I trying install window xp.and get errors message. Disk Read Error Occured. Press CTRL ALT DEL to restart.I trying install XP home edition.
This error can not read the order to your CD / DVD player or damage to your CD installer, try to install or use a different installer CD and when both said that problems can be your Player of the problem, hopefully it helped you.GOOD DAY
How are you installing it ?? boot from cd ?? or from a image or ??/if its from the disc..and its blocking ..and do not continue to copy files..the problem is the disc...its damaged ...if you want a copy look for me on yahoo ...catalin_yo_vlad I will provide you a image copy ..with a serial no that will be rec as original ...ad up-datable to sp3
