Question about Peg Perego John Deere Gator HPX Ride on Toy
No power going to the motors beyond the switches
    Problem Solver:
  • 8 Answers
This could very well be a wiring harness. Did one wheel turn for awhile, then none? This would probably be the motors in that case.
I would visit www.perego.com and call riding toy customer service.
Posted on Aug 04, 2009
WHAT COULD BE CAUSING MY PASSENGER SIDE WINDOW NOT TO GO DOWN? HAVE POWER TO THE LOCKS AND MIRROR. ANY SUGGESTIONS?
The first thing I would do is check the fuses. The fuse/circuit for the power windows would require more amperage than the mirror or locks and, would therefore, be on a totally different circuit. Check the owners manual for the location of the fuse.
Was the window acting up (operating slowly or making mechanical noises or grinding noises) if any of these were noticed, I would suspect a faulty motor or broken window regulator.
Me thinks, if it is anything more than a blown fuse, it would be beyond your skill level to fix therefore, I would take it to a reputable repair facility and ask them to check it out. If it is a fuse it would be a minimal charge.
Jun 03, 2014 | 2005 GMC Envoy
No power beyond the switch ,have replaced switch and front actuator
Have you checked fuse #48 in rear fuse box and fuse #8 in underhood fuse box?
Mar 25, 2014 | 2006 GMC Envoy
How to reset driver window motor in 2006 BMW 750
Press the window 'open' switch beyond the second switching position. When the window has reached the lower final position, operate the switch for at least 15 seconds but not longer than 25 seconds. Then let go of the button and immediately pull the switch beyond the 'close window' position. Do not let go of the switch! The window now moves into the top final position, stops, then moves to the lower final position, stops again and then moves back to the upper final position. The switch must be held in the "pulled beyond engaging point" position during the entire procedure. Once the window has reached the upper final position, the initialisation is complete.
Jan 14, 2012 | 2006 BMW 750Li
Front wipers will not operate. checked fuse and relay look ok. back wiper works
Here are a few other things to check beside the fuse and relay:
Check Wiper Motor - the wiper motor is the driving force of the windshield wiper. Feel the motor and listen to a humming sound. If there is no humming, the motor is the problem. Check if the motor is working properly and see to it that its electrical connections are made properly. If you find that the motor is dead and beyond repair, get it replaced immediately.
Check For Break in Connecting Wires - the connecting wires of the motor sometimes go loose and that may cause the windshield wipers to stop working. Also check the battery plug connection which the motor has. Connecting the loose wires properly or fixing/replacing the plug might solve your problem.
Check Wiper Switch - another wiper assembly part that can malfunction is the wiper switch itself. Check for switch malfunction and if you find that is indeed the problem, get it replaced from a mechanic.
Check for Bent Wiper Arms - bent wiper arms can cause the operation of the wipers to be hampered. If the wiper arms are bent beyond repair, get them replaced immediately.
Nov 25, 2010 | 2003 Isuzu Ascender
Wiper stopped working...what is the problem
Wipers Not Working - Things to Check
To troubleshoot car windshield wiper problems, you need to thoroughly investigate problems with any of its operating parts. Here are some of the things that you need to check to determine why are your car windshield wipers not working.
Check Wiper Motor
The wiper motor is the driving force of the windshield wiper. Feel the motor and listen to a humming sound. If there is no humming, the motor is the problem. Check if the motor is working properly and see to it that its electrical connections are made properly. If you find that the motor is dead and beyond repair, get it replaced immediately.
The connecting wires of the motor sometimes go loose and that may cause the windshield wipers to stop working. Also check the battery plug connection which the motor has. Connecting the loose wires properly or fixing/replacing the plug might solve your problem.
Check Wiper Switch
Another wiper assembly part that can malfunction is the wiper switch itself. Check for switch malfunction and if you find that is indeed the problem, get it replaced from a mechanic.
Bent wiper arms can cause the operation of the wipers to be hampered. If the wiper arms are bent beyond repair, get them replaced immediately.
Check For Blown Out Car Fuse
A blown up car fuse could be the culprit that has stopped the windshield wipers from working. Check the fuse assembly under the dashboard of the car. Replacing a blown fuse might fix the problem of windshield wipers not working.
Windshield Wiper Sprayers Not Working - Things to Check
Sometimes the windshield wiper sprayer stops working which can be very annoying. The washer mechanism is a self cleaning mechanism for the windshield. Here are some of the things that you need to check in case it is not working.
Check Windshield Washer Motor
The windshield washer mechanism might have been impaired due to the malfunctioning of the wiper washer motor. Check if its working and get it replaced if it is beyond repair.
Check Windshield Washer Fluid Level
Sometimes the washer doesn't work because the washer fluid levels are not filled to requisite levels. Filling in fluid might restore normal functioning.
Check For Broken Washer Hose
The connecting washer hose that connects the reservoir to the nozzle, might be broken or worn out stalling the overall operation. Check the hose for leaks and get it replaced.
Check Washer Nozzle For Clogging
Last thing to check is the nozzle of the washer for clogging. An obstruction in the washer nozzle might be the reason for windshield wiper sprayers not working. Using a pin, clean the clogged nozzle. This might restore the sprayer to the normal working condition.
Jun 07, 2010 | 1998 Saturn SL
2006 Mercury Marquis: Wipers will not turn off. Is a problem with the wiper switch? If not, what could be causing this?
You may be under warranty and it is always beneficial to check with the dealer about Service bulletins. Those bulletins can go beyond the normal warranty.
Your wiper switch could be the problem. There is also a cutoff device inside the wiper motor. When power is applied to the wiper motor it rotates. When you turn off the power the wiper continues to rotate a partial cycle and then breaks the grounding contact. The grounding contact is no longer getting magnetism from the current and it releases the points that ground the wiper. Thats when it shuts off.
If the wiper motor is grounding somewhere else in the case it will not shut off despite the wiper switch. Some housings have a plastic shield cover that sometimes lets you spray WD 40 into the points. If this solves the problem it is not the switch but the motor.
Nov 12, 2009 | 1983 Mercury Grand Marquis
1998 c1500 chev p.u. windshield wiper motor no go any speed
Beyond the obvious answer of replacing the motor itself, check the fuse, and bad wiper switch, it could be just the auto-park switch on the wiper motor that is worn out.
Oct 23, 2009 | 1998 Chevrolet C1500
The bosch 11227e rotary hammer will not energize when
It sounds like the cord is ok as you have power to the switch. It also sounds like the switch is OK. These units have a governor on them as well. I suspect the governor because you indicated that the hammer will not come up to full speed. Beyond the governor, the only other thing to look at is the motor. You did say that you didn't notice any sparking so the motor sounds like it is OK.
In my opinion from everything you said, its the governor.
May 01, 2009 | Drills
Heater motor works intermitantly
This Realy Sounds Like A Bad or Loose Ground Although it Could Be the Power Plug too Check for Loose Plug At the Blower motor And Also try to Catch When its Off but Switch is on And SMACK it With a Screwdriver this will tell its the GROUND Wiggling the Power lead W/Blower On & it comes on Says Its the Hot or POWER Lead to motor. Beyond that Its gona be the RELAY But AS I Said I think its Power or GROUND LOOSE Hope this helps !!
Jan 30, 2009 | 2000 Jeep Cherokee
Peg Perego John Deere Gator HPX Ride on Toy Logo
169 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
