Question about Kodak EasyShare M1033 Digital Camera
I have the EASYSHARE M1033 Digital Camera
My camera turns on, Then shuts off right away. When I try to charge it, It will charge for one minute. But then says it's done. So I try to turn it on. But it turns right off again.
  • Bill Buchsbaum
    Bill Buchsbaum May 11, 2010
    Fixing your problem could be as simple as cleaning the battery contacts
    in the camera, or the solution could be a lot more complex and
    expensive. Here's a link to the Kodak Help Center - it provides a
    simple Q&A format to diagnose the problem and propose a solution.
    http://www.kodak.com/global/en/service/r...
Mine did this as well. I now have it plugged into my PC with the usb cord. I think the ac charger that came with the camera is not functioning. Try charging it from your PC.
Posted on Aug 03, 2009
Every time i turn my camera on it shuts itself right back off...i've tried charging it and that doesnt fix the problem....
hi;
try to use another new battery, i think its a power problem.
the current of the battery is poor to turn on the camera.
Oct 30, 2010 | Kodak EasyShare M1033 Digital Camera
Camera turns on, and then turns off again right away
My M1033 had the same problem...I found a blog about someone using air to clean around the lens area...I cleaned my lens very thoroughly and noticed some gunk and once I cleaned this off, the camera seems to work like new!
Apr 05, 2010 | Kodak EasyShare M1033 Digital Camera
Kodak M1033 lens comes out but will not go back
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 22, 2009 | Kodak EasyShare M1033 Digital Camera
When i turn on my camera, it shuts off right away. the battery is fully charged and it stills shuts off.
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Nov 21, 2009 | Kodak EasyShare M1033 Digital Camera
Camara shuts off as soon as it turns on. Lens
I believed that you are using the battery came from the box the KLIC-7004 which is very good. Now since the battery indicates its charge, first thing you need to do is to removed the battery and Memory card, Now wipe the 3 metal contacts of your battery then reinsert only the battery in your camera then Turn It On. If the camera shuts off try to used 5V AC adaptor to Turn On the camera, If this failed to turn On using the AC adaptor It means the camera needs of service call Kodak Tech support toll free 1 800 421 6699 ext 12
Nov 09, 2009 | Kodak EasyShare M1033 Digital Camera
My camera shuts off immediately after turning it on, and the battery is fully charged. what's the problem?
Take off the battery and the memory card
Try to wipe the metal contacts on battery with a cloth
Try to put back on to the camera with out the memory card
Try to turn it on
If the camera still have the problem
Try to take the battery out
Try to plug the charger directly on to the wall outlet then plug it in the camera with out the battery
Try to turn the camera on
If the camera has the same issue
Call the manufacturer
Aug 11, 2009 | Kodak EasyShare M1033 Digital Camera
I need to know of a service centre in mumbai, india
i have a kodak m1033 digital camera.yesterday while taking snaps heavy rain came. though i shutted the camera within two mnutes ,and taken further snaps after 15 minutes when the rain was over, but after two and a half hours from i am not been able to open the camera or charge the camera with the help of the charger. please help
Mar 29, 2009 | Kodak EasyShare M1033 Digital Camera
Kodak M1033 will not turn on sometimes unless you remove and then replace the battery.
when i turn my camera on it shuts off after 3 or 4 seconds and will not sray on
Mar 07, 2009 | Kodak EasyShare M1033 Digital Camera
Kodak EasyShare M1033 Digital Camera Logo
396 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
