Question about Gaggia Syncrony Compact Coffee Maker/Espresso Machine
Brand new Gaggia Syncrony Compact will not pump water. Red light no. 27 flashes, and machine makes sounds as if trying to pump.
    President:
  • 1,618 Answers
Open the hot water valve, if it flows for a second and stops, then pusi in on the knob if that works, call up support and ask for a new stainless steel valve for your machine.
Posted on Aug 02, 2009
The led 27 flashing no stop
Hi
If you are talking about the descale light, you must let the machine quit on its own. The pump has to stop on its own. Any interruption (you stopping the machine) will keep it in the descale mode. Once it stops on its own, the lights will change. Then do the rinse by replacing the water in the tank and closing and then reopening the steam knob and again letting the machine quit on its own. Again the lights will change. Then repeat the last cycle (putting water in the tank and closing and then reopening the steam knob)until all the red lights go away and you only have a green blinking light. Now your finished descaling a compact without a digital display.
Jan 06, 2010 | Gaggia Syncrony Compact Digital Espresso...
Descaled and got 23, 24, and 27 buttons flashing
Fill water tank and open the knob to empty boiler and circuit.
Nov 29, 2009 | Gaggia Syncrony Compact Coffee...
Low water light stays on
If water light and heating lights go on and off, Try this: Fill water, turn water nozzle on, let water flow out. Water light should go off. Shut off water.
If coffee lights are solid, turn off the machine, let it cool off and try the above again.
Jul 07, 2009 | Gaggia Syncrony Compact Coffee...
GAGGIA syncrony compact coffee grinder motor is
Remove the brew unit and to the left of that is the the discharge area for the grinder, make sure that hole is clear, then adjust grind 1 number coarser, and check machine.
Jun 07, 2009 | Gaggia Syncrony Compact Coffee...
Water is leaking, while the machine heats water for steaming
The steam valve tap rod needs to be replaced, or check machine if it has a plastic steam valve, Gaggia designed a new Stainless steel steam valve for the compact machine.
May 23, 2009 | Gaggia Syncrony Compact Coffee...
Gaggia Syncrony
I think you get air in the system, try to find a bellow pump or similary and force in water in the water tank inlet. Make sure you open the steam knob when you do this.
Hope this will help you.
/Mirran
Aug 09, 2008 | Gaggia Syncrony Compact Coffee...
Try to make a cup of water, if you only can get a half cup then the flowmeter has to be replaced.
Jun 22, 2008 | Gaggia Syncrony Logic 74884 Espresso...
If you are in decalcify circle you have to finish it before the machine goes to ready again.
When you decalcify the machine, there will comes water for a short period, then it hold up for a couple of minutes then it will run out little more water. So will the machine do to the water tank is emty.
May 18, 2008 | Gaggia Syncrony Espresso Machine
Gaggia Syncrony Compact Coffee Maker/Espresso Machine Logo
332 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
