Question about Irons
Philips low cost iron box
i am srinivasrao .basically i am a electrical graduate i purchased one phi lips iron box.i am unable to fix the problem my that is ordinary iron box the the supply line is connected through one component to coil,and another one through temp selection switch across the coil one small indicator is is not switch on what might be the problem, can i bypass the component(may be resister) please fix the problem
  • 304 Answers
It sounds to me like the thermal cutoff switch has blown. Irons have these as a safety device similar to a fuse to protect against fire in the event the iron gets too hot. These are not very costly to replace. Here is a link to where you can buy them:
Make sure you get one of the exact same cutoff point as the one designed for your Iron. If you put in a higher temp device it will be harder to blow but will make the iron dangerous as it may cause a fire if it over heats. Some shady repair men will just bypass this and the iron will work again fine but this is a dangerous practice as it directly puts you of danger. If you do have it repaired at a shop demand for the old thermal cutoff from your unit when you drop it off so the tech will know you know what is wrong with it and that you will check to make sure that it has really been changed. This will also not give him the chance to over charge you when he knows you know it is only a 1 dollar part and easy to change.
This device is very easy to change, If you can open your iron you could easily do this yourself. The part, as you will see on the site where you buy them, only has 2 wires one comming out of each end. You simply cut out the old 1 and replace it with the new one. You do not even have to worry which end goes where. It is like a fuse, it works the same either direction. You have to buy some wire crimp connector to connect it, you can not just solder it in due to the heat in the iron. In a pinch you could just securely twist the ends of the leads with the leads from the old cutoff if you clip the leads from the old cutoff real close to the device. This will leave you with plenty of wire to get a good twist. I always use the crimp connectors so it looks more professional.
Anyway, I hope you found this to be helpful and if you need more help feel free to ask me. I will stay with you on this until we have it fixed.
Posted on Jul 25, 2008
I have phiips box but its hottness is not enough even to iron cotton or linen shirt what might be the problem
Posted on Jul 05, 2010
I am unable to twist off the top of the iron in order to put water into the steamer. I have tried twisting it clockwise and counter-clockwise as instructed. I
Please let me know the make and model of the iron. We have a Delonghi Pro300 and I fashioned an opener out of a 2 inch pvc t that I purchased at Lowes. It allows my wife to open the steam reservoir with no problem.
Dec 03, 2014 | Top Irons
Philips 6104 duble speed
follow this test and fix it. God bless you
As with many small appliances, regular maintenance makes a dramatic difference in how trouble free your electric iron will be. Even so, things can happen.
If the iron doesn't heat, make sure power is on to the outlet, check the power cord and check the thermostat and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents and flush sediment out of the steam chamber
If the iron produces too much or too little heat, test the power cord Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Nov 29, 2013 | Philips HI-296 Iron
My ultra T-fal iron is leaking right out of the iron, before I turn it on. Should I get a new iron, or can this be fixed?
I believe there`s faulty construction'and the cost to repair is about as costly as a new purchase.The valve that inhibits the water flow apparently is remaining open.
Mar 04, 2013 | Irons
Trying to fix philips iron 1830
you must go to www. and buy it or go to the supplier from the electrical iron. or you can go to some home depot and proove it some screws and buy it for fix it.
God bless you
Oct 01, 2012 | Irons
Our philips iron keeps tripping our fuse box - this is the second model (but different model) that has done it - is there any advice you have as to why this keeps happening?
Your circuit is bring overloaded by the iron.Irons use lots of energy They usually use more than half the capacity of most electric circuits.Try it on another circuit or unplug some other heavy energy user on the circuit.Better yet have an electrician have a look on the circuit.
Feb 13, 2011 | Philips Irons
Leaking where the base plate attaches to the upper portion of the iron thus causing all the water to eventually run out onto the iron board or item being ironed. I do not have original receipt or box but...
This is a leak on the seating of the body to the frame and it is possible that the seal is not tight. It can be tightened with the screw fittings inside the handle but if you can get warranty for the Iron it will be bettter than tampering within.
Now for the time being do not use water into the iron but have it dry and sprinkle from outside till you get confirmation from Walmart.
Sep 26, 2010 | Irons
Steam iron is not heating.
Yes you most likely can, they are very simply consisting basically of, a switch, a thermal fuse, a thermostat, and an element.. all wired into the Phase wire, the neutral, is simply the return. Take it apart and draw a diagram of how it all goes together and reverse the procedure.
May 09, 2010 | Irons
The electrical at home trips everytime I swicth ON the AZUR4330??
I know its hard to say... But please get a new iron....
You me y do more harm to other electricals just trying to fix the iron....
I know this is not a great solution byt a pratical one...
Warm Regards
Feb 02, 2010 | Philips HI-296 Iron
2 yr old Tefal Pro Express Steam generator Iron Trips Fuses
hello does all the electric go off in your home if so theres a bad earth on the iron or the iron element is shorting out also make sure theres no water getting into the iron good luck
Mar 20, 2009 | Tefal UltraGlide plus 1656 Iron
Iron is out of order
an appliance repair center could probably fix it but you have to consider the cost against a new iron
mostly it is more costly to repair than to fix
Oct 19, 2017 | Panasonic NI-A57SR Iron with Auto Shut-off
Irons Logo
1,638 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
