Question about Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HLP5063W turns itself off
I have had this television for 3 years and have had no problems. Recently, the TV turns itself off with no indicator lights showing a problem. The set may go several days and not do this, but on some days it may turn itself off up to 3 times per hour.
  • 7 more comments
  • Jbreitenbach Dec 14, 2007
    I am having the same proble with my DLP. I am TV DUMB so if there is any way that someone can do a play by play as to what I need to do to fix this it would be awesome. And if the thermostat indeed does need changing than where might I locate this item?
    Thank you!
  • Billy Rodgers Dec 21, 2007
    I have the DPL...ownwed for about 1 year...Set turns itself OFF periodically for no apparant reason....I don't know what to do to correct this!!!!!
    Set turns its self off. What do I do and what might be the problem?????
  • 5063 Mar 02, 2008
    The TV turns itself off, and none of the 3 lights flash to indicate the problem for trouble shooting it. I've vacuumed out the back, even though it didn't need it, still the problem exists. The TV will not stay on.
  • ajacks504 Apr 23, 2008
    I have the same issue, tv randomly turns itself off. It seems to do it mostly on startup (cold), then become increasingly infrequent as the tv gets warmers.
    1 after 3 mins, 1 after 5 mins, 1 after 20 mins, 1:30, 1:60, etc...
    This leads me to think that there is a heat problem and makes the thermostat change sound like a good option.
    Anyone have these issues and successfully resolve it?
  • cheldark Jul 01, 2008
    I've had this HDTV just under 4 years and its just started this problem about a month ago, i.e., randomly turning itself off 1 or 2 times every evening of 4 hours watching. I, also, am looking for a solution.
  • rudistahl Feb 28, 2009
    Our "Samsung HLP5063W turns itself off several times in an evening, more often when the TV has been on a short time.
  • sandusky Feb 28, 2009
    had this tv for 4 years and have this same problem with the set turning off randomly, they replaced the lamp but it still turns off
  • Anonymous Apr 25, 2009
    the set turns itself off. it is happening more often and currently it won't stay on for more than 10 minutes.
  • 179 Answers
Rither the lamp door cover switch, or the thermostat has become intermittent..neither one is very expensive but soldering skills are needed
Posted on Nov 30, 2007
Lamp light and timer light continue to blink but no picture just sound; had this problem about 18 months ago, the repair service had the TV for one month; what do i do; i am trying to find a local repair service HELP
Posted on Apr 20, 2009
Won't start
The symptoms are indicative of a power supply problem. The age of your TV can influece your repair/discard decision.
Jan 21, 2014 | Samsung TSK3092WF 30" TV
My HLP5063W tv comes on and works for 3 to 5 min then the pictures gets dark and the colors are distorted. The remote no longer operates the set and I can not turn it off using the front or side switch. ...
It sounds like your lamp is about to die out,this tv lamps are good for 6000-8000 life hours which is a average time of 2-4 years old and with time the picture starts to get darker and darker until one day black screen. Try Encompass .com ;
Jun 11, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HL-P6163W DLP sometimes turns on with NO PICTURE
sounds like the dmv pcb bpard cost 597.70 and about a 250 core charge from andrews electronics.
or you can look ay the price at partsstore dot com.
Jan 09, 2009 | Samsung HLP6163W 61" Rear Projection...
Samsung LNR 328W TV turns itself off and turns itself back on
it sound to me like your power supplie is heating up and shuting down your power supplie is on its way out
Dec 02, 2008 | Samsung LN-R328W 32 in. HD-Ready LCD...
Tv shuts itself off
Look for the computer processor inside the TV. It needs to be cleaned. A can of compressed air will work. The processor is overheating and causing the tv to shut off. Look for the small fan that is supposed to keep the processor cool then remove the dust.
Oct 22, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HLP5063W DLP
no you do not need a bulb you will need to have the color wheel replaced.
Aug 04, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Only black and white
The same thing happened to my HLP5063W. Researching the internet forums I concluded the problem was with the color wheel, which I replaced. As it turns out the old one was completely smashed. Go to for replacement instructions.
Jul 05, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Very noisy when turned on, then shuts down, Samsung 61 inch
Color wheel defective. Replace it with the new designed color wheel. The lamp is ok.
Dec 10, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HLP5063W-Picture Dropping Out Using HDMI
is the eprom settings set correctly for the input beeing used,you must enter the service mode to inspect and adjust the settings,call your local dealer for assistance.
Sep 12, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HL-P5063W 50" Rear Projection HDTV Logo
526 people viewed this question
Jerry Greenberg
Jerry Greenberg
