Damesha Murphy Posted on May 08, 2018
Ematic ebs107 speaker doesnt work - Ematic Audio Players & Recorders
Ematic esb112x
Try resetting the unit buy holding down the volume up and power button at the same time. It may work.
[email protected]
USING SOUND BAR FOR BLOWN SPEAKER ON TV
If you use Blue Tooth, wires are not needed.
Press the manual Mode button to find blue tooth mode. Green light will display. Blue Tooth is a general signal sent out. There is no specific setting for TV.
If your TV is sending out a Blue Tooth signal, it should find the speaker automatically. http://www.ematic.us/sites/default/files/ESB212_Manual_01_0.pdf
Check your TV's Blue Tooth settings and have it scan. Default password/code for the sound bar is 0000.
Also check your remote batteries. Sometimes they are installed backwards by the factory so they won't go dead.
How do I mount my sd card
Maybe the SD card is damaged.
Try if it is working on a different device or computer.
1helpful
2answers
How to charge ematic esb112x speaker
It's a relatively cheap speaker. If it doesn't charge via usb the speaker is defective. No repairs are available.
Ematic instructions
my granddaughter has a sprout cubby that she got for CHRISTMAS she has forgot her email address and her password it will not reset plzz help
2helpful
I am using my ematic e6 mp3 player for the first time. I connected it to my computer and it says USB connected. However, the charging icon does not appear when I press the exit button. What do I do?
have you tried holding it down? get an AC adapter and plug it into the wall and try it again and if it doesnt work, then you might wanna call ematic support and ask for a solution.
10helpful
2answers
Computer not reading drive for Ematic mp3 player
i am having that same problem, and ontop of that my ematic is frozen! when i turn it on the picture of the river comes up and stays up untill you turn it off. i have the ematic 5 series, is thier a solution?
Top Ematic Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you an Ematic Audio Player and Recorder Expert? Answer questions, earn points and help others
