Question about HP Photosmart C7280 Laser Printer
Carriage jam I tried to take the paper out and some came out, I can't see or rich the other piece.
  • 724 Answers
Make sure the machine is shut off open the back exposing the paper transport drum
Posted on Aug 01, 2009
How to disassemble a Kodak ESP C110 printer?
Hello Edward,
There really is no reason to take it apart fully as the printer is showing classic signs of a paper jam. Usually it is a small piece of paper that has torn off and is lodged in the printer's paper path, it also could be something small such as a paper clip. Yours obviously is located on the side that the crease appears. The paper feeds in and then it hits the stuck object, then jams. Look very carefully at the leading edge of the paper near the crease and it may show the exact location of the foreign object. in the paper path. Remove the object and you should be all set!
Good Luck!
Rich Lilja
Mar 01, 2015 | Kodak Office Equipment & Supplies
Panasonic KX-P7110 printer won't print from the auto feed tray, shows error when printing is attempted.
Please check the entire length of the paper feed path from input to output for a small piece of paper that is stuck causing a "Paper Jam".
You are lucky that you can still print manually as this usually shuts a printer down until the jam is found and removed!
Good Luck!
Rich Lilja
Jan 06, 2014 | Panasonic KX Office Equipment & Supplies
Load legal message
You will need to go into the printer's settings and change the tray 2 paper size back to letter. This printer is an oldie and does not rely on the paper tray to tell it what size paper the tray contains. Another possibility is that If your program is sending a print job (which will over-ride the printers settings) that somehow is set up as legal, then you will need to either abort or cancel the print job on the printer or install a legal size piece of paper into tray #1 (the manual feed tray) and then press GO or CONTINUE on the printer to complete the print job!
Good Luck!
Rich Lilja
Oct 28, 2013 | HP LaserJet 4 plus Printer
Printer is not print properly & paper jam problem. how repair the printer &how to troubleshoot the printer &how check out ,which part have problem.
When you removed the jammed paper, did the paper come out inone piece, if not did all the pieces that were removed make up the entire sheetof paper?
Otherwise there may be still a small piece/s of paper still in the printer,which is causing this error message.When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper.The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Nov 28, 2011 | HP Office Equipment & Supplies
I have a paper jam. Some of the paper is still stuck in the rollers. Machine said to open back door. I did and can see the pieces of paper but when I try to pull them out with a pair of needle nose...
HI, Try to roll gently and slowly the paper roller and pull the piece of paper in the same time. Grab the piece of paper close to the roller to prevent tearing. Good luck!
Mar 03, 2011 | Dell 5210n Laser Printer
My hp 7400 displays a message carriage jam
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
Sep 20, 2010 | Office Equipment & Supplies
"carriage jam. Open door. Clear carriage jam, then press okay" error keeps repeating... tried everything still no change...
Sep 01, 2010 | HP OfficeJet 6210 All-In-One InkJet...
The paper feed is screwed up. We tried printing on paper that had already been fed through the printer and a piece got stuck. We think we got that all out but can't be sure b/c we don't know how to fully...
The chances are you have a piece of paper blocking the paper path.
Try tipping the printer with the paper input upside down to see if your can dislodge the offending piece of paper.
Next, try taking a thick piece of paper (double weight or construction paper) and feeding it through to see if you can push the offending piece of paper out.
If these do not clear the problem, let me know and we can look at partially disassembling the printer to clear the path.
Please rate this solution. Thanks.
Aug 30, 2010 | Canon MX700 Office All-In-One InkJet...
Started with paper jam and then after that. Error message. Carriage Jam, print carriage access door. Clear and press ok. can't figure out what this means
http://www.fixya.com/support/t5821600-carriage_jam_open_door_clear
Aug 20, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
HP Photosmart C7280 Laser Printer Logo
44 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
