SOURCE: I am looking for an owners manual for an MTD 5hp wood chipper mod
Try this site if you are sure you have model number right
SOURCE: I'm looking for the reverse belt routing.
Just take the old belt to a auto parts store and they can match it for you. If you dont have the belt take a piece of twine and put it around the pulleys
to make a template so to speak. Then take that to the auto parts store. Hope this is a FixYa. Pls rate the answer.
Kurt
SOURCE: No spark
If your engine is 11 years old it will have points @condensor under flywheel there are two wires coming from the condensor one goes to the coil and the other goes to a ground switch thats most of the time on the throotle linkage,if that wire is grounded against metal there will be not spark . the gap between coil and flywheel is 10 thousands (you can use an index card to set it .
SOURCE: 5hp briggs & Stratton lawnmower
ck fuel pump its on the side of the carb
3or4 screws hold cover on .
SOURCE: wiring on an old 5hp Briggs and Stratton engine
The "heavy wire" connects to the spark plug. It should have a plug connector attached. There are 2 small wires. One of them grounds to the engine block (probably through one of the screws that holds the magneto in place). The other wire goes to the condensor/capacitor.
