Question about Bosch 18 in. SRS45E02 / SRS45E08 Exxcel Slim-Line Free-standing Dishwasher
E3 showing on Kenwood model KDW243A
E3 showing before cycle starts following repeated beeping. Any ideas?
    Problem Solver:
  • 16 Answers
E3 means longer heating time. Usually this indicates the heater element has failed.
Posted on Jan 24, 2010
Dishwasher shows error e01
It seems like main motor pump or main control problem
do step by step troubleshooting procedure to eliminate working parts until you could detect defective part or parts
Dec 09, 2013 | Kenwood KDW243A Builtin Dishwasher
Kenwood KDW 243A Dishwasher has an E3 fault and will not wash the dishes, can you tell me what is causing this please? Thank you
The error (E3) relates to the water heating but not reaching the required temperature. This can be due to a couple of things generally. The sensor which detects the water temperature can be faulty or the heater element itself is faulty and not heating the water to a high enough temperature. I think it's needing to be replaced.
Check to see if there is a thermostat screwed up into the underside of the tub on the rear right side. If there is, test the thermostat to see if it's open circuit, if it is you'll need to change it.
Jun 12, 2011 | Kenwood KDW243A Builtin Dishwasher
Kenwood diswasher kdw243a/a e3 fault code?
e3 means there was a longer heating time but not reaching required temperature could be a malfunction of temperature sensor or of heating element. E3 is a temperature error. There are two theromstats, 90 degrees and 78 degrees. I suggest you to call the competent person to substitute either of these thermostats.
Jun 05, 2011 | Dishwashers
My Kenwood KDW243A built in dishwasher is desplaying what I assume is an error code, E3. What does this mean? The washer is not washing properly.
E3 means the base is full of water. A quick fix is to tilt the machine back for 10 mins or so but you need to find the cause of the leak and repair it
Jun 03, 2010 | Kenwood KDW243A Builtin Dishwasher
SHOWING E3 ON DISHWASHER
Had the same problem (apart from the code) and the answer is to stop putting plastic in the machine ! It seems the dishwashers need the heat radiated from the Ceramic plates, stell knives etc to help dry. The plastic simply absorbs some water and then your dishwahser spends most of its drying time trying to get that water out again. Also Plastic doesn't radiate any heat to help. As soon as we stopped putting plastic plates and tupperware containers in, hey presto the dishes are drying again
Apr 13, 2010 | Kenwood KDW243A Builtin Dishwasher
My Kenwood Dish washer KDW243A has the Code E3 showing, its working but not heating up the water
If you inspect the heating element at the bottom of the dishwasher, you will probably find damage. Replacing the element is the next step.
Good Luck!
Jul 07, 2009 | Dishwashers
E1 fault on kenwood dishwasher kdw243a
error code E1 refers to "lack of water inlet pressure" the valve the elctrically lets in the water might be at fault
Jan 18, 2009 | Kenwood KW85 Air Conditioner
Dish washer is not working
Hi kssami9,
I'm Harvey the Master Plumber.
Your problem is: Your dish washer kenwood model kdw243a is not working and displaying the error code E3 please give you the solution.
First try to reset the d/w. Just turn it off at the circuit breaker for ten minutes.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 27, 2008 | EuroTech Dishwashers
Kenwood dishwasher kdw243a
kdw243a code E3 what doesthis mean. ??? pleae.. adres Poland,,,,,, e_mail wiesiekwro@poczta.fm
Dec 14, 2007 | Kenmore Dishwashers
Bosch 18 in. SRS45E02 / SRS45E08 Exxcel Slim-Line Free-standing Dishwasher Logo
730 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
