When phocopying a A4 sheet, the copy is shrunk. How can I reproduce the A4 original at the full size?
  • 365 Answers
Turn of reduction in copy model.
The procedure varies by unit and manufacturer
Posted on Aug 01, 2009
If I want to copy & paste from the internet my Canon Pixma MG3200 only prints the size of a postage stamp on A4. It used to be OK. What's wrong with my settings?
Default setting on printer itself must be set to passport photo size if from a computer go to devices and printers and look at printing preferences check paper size
Jan 08, 2015 | Canon Office Equipment & Supplies
I cannot copy and print a document on 8"X14" plain paper. No problem with 8"X11 1/2" plain paper
Scanner: dot2.gif optical resolution: 2400 x 4800 dpi /19,200 x 19,200 dpi interpolated dot2.gif 48 bit color depth
maximum document size: 8 1/2 in x 11/11/16 in dot2.gif Copier: dot2.gif copy speed for text documents: up to 30 copies per minute in black; up to 20 copies per minute color dot2.gif reduction/enlargement: 25/400 percent dot2.gif Fax: dot2.gif color or black and white faxing dot2.gif stores up to 40 numbers in speed dial dot2.gif built in memory for up to 100 incoming fax pages General Features: dot2.gif automatic document feeder holds up to 30 originals for copying, scanning, or faxing multiple documents dot2.gif Ethernet port for connecting multiple users in a computer network dot2.gif 2 picoliter sized ink droplets for fine detail 4 individually replaceable ink tanks dot2.gif ChromaLife 100 inks for long lasting photos dot2.gif Full photolithography Inkjet Nozzle Engineering /FINE 1,600 nozzle print head dot2.gif paper sizes: letter /8 1/2 in x 11 in, legal, credit card /2/ 1/8 in x 3 3/8 in, 4 x 6, 5 x 7 in, envelope, photo stickers dot2.gif high speed USB interface dot2.gif 18 15/16 in W x 9/ 7/16 in H x 18/ 1/4 inD dot2.gif weight: 22.3 lbs. dot2.gif Part Number: 2186B002
you have to select the paper size from the computer while giving printout from computer and apply the changes you make.and while copying the page from the scanner you have to change the printersettings by clicking the menu button in the printer.
Oct 04, 2008 | Office Equipment & Supplies
How do you enlarge on the HP309A SERIES
  1. Use the following guidelines to determine which setting to choose:
    • Copying an original to letter or A4 paper : Choose Fit to Page , or choose Full Page 91% to prevent unwanted cropping.
    • Copying a legal-size document to letter paper : Choose Legal > Ltr 72% .
    • Copying a photo to full-size paper : Choose Fill Entire Page .
    • Copying to a custom size : Choose Custom 100% , use the Up or Down arrow buttons (c01314741.gif ) to reduce or enlarge the size of the copy, and then press OK .
  2. On the LCD screen, choose Copy from the options (use the arrow buttons) and press OK .
  3. Press the Settings button (the button below the Home button) twice, to access the Copy Settings menu.
  4. Select Size and press OK to access the copy size options.
  5. In the Copy menu, use the arrow buttons to select the appropriate size settings. Press OK to continue.
  6. Press Start Copy Color or Start Copy Black .
Mar 05, 2011 | HP Photosmart Premium C309A All-In-One...
Windows 7HP and Epsom BX300F can scan but preview shows that, one a4 sheet is split into 4 or 5 random areas and will print those areas only on 4 or 5 seoerate sheets of A4. How do I change this so that...
Goto -> Printer's Property/ Prefrences 1 - "Layout" Tab -> Select Portrait in Orientation section. 2 - "setting" Tab -> Select A4 in Paper Size DropDown. 3 - Click OK and try.
Feb 16, 2011 | Office Equipment & Supplies
How to fax
Load an original in the automatic document feeder (ADF)
You can copy, scan, or fax a single or multiple-page A4, letter, or legal-size document by
placing it in the document feeder tray.
The document feeder tray holds a maximum of 20 sheets of letter or A4-size paper or 15
sheets of legal-size paper.
To send a basic fax from the control panel
1.
Load your originals. For additional information, see Load originals.
2. Enter the fax number by using the keypad, press Speed Dial or a one-touch speed
dial button to select a speed dial, or press Redial/Pause to redial the last number
dialed.
TIP: To add a pause in the fax number you are entering, press Redial/Pause,
or press the Symbols (*) button repeatedly, until a dash (-) appears on the display.
3. Press START FAX Black.
If the device detects an original loaded in the automatic document feeder, it
sends the document to the number you entered.
TIP: If the recipient reports issues with the quality of the fax you sent, you can
try changing the resolution or contrast of your fax.
for further refernce check out the online manual
http://h10032.www1.hp.com/ctg/Manual/c01181836.pdf
Mar 29, 2010 | HP Officejet J3680 Multifunction Printer...
Sir i face problem in di 650,i place original
Sir,
Do you have the paper selection in AUTO? Mite you also check your defaults settings
Feb 20, 2010 | Minolta Office Equipment & Supplies
Cannot fill a3 sheet
Have you set up the page as A3? If so, should be ok if you set the printer paper size to A3. If you set up the page on A4 you will need to tell the the printer to 'scale to A3' and it's best to say you want to preview before printing
Jan 31, 2009 | Canon PIXMA iX4000 InkJet Photo Printer
Size reduction from A3 to A4
put the A3 original on the glass.
press reduction button.
make sure you have A4 loaded into the drawer.
select that drawer.
off you go.
Nov 19, 2008 | Canon IMAGERUNNER 6570 Copier
A3 Printing
Put A3 in the paper tray and select reduce and enlarge and set to 141% this is A4 up to A3 then press start this should help.
Thanks J
Oct 02, 2007 | Sharp AR-161 Laser Printer
Copying
It seems to me that the tray sizes are not programmed correctly. A4 size is european and and slightly longer than letter size. If programmed to A4, the unit will behave as you described.
Sep 06, 2007 | Dell 1600n All-In-One Laser Printer
24 people viewed this question
k24674
