Question about Frigidaire FAS256N2A Air Conditioner
Makes loud noise while cooling. sounds like fan is hitting something. a/c is 4 years old, in the wall, problem just began July 2009. Lowering fan speed, or energy saver setting do not help.
That's because it probably is.Shut it off.Pull it out.Set it on a table by the outlet or a/c housing.Plug it into the same outlet.Keep fingers away from the blade and visually watch it.
My guess is the fan blade loosened on the shaft and needs to readjusted and tightened.Or the wires need to be moved out of the way of the blade and tie down(not on the fan blade either foo!!!).
Posted on Aug 02, 2009
My samsung fridge/freezer is only 3 years old, just started making loud noise, then when the fridge is opened sounds like the fan making a loud noise that goes down and stops. Then not long after that...
Compressors usually make a thrumming/humming noise, so yes, this sounds like the fan. It could be something touching the fan blades, like ice or a wire. If you can unplug the fridge and remove panels near the fan, you may discover the problem.
Jun 06, 2012 | Refrigerators
I have a Dell inspiron 1525...I have found that now, after a year and half the fan has become loud and noise. So noise, I wake up in the middle of the night, hearing my computer cooling b/c the fan is so...
you need to buy a new fan, your fan is about to give up the ghost. if you let the fan die while the pc is running, it might burn out the cpu.
fans are very cheap, like a few dollars, and do not always last forever.
Nov 06, 2010 | Dell (6F858) Cooling Fan
Traeger junior 2 weeks old dosen't seem to make loud fan noise when starting up , seems like during grilling last night made funny noise like bad bearing or something cleaned grill empted fire pot and...
Take and unplug your electrical cord and then take the bottom grate that covers your motors and components off. The are 4 small screws and then it should drop down. Look to see that there are not any wires hitting your fan motors. You can just reach up there and move them around if they are. Some Treagers seem to have some noise until you use them a little. They have a 3 year warrenty, so if the wires are not hitting the fan blades, I would use it and see what happens.
Apr 15, 2010 | Grilling
When the fan runs it sounds like something is
Replace the fan. Probably bearings in fan are failing.
Nov 15, 2017 | Avanti (BCA5105BG) Beverage Cooler
Fridge making loud noises occassionally
the noise can be from the fan next to the compressor or the fan in the freezer.
check them when you hear the noise if they tuch something or they might need to be replace b/c of berring problems...
Jan 06, 2010 | Refrigerators
Hi I have a GE Fridge Model Number GTS18HBSW and it just started to make this loud noise. seems like it is coming from the fan or back of fridge only 3 years old. Any suggestions
Any noise in the fan needs to be corrected soon. It could be something trapped there or it could be something is wrong with the fan or the fan blades. To lose the operation of that fan will stop cooling and chance damage to the compressor from over heating. I recommend that you unplug and pull away from wall. Remove cover that covers compressor and fan and find what is causing this to prevent further damage. Let me know what you find and if you need additional help please let me know, Thanks, Sea Breeze
Aug 26, 2009 | GE GTS18HBSWW 28" 18.2 Cu. Ft. Top-Freezer...
Loud rattleing sound
If this AC is a thru walled, since it is new it is better to inquire to the people where you buy this unit, for this type of problem. They must have some authorized repair man/shop or, use its product warranty.
The problem could be also uneven placement of its base. This could maybe hitting the fan guard, some loose connection or some foreign object left that's hitting something inside.
Jul 31, 2009 | Kenmore 75085 Air Conditioner
Loud Buzzing Sound
Sounds like the cooling fan blades are hitting something (possible worn bearings).
Apr 21, 2008 | RCA P52926 52" Rear Projection Television
Frigidaire FAS256N2A Air Conditioner Logo
294 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Donni Steen
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
