Question about Philips 47PFL7422D/37 Television
47pfl8404 two days old-DEAD!
Tried to switch on this morning and the Philips logo comes up as usual, then screen turns off and white light just blinks continually. Tried unplugging for a while and plugging back in but to no avail. I guess this is the main board, but could it be caused by adjusting the service menu? Surely not? I know they warn you against this but surely there's nothing that should do this to the tv? It was working fine all day yesterday until I switched off last night. I'm just worried that they might be able to tell I've been into the service menu and not refund my money.
  • 4 Answers
SOURCE: Actually Philips 20PF5320/01 Fault no power, blinking LED
If the TV has sound and no picture, it might be the timer settings. There is a fix for Philips 20PF5320 here
http://www.123datarecovery.co.uk/fix_philips_pf5320.htm
Posted on Mar 20, 2008
funkengruuve
SOURCE: My Philips 19pfl3403d/f7 wont turn on without unplugging first.
just call philips and they will send you a new t.v.! it isn't a recall, that would be bad publicity!! i spoke with a philips representative yesterday concerning my 'possessed' television. a gentlemen informed me that philips has a 'rapid replacement program' for the described 'possessed' t.v. set. simply provide model and serial numbers, time and place of purchase, then provide street address for fed-ex delivery. approximate time of arrival is 10-15 days. you are directed to package and return the old set to nearest fed-ex pick up site. i am super excited that i took the time to call philips support. i think that i spent a total of 10 minutes on the telephone; it was time well spent. oh yea, here's the number!
Speak with a Philips representative
1-888-744-5477 Monday - Saturday 8:00 am - 11:00 pm EST Sunday 9:00 am - 6:00 pm EST Excluding major holidays
Posted on May 10, 2009
ginko
  • 19396 Answers
SOURCE: Red LED blinking after turn on the TV (Philips Plasma 42PF9631D
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 21, 2009
  • 44 Answers
SOURCE: Hi. My Philips flat TV will not show any picture
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
roety
  • 585 Answers
SOURCE: No picture in Philips 42pf7220a/37 Plasma TV.
Hi my name is Roety,
I can help you with your issue ,
You can look for two bad capacitors on the power supply. They will look swollen on top like this photo
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Posted on Nov 14, 2009
Vizio M650VSE powers up, pilot light comes on, logo comes on screen, 10 seconds later, logo goes off of screen, pilot light goes off then flashes 1 time. Which board has the problem?
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Nov 30, 2016 | Vizio 65" M650VSE Full HD LED-LCD TV,...
Broksonic Flat Panel TV, tried to turn back on TV and Green LED light is blinking and screen pops up a few sec with white and colored lines and the turns off
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Oct 21, 2014 | Broksonic Televison & Video
The phone does not switch on.. when I press the not switch on.. when I press the power button, the Nokia logo shows with a small vibration as usual but then the screen starts blinking white a few times...
hi there!
try changing batteries. or try turning it on while charging, if theres no problem when its directly plugged in with the charger, the battery may be dead (especially if its more than a year old and is frenquently used for calls and internet). if its having the error while still plugged in directly with the charger, a local technician is the best here.
Apr 08, 2011 | Nokia X3 Cell Phone
We went to turn our TV on and when it turns on the Philips logo usually appears before it turns on. It is frozen on the Philips logo screen. You can't turn it off. And it will not go to the TV. I'v...
The standby power supply resistors on the inverter board have changed values. You will replace resistors R1217, (820K 1/4 watt), R1218,(820K 1/4 watt) and R1219 (390K 1/4 watt). Please use the values just mentioned. Or you may have the inverter board replaced. Take this note to a TV repair Tech.Thanks for asking and show a few hands of support!
Mar 12, 2011 | Philips 42PFL3704D LCD TV
The phone does not switch on.. when I press the power button, the Nokia logo shows with a small vibration as usual but then the screen starts blinking white a few times before switching off.
your phone got deads its happens many times when firmware is not properly updated,try to update your phone firmware but be care or send it to nokia centre
Sep 06, 2010 | Nokia X3 Cell Phone
LG 47" LCD shuts down several times w/ blinking red light.
Granger1212 we had the same problem. We called LG and although our LG was out of warranty by 4 months, we were asked to supply our proof of purchase and LG sent a serviceman to our home and in 2 days we had our television back working wonderfully. It's the power supply, call LG and BE NICE, I'm sure they will fix it.
Sep 22, 2009 | Philips 42PF7421D 32 in. LCD HDTV
Toshiba Laptop doesnt fully boot up!
Question, does it freeze while BIOS boot or operating system boot? try reinstalling operating system and or repairing (overwriting) the MBR.
Sep 11, 2008 | Toshiba Equium 100 PC Desktop
Philips DVD Player Seems Dead
It looks like this problem has been discussed here: "Standby light blinking."
Mar 24, 2008 | Philips DVP642 DVD Player
V3's External screen acting up, keyboard and displays turning off, phone doesn't let me perform any functions
this could be a firmware problem, though i have not known motorolas to have firmware problems.
Sep 08, 2007 | Motorola Mobility RAZR V3
Philips 47PFL7422D/37 Television Logo
133 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
