Question about Samsung LN-T4665F 46 in. LCD Television
I need the correct Settings for Samsung LNT4665FX to view the best picture
I bought the TV and hooked it up but the television is a little fuzzy looking and I want a sharper picture...can anybody help??
  • 179 Answers
Re: I need the correct Settings for Samsung LNT4665FX to...
These sets are designed for a digital input source, so if you are on an antenna or analog cable it will not look as clear..also if you can set the source for 720p instead of sounds like a lower resolution but 1080i scans 540 lines 2 times to get 1080i and 720p scans 720 line each time,,
Posted on Nov 30, 2007
0 characters
3 Points
I have purchased a Samsung Led 50 inches tv in USA, The picture is not displayed full on the screen. Can you please suggest?
These are generic instructions for all TV's and all Remotes:
1. Press 'Menu' key on Remote (or 'Setup' key).
2. Go to Setup, View, or Picture tab (whichever one you've got in your Remote's Menu or Setup)
3. Change your Zoom or View aspect.
NOTE: Depending on the dimensions of your TV, you simply may not be able to view the entire picture using a correct aspect ratio (NOT stretched). On my 42" RCA is use a 4:3 Zoom setting to fill my screen but, it chops a little bit off the top & bottom. It's the best I can do with my current setup.
Dec 17, 2014 | Samsung UN50H5203 - 50-Inch Full HD 60Hz...
Picture settings..? What are the best calibration
You can't use someone else's numbers, even for the same set, and expect them to be perfect. The picture settings are governed by the viewing conditions in your TV room.
Settings such as Brightness can only be set correctly in the room where you are viewing. Brightness affects where you might then set gamma, and contrast, and colour. So just one setting has a lot of impact on several other areas of the picture.
Putting in someone else's numbers will make the picture look different. But that's not the same as the "best" calibration for your TV.
If you want to do a good set-up without spending any money, have a look at your DVDs and Blu-rays for those titles with the THX Optimizer.
Sep 13, 2014 | Flat Panel Televisions
Clour is not good
modify display settings, use warranty or buy a better one.
Oct 22, 2013 | Samsung LNT4665FX 48 in. LCD TV
Philips 32 Ambilight PF 9986 TV Picture Problems - Fuzzy & Loss of Picture
What are you using for signal to the set? (Box?) and how are you connected? (HDMI?)
If HDMI try going Component
It may be the box/HDMI hook up causing the problem.
Mar 15, 2012 | Flat Panel Televisions
Its darker when the camera is father away.
this could be an auto picture feature not working correctly with the wide lens view you will want to go into your tv settings menu and make sure nothing is set to auto and than configure it so this no longer happens be prepared to spend about an hour getting familiar with each option so you understand which is doing what exactly
hope this helps
Apr 29, 2010 | LG 50PC1DRA 50 in. Plasma Television
Just bought the Samsung 550 Plasma Hd Tv can you tell me if we just use a regular cable from the wall to the Tv will the picture quality be sort of off.. WE have an HM MI cable from the cable box to the TV...
unfortunately cable does not give you the best quality picture and "fuzziness ' is the reduced resolution being displayed on the tv.
the easy way to check the picture quality is to get a decent hd antenna and scan using it for free hdtv signals, if these are also fuzzy, on all channels then the tv has a problem but if it is only on a few lower resolution channels then its just the way it is until everyone is hd 720 or better.
Jan 31, 2010 | Samsung 50 in. Plasma TV
Picture is fuzzy
Do you have a HIGH DEFINITION satellite / cable SERVICE? Unless you are specifically set up to receive HD - your picture will still be back around 400 lines - and both LCD and Plasma HD units are notorious for looking WORSE when viewing NON-HD PROGRAMMING.
Unless your DVD is capable up converting up to (pseudo) HD, don't expect much there either.
Not sure how the INSIGNIA is set up for inputs, but good old Wal*Mart sells a FANTASTIC UNIVERSAL REMOTE called AVEX that is an absolute JOY to program and work with - and it's only about $20!
Put a DVD in your player and turn it on and let it play. I doubt that you are actually looking for a "CHANNEL" - but instead an *input* that is electronically controlled by your tv.
Go to the "TV" position on your remote and find the "INPUT" button. Pressing it should bring up a menu of different inputs that your tv has. Use your center UP/DOWN button to switch inputs until you see your DVD playing through one of them.
Jun 19, 2008 | Insignia 37" LCD Flat-Panel HDTV
Best Picture Quality
The set may not be at fault. If you are on cable some channels are still in anolog and some are digital. if you are on a nolog channel the picture will look preaty bad compared to the digital ones.
May 09, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Snowy picture on certain channels and only sometimes
Hello, the best option for you is to put another (small) TV instead of plasma to check whether your cable is OK. If you need more info please advice. Arpi
Mar 16, 2007 | Philips 23PF5320 23 in. HD-Ready LCD...
Samsung LN-T4665F 46 in. LCD Television Logo
362 people viewed this question
Top Samsung Flat Panel Televisions Experts
xxxxxx xxx
Steve McIntosh
Level 1 Expert
Steven Wander
Steven Wander
Are you a Samsung Flat Panel Television Expert? Answer questions, earn points and help others
