good day sir!!!! this are steps how to connect your psp to wireless connection...
1.Turn on your PSP. 2.Enable WiFi by flipping the WLAN switch to the "On" position. 3.Select "Network Setup" from the main menu, then select "Network Settings" (press "X"). 4.Select infrastructure mode. 5.Create a new connection. 6.Select "Scan" to look for your WiFi network. Otherwise if you know all of your network settings, you can do it manually. 7.Select your WiFi networks SSID. 8.Enter your security settings (if applicable: WEP, WEP TKIP, Shared Key). 9.Select "Easy" in configure network settings to obtain an I.P address. 10.Confirm the settings. 11.Test the connection. 12.Go back to the main menu, select the broswer and enter a web address (e.g www.google.com) Your PSP's internet is ready to be surfed out wirelessly! The PSP, unless you have a hack installed, will not be able to browse sites such as Youtube, Facebook or Twitter because they require flash/java/enhanced memory (this is not the memory stick) it can however use Facebook mobile or Myspace mobile by typing in m.facebook/m.myspace.com.
You need to connect to each other wirelessly in ad-hoc mode. You've probably got them both set to infrastructure.
Here is a handy guide for connecting multiplayer on psp: http://forums.gameaxis.com/showthread.php?t=1459101
Hi you have to find a wifi access point not encrypted is easy wep is a little harder plus some people dont know about the switch that turns wifi off, near the memory card also the wifi board may be faulty inside good luck
If you installed custom firmware(psp hacked firmware 3.51m33 and up ) well you cant go to the PlayStation store sorry,but you can connect to wifi spots at the internet browser.
You need to have a WiFi network or be on a WiFi hotspot. If you are connecting to a secured network, make sure you get the passkey from the WiFi admin. If you want to setup a WiFi network at your place. You need to buy a Wireless router. Usually costs around $50-$60. This will share your internet connection wirelessly.
I have never seen this error code before! i will look into it to try help your problem!
The only code i know that comes any were close to yours is:
80410405 = Cannot connect to the given acess point
804xxxxx = A Wifi Error!
xx410xxx = Internal firmware/board error
