Question about Whirlpool SB160PEE Gas Single Oven
Whirlpoo stove is in celcius now how can i change it back
    President:
  • 1,714 Answers
You must go through the 'menu' on the control panel to set preferences and set to Farenheit
Posted on Aug 01, 2009
Is the oven temperature in Celcius or Farenheit...I tried to heat up oven to cook chicken and it only goes up to 287 degrees....
It should come programmed with ?F. Have you tried to cook anything in the unit to measure the temperature? That would be another way to easily tell. Set it for the highest you can get it and bake something you normally would be at a lower temp for lower amount of time and go from there.
Sep 05, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Americana stove not heating but lights come on
get in an electricians to check what looks good but isn't
May 29, 2017 | Ovens
My Thermador RDDS30VRS only heats up to 230 degrees
If you have the use and care manual, check to see if your unit has the option to change from farenheit to celcius. If so, make sure yours was not accidentally changed to celcius.
Sep 07, 2011 | Thermador SEC301 Electric Single Oven
I have a Simpson electric oven with stove top elements, and one of the burners will only cook at the highest level, I cant figure out how to change it, any suggestions?
You need to change the "Simmerstat", take the model number to your local electrical parts supplier/parts counter at your local stove retail shop that sells Simpson stoves and ask for one for that model, make sure you get the right one for the position as some control a single element and some control dual elements.
*** TURN OFF THE WALL SWITCH AND ENSURE NO POWER IS APPLIED TO THE STOVE BEFORE PROCEEDING ****
Remove the upper back panel of the stove. Swap wire for wire of the old simmerstat to the new one, remove the knob from the old Simmerstat, undo the nut securing the simmerstat in the oven control panel and discard, fit new one, secure, fit knob, fit back panel, turn on wall switch and test.
Some countrys/states require registered electricians perform this task on electrical appliances so you must ensure you can do this legally before you start and take the relevant safety precautions and don't electrocute yourself.
Apr 13, 2011 | Ovens
I need to know how to change the temperture from celcius to farenheite
press and hold PRECISE CLEAN for 5 seconds, a tone will sound and c or f will appear on the display. repeat to change back. to exit press CANCEL/OFF
Dec 17, 2010 | Whirlpool RBS275PD Electric Single Oven
Getting oven back on fahrenheit instead of celsius
Actually for the Whirlpool Accubake I just figured out, the bake button didn't work, but holding the broil button did the trick.
Apr 19, 2009 | Ovens
Temperature Display
Press and hold CUSTOM BROIL for 5 seconds. A
tone will sound and “°F” will appear on the lower oven display for
3 seconds.
A complete owners manual can be downloaded from
http://shared.whirlpoolcorp.com/product_literature/search.jsp
Thanks for using Fix Ya, please take the time to rate this solution.
clarkco
Feb 06, 2009 | Whirlpool GBS277PD Electric Single Oven
How do I change my whirlpool oven back to Farenheit instead of celcius...
its in your manual, did not give model number so i looked up anyone. if this does not work you can enter your model number here for a copy of user manual
To Change:
tone will sound and “C” will appear on the display. Repeat to
change back to Fahrenheit.
Nov 07, 2008 | Whirlpool Ovens
Fan Oven blows Fuse over 175 Celcius -Baumatic BT2760SS
Hi, I was cooking and my oven jut went off, looked in fuse mains box and had tripped. So put back on and now the fan works but no heat...Can you give me some idea what it mite be.
Sep 18, 2007 | Ovens
Whirlpool SB160PEE Gas Single Oven Logo
94 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
