The Computer part works it tells me im walking but the tread wont go?
SOURCE: have a proform pro from730cs treadmill every
The walkbelt is either worn out or has a lack of lubrication between the walkbelt and deck. Either condition causes too much friction between the belt and deck causing the motor to overheat. Do not use silicone or unapproved lubricants as they will deteriorate the walkbelt.
SOURCE: What does code 22 mean?
Error 22 - No Motor Pulses at Start Up
Description
Error 22 indicates that the drive motor (running belt) has been instructed to start, by either
manual or program control, and the monitoring system has not received any response from the
speed sensing system indicating that the drive motor has started.
Possible Causes
1. The treadmill utilizes an optical (infrared) speed sensor and the line of sight between the
speed sensor and the speed sensor target is obstructed.
2. Drive motor brushes are bad.
3. The speed sensor position relative to the speed sensor target is incorrect.
4. The speed sensor potentiometer adjustment is incorrect (when equipped).
5. The speed sensor is inoperative.
6. The lower PCA is bad.
7. The lower PCA to upper PCA interconnect cable is bad.
8. The upper PCA is bad
SOURCE: Proform 590 HR Treadmill. Belt won't run
Hi, i fixed one just the other day, the control unit fails.
broddersbaldrick on a big auction site fixes them :)
Hope this helps
SOURCE: Proform 2500 treadmill stuck in incline position
Under the motor shroud their is a instruction mini manual it will have a how to calibrate the incline motor, if that does not fix it then you may have to manually adjust the incline motor and sometimes it will take awhile to realign . If that does not work replacing the motor maybe the only option
SOURCE: my treadmill Proform caliber walk... belts keeps
The deck needs to be lubricated. The lubricant can be purchase @ gympart.com. LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes
