Question about Torker Tri Star Rear Basket White Bicycle
How do you install the rear fenders on a torker tristar
I had to make longer support rods for it.I made them pieces I had,and I t wasn't great,but if you can find long enough support rod it will work fine.Tom
Posted on Jan 21, 2014
I have 2 Torker bmx bike from I think the late 80s.I would like to find out year and model on this if you can help. Here are the serial numbers, da 70526004 and the other is do 70524778
You can look under the saddles or even any plastic part for a year scale engraving. The engraving should be a circular scale of years and an arrow pointing to the year of manufacturing of the particular part. The bike could be slightly younger than the part fitted to it.
Feb 10, 2016 | Torker Cycling
How to remove rear fender on duece
2003 Softail FXSTD REAR FENDER removal and replacement:
Start by blocking themotorcycle underneath the frame such that the rear wheel is
raised off the ground to allow necessary clearance for removal of the fender and then remove the seat and disconnect the negative battery cable. THEN remove all of the fasteners from both of the fender supports, remove the fasteners and washers from fender underside, remove the fasteners, and spacers adjacent to the oil tank, remove the tail lamp. disconnect and remove the rear turn signal assemblies, disconnect both of the ignition control module connectors and the rear lighting harness, remove the retaining nuts from both fender mounting brackets and lift the fender from the motorcycle. To Disassemble the fender:
start by removing the both screws and washers and remove the license plate bracket from the rear fender. THEN, if needed,remove the tail lamp harness from behind that bracket To Reassemble the fender: start by reinstalling the tail light harness of it was removed and position it along the side with the slot as it was removed from. THEN fasten the license plate bracket and tighten both of the fasteners to 144-180 in-lbs (16.3-20.3 Nm).
To Reinstall the Fender start by positioning the fender inside of the frame tubes and over the tire assembly making sure that both the ECM and the tail light wiring harnesses are not in a position that they might possibly be pinched by the fender and having done that loosely install both fender mounting brackets using on each side, the two nuts that were previously removed from these locations and tighten them all to 20-25 ft-lbs (27.1-33.9 Nm). THEN apply a drop or two of LOCTITE THREADLOCKER 243 (blue) to the fastener threads, install the fasteners and spacers to secure both fender supports and with the spacers on the front fasteners and tighten them to 168-192 in-lbs (19.0-21.7 Nm). THEN re-attach the turn signal assemblies, loosely install the fasteners and washers from the underside of the fender and tighten them to 144-180 in-lbs (16.3-20.3 Nm). THEN re-connect the ignition module connectors and the rear lighting
Harness and install the tail light assembly, reconnect the battery negative cable, properly and securely reinstall the seat.
Jun 16, 2014 | 2003 Harley Davidson FXSTD Softail Deuce
How do i remove rear fender on night rod special
To remove a 2011 VRSCDX rear fender FIRST remove the main fuse under the right side cover first, then remove the tail light open the seat, remove the seat pillion, remove the fasteners and the passenger pillion, remove the electrical caddy and the six fasteners and the washers from the fender, remove the fender from the inner fender by lifting upward and sliding the fender back, remove the inner fender by removing the rear shocks and fasteners.
To install a 2011 VRSCDX rear fender FIRST install the inner fender and fasteners, tighten the fasteners to 95-110 Nm (75-81 ft-lbs), install the rear shocks using shock mount fasteners and tighten the fasteners to 41-68 Nm (31-50 ft-lbs), install the rear fender by sliding it into the slot on the tail lamp panel and aligning the fender with the bolt holes on the inner fender, install the six fender fasteners and tighten them to 4.5-7.5Nm (40-66 in-lbs), install the tail lamp, install the passenger pillion and its fasteners. And tighten them to 20-26 Nm (15-19 ft-lbs), install the main fuse, install the right side cover and ensure that the headlamp, tail lights and stop lamp and turn signals are operating properly.
Jun 04, 2014 | 2011 Harley Davidson VRSCDX Night Rod...
Trying to remove the battery from my 2007 soltice
Hello robert.... Battery Replacement
Removal Procedure
Disconnect the negative battery cable (2). Refer to Battery Negative Cable Disconnect/Connect Procedure .
Remove the wheelhouse liner. Refer to Wheelhouse Liner Replacement - Front .
Lower the vehicle.
Open the positive battery cable connection cover.
Loosen the positive battery cable bolt.
Remove the positive battery cable (1).
Remove the front fender rear bracket to side rail bolts.
Remove the front fender to front fender rear bracket upper (1) and lower (2) bolts.
Remove the front fender rear bracket.
Remove the battery hold down retainer bolt and retainer.
Important: Do not tip the battery more than 40 degrees during removal.
Remove the battery.
Installation Procedure
Important: Do not tip the battery more than 40 degrees during battery installation.
Install the battery.
Notice: Refer to Fastener Notice in Cautions and Notices.
Install the battery hold down retainer and bolt. Tighten the bolt to 25 N·m (18 lb ft).
Install the front fender rear bracket.
Install the front fender rear bracket to side rail bolts. Tighten the bolts to 20 N·m (15 lb ft).
Install the front fender to front fender rear bracket upper (1) and lower (2) bolts. Tighten the bolts to 20 N·m (15 lb ft).
Install the positive battery cable (1).
Tighten the positive battery cable bolt. Tighten the bolt to 17 N·m (13 lb ft).
Close the positive battery cable connection cover.
Install the wheelhouse liner. Refer to Wheelhouse Liner Replacement - Front .
Connect the negative battery cable (2). Refer to Battery Negative Cable Disconnect/Connect Procedure .
Joe
Thanks for choosing Fixya!
Jan 30, 2011 | 2007 Pontiac Solstice Convertible
Where is the battery located?
Battery Replacement
Removal Procedure
Lower the vehicle.
Remove the battery.
Connect the negative battery cable (2). Refer to Battery Negative Cable Disconnect/Connect Procedure . 1737d1122299169-solstice-service-battery-replacement-procedures-158wilmingtoncarshow36.jpg
hope this helps . please rate my response.
Nov 28, 2010 | 2007 Pontiac Solstice Convertible
Dead battery
Removal Procedure
Remove the battery.
Oct 15, 2009 | 2006 Pontiac Solstice
Can't find a Torker tri-star 3 wheeler to try out
In my experience there are very few adult tricycles that are not cheaply made under $1,000.00 . Keep searching on the net. Try and find one with a parts list, and what kind of tubing is used in the frame build. Good Chromoly tubing is recommended. Go to Parktool.com., and educate yourself on the cycling industry. Libraries often have back issues of cycling magazines.
Jan 21, 2009 | Torker Tri Star Rear Basket White Bicycle
TriStar Vacuum Nozzle Pivot Elbow replacement
Look inside the two rear wheel slots. You will find the two retaining screws that hold the unit together.
Feb 12, 2008 | Vacuums
Torker Tri Star Rear Basket White Bicycle Logo
74 people viewed this question
Top Torker Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Torker Cycling Expert? Answer questions, earn points and help others
