Question about Canon CLC-700 Copier
Error message "wire cleaner needs to be changed" what is that?now prints all black.
  • Canon Master
  • 1,297 Answers
If prints all black,yuor problem in the optic section.Please check the exposure lamp,termofuse.If your problem to be charge or transfer/separator corona wire the copy is blank.If posible OPC drum cleaning blade damage or used toner rotative mehanism blocated.
Posted on Aug 01, 2009
I cant print it says I'm out of black link and I just replaced it and it's flashing E 1 6
From http://www.refreshcartridges.co.uk/igloo/clearing-canon-pixma-error-message-e13-e16/
Locate the STOP/RESET/RESUME button on your printer which is represented by a triangle within a circle on the body of your printer and is usually in red, white or black as pictured below. With the reset button located hold it down for at least five seconds and then release it.
Aug 02, 2015 | Canon PIXMA Office Equipment & Supplies
Error message "to print in color, install the following cartridges:" continually comes up after installing new cartridge.
on ours the cartridges click twice to be fully seated..there are 4 cartridges in this one.. if one is not all the way down, it will error..in extreme cases if all the cartridges are in place..unplug the unit and reboot it..
Jan 19, 2014 | HP Photosmart C6180 All-In-One InkJet...
Error message that color cartridge has low ink, so printer won't print. How do I override this? This message occurs when only one color is low and requires replacing the entire cartridge.
No way 2 override the message. Printer works on a combination of both black and color ink to print those perfect pictures and documents. If it is showing color ink needs replacement,you ve 2 change it in order to print even in black and white.
Jan 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Canon Pixma won't print
Sounds like you need a new printhead.
QY6-0054-000. around $40.00
Jul 03, 2009 | Canon PIXMA iP2000 InkJet Printer
Hp 6150 won't print clearly --new cartridges are in
Clean the print head if you suspect that the nozzles might be clogged. Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
Hope this initial info/idea helps.
May 01, 2009 | HP Photosmart C6180 All-In-One InkJet...
Have changed Ink Black and Colour... Stil getting error Message.
Make sure the tape covering the hole on the bottom of the black cartridge is removed. and then go into the printers folder and right click on your printer icon and go into the properties of that printer and there should be something in there to tell it that you changed cartridges and you can also print a test page as well.
Feb 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Printing error message: cartridge problem.tri-color.I wasn't even
hi,
its becoz even if ur print contains only black text in it, while printer printing in black it needs a cyan or yellow ink to give very clear print out. work around for this issue, go to the printer icon and right click and go printing preferances and change the option to print only in blak or print only in gray scale. it should resolve ur issue............
Regards,  raj_p5983
Jan 21, 2009 | HP OfficeJet J4580 All-In-One Laser...
Supply Memory Error
It sounds like you are having two diffrent problems. I don't think they are associated with each other.
First, the memory supply error. The cartridges on this machine have a chip. The chip could very well be faulty causing this supply error message. Change the black cartridge and see if the message clears. if it dosen't then the antena that reads that chip needs to be replaced. I suspect the cartridge is the problem.
Second, the paper jams. This can be caused by a worn p/u roller as you mentioned. Sounds like the jam happens first then the error, based on your description.
The black thing you refer to on the door is called the "transfer belt assembly".
Aug 21, 2008 | HP Color LaserJet 2600n Printer
Center of page is not printing black
I changed out our black photoconductor unit #165 and it solved the problem. Even though the error message did not say that the photoconductor needed changed out, it had been eight months since the last replacement. I hope this helps!
Apr 03, 2008 | Ricoh Aficio CL3500N Laser Printer
Printing black shaded on complete page
Problem is usually a dirty charge corona wire. There is a cleaner on the drum unit, slide this across and back 2 or 3 times. If not, then the corona wire itself is missing or broken, change drum.
Feb 19, 2008 | Brother IntelliFax-2820 Laser Fax
Canon CLC-700 Copier Logo
76 people viewed this question
old marine
old marine
