Question about Cell Phones
My new omiz bluetooth won't pair with my palm trio
  • 6 Answers
SOURCE: how do i pair my sanyo bluetooth with my palm pre?
hld dwn button till long lite pair while lite on den power bluetooth off usually # is 1234 or 0000
Posted on Mar 05, 2010
Beni S-P
  • 1006 Answers
SOURCE: Software upgrade makes bluetooth unworkable
I think this can help you:
Treo 650 only
A zero out reset will regress a device that has non-volatile memory to its factory-fresh state. When done correctly, it completely rewrites your device's internal memory with zeros and ones, ensuring that any data is expunged. It should be used only if you want all information completely obliterated (example: you're selling your handheld, or you're sending it in for repair, and want to protect your privacy). Tungsten E2 note: a hard reset (above) produces the same results as a zero out reset - completely rewrites data on internal memory. No need to perform the steps below. Warning: A zero out reset will erase everything on your device. All your data will be removed, and formats, preferences and other settings are restored to their factory default settings. Don't perform a zero out reset unless you want to eradicate everyting.
spacer.gif HotSync note: Some third-party applications change the way your device backs up data. Other third-party applications do not back up data. If you have third-party software on your device, please contact the developer to learn what components are backed up during a HotSync operation, and if HotSync conduits are altered. Any data not backed up will be lost.
There are two ways to perform a zero out reset.
  1. Read through these instructions before attempting the reset. We made this method of zero out reset extremely awkward to perform, so that it would not happen by accident. You may need the help of a dextrous friend if you find it too difficult to do by yourself.
  2. Connect your device to its HotSync cable or cradle. The HotSync cable does not need to be connected to your PC, and it does not need to be connected to power.
  3. Press and hold the Power button and UP on the 5-way navigator.
  4. While continuing to hold Power and UP, press and hold the HotSync button on the HotSync cable or cradle. As you press HotSync, make sure your other finger doesn't slide to LEFT or RIGHT on the 5-way navigator; it needs to be exactly on UP during the entire process. Although you are pressing the HotSync button, a HotSync operation should not begin.
  5. While continuing to hold Power, UP and HotSync, press and release the RESET button on the back panel of your device (where's the reset hole?). This is very difficult to do with only one person; you may wish to hold the stylus in your mouth and use your hands to press Power, UP and HotSync.
  6. Release Power, UP and HotSync.
  7. If you did this reset correctly, the screen of your device will go blank, and you will not be able to turn it on. The charging LED will not light up, even if it's connected to power. It will appear to be "dead." (any other activity — such as the Palm OS logo or a rainbow-colored Boot Log screen appearing — means the reset was performed incorrectly; try again)
  8. Your device will appear "dead" for several minutes (up to 10 minutes). During this time, your device's internal memory is being reformatted. If your device doesn't appear "dead" for several minutes with the screen completely blank, the zero out reset was performed incorrectly; try again.
  9. After several minutes, your device will "wake up" and the Palm and Palm Powered logos will appear as if you had performed a hard reset. Eventually, you'll be taken to a series of screens to calibrate the touchscreen and set date & time.
  10. If you want your handheld to remain in factory state, stop here. If you want to restore data to your device, follow the steps for recovering after a hard reset (a zero out reset is a special type of hard reset).
Quick Erase, Secure Erase
LifeDrive only When you perform a hard reset on a LifeDrive mobile manager, you will see two options on the reset screen: Quick Erase and Secure Erase. Both of these are types of hard reset. Quick Erase: Perform a Quick Erase reset for a regular hard reset, to get your device to wake up and respond again. This eliminates user information on the drive in such a way that there is no info available to anyone using the device. A Quick Erase reset takes approximately 5 minutes.
spacer.gif spacer.gif spacer.gif Secure Erase: Perform a Secure Erase reset if you are turning the device over to a new owner. A Secure Erase helps prevent your files from being restored or recompiled by a new owner who might remove the hard drive and use a drive reader to access your information. This completely deletes all user info on the drive. A Secure Erase reset takes about 30 minutes.
Note: If you use a password to protect your device, you must do a Secure Erase when you hard reset your device; the Quick Erase option does not appear on the reset screen.
  1. Slide the power switch to the right and hold it in that position.
  2. While holding the switch to the right, use the tip of the stylus (or a similar object without a sharp tip) to gently press and release the reset button on the bottom of your device.
  3. Wait for the reset screen to appear (it will say "Warning, Erase all data?"). Then release the power switch.
  4. Choose your type of reset:
    • Press Up on the 5-way navigator to perform a Quick Erase (5 minutes)
    • Press Down to perform a Secure Erase (30 minutes).
  5. During the reset process, a status screen appears with the words "Quick Erase" or "Secure Erase" and a progress bar, followed by screens showing the Palm, Palm Powered and LifeDrive logos.
  6. Then you will be prompted to tap the screen to align the digitizer and select the language you want to use on your device. A screen appears showing the Palm logo and a progress bar.
  7. When the "Welcome: Setup your device" screen appears, the hard reset is complete. Follow the onscreen instructions to set up your device.
Posted on Nov 10, 2007
SOURCE: Bluetooth pairing with Lexus
Try using the following code: 0000 on the Palm Treo and your car's device. It worked for my BMW 328i
Posted on Dec 12, 2007
  • 65 Answers
SOURCE: I can't pair my h700 bluetooth to my Palm device
Depending on the phone... try and remove the currentbluetooth device. Close the headset. Go to the phone and choose discover, or search. Open theheadsetand press and hold the big button. It should then turn purple and should be recognized.
Also make sure thebatteryon theheadset is charged before doing this.
If this doesntwork: Start the search onthe phone, Keep the boom of the mic closed when you press and hold the buttonon the h700. the light should turn purple. After this, open the boom
The passkey will be 0000, four zeros.
Posted on Jul 30, 2009
  • 65 Answers
SOURCE: Light won't stay purple even when boom closed & button held
Depending on the phone... try and remove the current bluetooth device, if there is any. Close the headset. Go to the phone and choose discover, or search. Open the headset and press and hold the big button. It should then turn purple and should be recognized.
The boom should be open when you press the button.
Also make sure the battery on theheadset is charged before doing this.
Posted on Jul 31, 2009
Jwin headphones won't pair with HTC Shift Droid
You have to pair it initially. to do this the headphone must be on discover mode(pairing enabled mode for detection). then only it will be show in the Phone.
Jan 30, 2012 | Jwin Electronics Stereo Bluetooth...
Palm Treo and Jabra bluetooth headset
Turn your headset off. Then, press and hold the answer/end button until the indicator light is solid lit in blue. It is in paring mode. Now, make your phone's bluetooth application search for new devices. After a while, the BT-350 should appear on-screen. Select it and command the application to proceed. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing proces is successful, the headset should enter stand-by mode. The pairing process is timed.If you fail to complete it, you'll have to start it over, from the phone turned off phase. Once paired, whenever both your headset and your phone's bluetooth radios are turned on, they should connect to each other automatically. Otherwise
Hop
May 16, 2010 | Jabra BT350 Bluetooth Headset Headset
My Treo 755p will recognizes my new jawbone but will not connect. It seems to skip the step where I am supposed to enter a password into to connect to the jawbone. Any ideas? Josh
Delete any other bluetooth devices paired to your phone. Then, for the Palm Treo 755p . . .
To pair the Palm Treo 755p handset with the Jawbone, perform the steps listed below:
  1. Set the Jawbone to Pairing Mode.
    • For the Original Jawbone, press and hold down the Noise Shield button for at least three seconds until the LED Indicator Light flashes red.
    • For the New Jawbone, press and hold down both the NoiseAssassin™ Button and the Talk Button for at least three seconds until the LED Indicator Light flashes red and white alternately.
  2. Press Applications and select Bluetooth.
  3. Select Bluetooth On.
  4. Select Setup Devices.
  5. Select Trusted Devices.
  6. Select Add Device. (The Discovery icon appears, indicating that the discovery process is active.)
  7. Select the Show pick list and select Nearby devices.
  8. Select Jawbone from the Discovery Results list, and then select OK.
  9. Enter the PIN "0000" (be sure you are entering four zeroes and not the letter "O".) and select OK.
  10. Select Done, and then select Done again to return to the Bluetooth screen.
Your phone should now be paired with the Jawbone.
Jan 26, 2009 | Palm Treo 755p Smartphone
Forgot how to par my bluetooth PLT 510 to my Palm Centro
To pair with a Bluetooth device:
  1. Make sure the device's Bluetooth radio is on.
  2. Set the handset's Bluetooth discover mode to On.
  3. Select the appropriate Bluetooth accessory.
  4. Enter your PIN number.
Once a Bluetooth accessory has been paired with the device, it can be used with the device, without the need for re-pairing, assuming the appropriate profile exists for the required service.
Sep 16, 2008 | Plantronics Lands Phones
Palm TX, Dell 6300 Laptop, can see each other through Bluetooth but will not connect. Want to connect to sync clocks.
Have you checked your hotsync settings and bluetooth settings to make sure that you are using bluetooth sync and not the serial connect. Palm devices can also share LAN/Internet over bluetooth.
Jul 18, 2008 | Apple iPhone 3G
Pairing a AtivaBT220 to a palm treo 755
Make sure both devices are turned on.
Do a search for new devices with the phone, it should find all devices in range. Select the device you want the phone to pair with. Use 0000 as a password.
Feb 29, 2008 | Palm Treo 750 Smartphone
How do I get to "Pairing Mode"
I have a new Sony ERicsson Z310A phone I just replaced the old one the bluetooth icon is visible on the phone but when I try to turn the blue tooth on it tells me bluetooth device not found
Jan 08, 2008 | Palm (3206WW) Wireless Headset
Nov 11, 2007 | Palm Treo 700p Smartphone
Cell Phones Logo
201 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
