Televison & Video Logo
tom taylor Posted on May 09, 2018
I just need the codes for Panasonic sc-htb70 soundbar to mate my jvc tv
What is the best way (cable) to connect my JVC TV Model LT-42N530A to a soundbar?
That really depends on what connections are on both the TV and the soundbar. Optical connections provide the best sound quality, but your TV and soundbar may not have that connection. Your manual for your JVC should show you all the different ways you can connect that. I would compare that to your TV's connections and look up the quality of the signal for all the connectors that match both. Hope that helps.
Is it easy to set up soundbar up to an x box 1? I'm just gunna settle for the soundbar to be used when gaming or using DVDs ect throu the x box.
Connecting your xbox one console to a sound system. this setting allows you to adjust how much the volume change on your tv using the volume up or down.
Need to hook up sayo sound bar to my elment tv and my dvd player together
Help me connect my soundbar to TV, DVD, and Cable ...
www.tomsguide.com/answers/id.../connecting-soundbar-dvd-cable.html
Jan 2, 2015 - I want to connect my soundbar to give sound from my dvd player and cable box. ... More about : connecting soundbar dvd cable ... SolvedHow do I connectmy Element ELEFW392 TV to my Insignia NS-SB314 soundbar.
How do I connect my sound bar to the TV, BluRay, DVD, and ...
www.tomsguide.com/answers/.../connect-sound-bar-bluray-dvd-dish.htm...
Dec 30, 2014 - Then connected Panasonic Blu Ray DVD player: Panasonic HDMI to TV... pretty hook them up and it works' followed by 'why did you buy a sound bar?' Do Ihave to connect sound bar to TV AND Dish receiver? and not to DVD? ... tv bluraysound bar and a DVR cable box together Forum; Solvedconnecting ...
Soundbar to tv [Solved] - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-2198401/soundbar.html
Have bought a Panasonic soundbar SC-HTB8. No connection cable included. Which cable do we need to buy to connect Soundbar to tv please?
You will need an optical digital audio connection for the TV and the TV will have to be fitted with a compatible "optical digital audio" OUT connection.
The soundbar unit you have does not have an HDMI connection so you only have the one choice with cable..
Any electronics store selling cables will fit you with the correct one.
The one pictured here next to the HDMI cable is the type you need (aka Toslink) but if you don't have an Optical digital Audio Out connection on your TV you have a problem.
HDMI vs optical Which digital audio connection to use CNET
1helpful
How do I get my headphones to work with my Panasonic smart tv and LG soundbar?
Let me see if I can understand what you want to accomplish.
You have a Panasonic Smart TV, and an LG soundbar. But you want to use a set of headphone. I guess that your TV is already connected to the soundbar, no?
The first thing that you need to check is for an output, it must be from the sounbar, it could be a 3.5mm jack, or an RCA jack. Usually soundbars only have input, meaning that only takes the sound in, never out. If you have an audio output from the TV, you c an always try, but the soundbar won't be use then.
Panasonic soundbar SC-HTB8 is paired to Bluetooth but won't play the sound from the connected TV, is there anything we can do. TheTV is a Panasonic smart tv & we have connected it with a optical lead
If you have connected the optical cable then you should be able to select AV using the TV remote, keep pressing until you hear sound from soundbar!
Need remote control code for Panasonc sa-pm01 (stero system) for programming into a TV/universal remote
This is the best i can do mate hope it helps:
http://www2.panasonic.com/consumer-electronics/support/Audio/Home-Theater/Micro-Systems/How-To-Guides/model.SC-PM01.H#ts
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
