from pump). you will need boiler in boiler to heat the water wich comes from pump before it gets to group. this is bit more complicated than you thought may bee but it is only solution.
Feb 20, 2009 | La Pavoni Europiccola EPC-8 Espresso...
La Pavoni Professional. The machine never stops heating.
  1. check the diaphragm of presurestat, it might be to old and non sensitive, measure the cirquit at presurestat. does he open the cirquit when it is at 1.5 bar pressure(you can test it with air, no need to be built in machine)
  2. if presurestat works properly than check the heating element, he can take phase directly and heat in conection with grownd if it is broken, than you cant stop it he heats to infinitive. in this case you replace the heating element.
as i said solution is either pressurestat or heating element.
Nov 30, 2008 | La Pavoni "PROFESSIONAL Chrome" 16Cup
La Pavoni Professional, Chrome, 16 cup capacity Europiccola
You have to take a screwdriver and try to bend up the platic, be careful so you not break it.
Aug 20, 2008 | La Pavoni "PROFESSIONAL Chrome" 16Cup
La pavoni professional
Make sure your filter is clean.
Jul 21, 2008 | La Pavoni PC-16 Espresso Machine
No pressure
I have the same problem are awaiting reply from la Pavoni direct...I suspect there is a fualt with the pressure gauge as it is steaming up too!!
Jun 10, 2007 | La Pavoni PC-16 Espresso Machine
Coffee Makers & Espresso Machines Logo
144 people viewed this question
Top La Pavoni Coffee Makers & Espresso Machines Experts
billconfused
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
