Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
DD603 upper drawer pump rotor will not turn - F2 error. Was completely siezed. Removed rotor and got the shaft to turn with pliers. However it does not spin freely and still shows an F2 error. Does anyone have a repair manual so I can figure out how to remove the pump? Lower drawer had an F1 error (due to the upper leaking/F2 error) and this website helped me fix that problem.
Maybe you dont have to remove anything else.. try the rotor from the bottom drawer first. If this works just buy a new rotor..
Posted on Aug 05, 2009
Fisher & Paykel Dishdrawer: DD603: Have had motor & rotor assembly replaced - now F-2 code here is goes again. Determined to have husband fix it!! I hope. Company says it is an issue with the...
Hi - F2 error code indicates a failure of the rotor/motor or the sensors, the following notes should give you guys something to check and see which of these has failed..
Error Code - F2
Which LED - Delicate LED
Reasons - The motor has not been sensed rotating
Likely Causes
_ Foreign object has jammed the rotor
_ The rotor has failed
_ The hall sensor has failed
_ The electronic controller has failed
Aug 19, 2011 | Fisher and Paykel 24 in. DD603H W Built-in...
Hi I have a DD603 F & P dish drawer. I had an F2 fault, found the rotor motor seized. I've replaced that but F2 still comes up & the water doesn't drain away. Any ideas?
Before we talk about water not draining away, can you confirm if the wash arms rotate during the wash cycle. The rotor works as a wash pump and drain pump depending on which cycle it is in.
If F2 keeps coming then it is also likely there is some debris in the rotor cavity which is grinding on the rotor. But one needs to be sure if F2 is coming up only in drain cycle or is it already on during wash cycle.
May 16, 2011 | Fisher and Paykel 23 in. DD603H SS...
We have the error F2 showing on our dish drawers
normally the F2 showing on both drawers is unusual.
It is a rotor fault. Which means either the rotor that drives the wash arm and also works as a pump is either faulty or there is some rubbish stuck in the rotor cavity.
Lift the fiter plate out and open the rotor ring. Get the rotor out and inspect. If it looks ok or there was no noise when the F2 error showed up then the hall sensor mounted on the underside of the drawer is faulty.
The hall sensor can be hard to replace unless one has good experience in repairing dishwasher.
Nov 27, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Leaking fisher & Paykel DS603 Dishdrawer
i think there is a hole in the grey sump underneath rotor motor, the motor is the grey blades u took out of sump. pull out drawer, take filter tray and rotor motor out of drawer, dry all of water out of drawer , then look underneath unit , pour a little water into drawer and see if it is leaking past motor windings . if it is then there is a hole in the sump. if it doesnt leak from there try looking at the little black drain hose. please turn off power b4 u work on dishwasher do not want any accidents . please reply 4 more help.please tell me what u find. good luck
Apr 09, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F2 code. Followed listed guidance of removing assmebly and checking...unfortunately, however, my impellar has separated from the rotor assembly and the rotor assembly is stuck in the drawer. I tried to...
There are no wires underneath the rotor - it is just suspended in the cavity. So you cannot do any damage except make scratches around that area. Maybe take a straightened wire coat hanger and insert from the side hole in the filter sump area. You might be able to push the rotor up to an extent and then grab it with pliers.
Nov 02, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
I am getting an F2 error code on an DD603.
there is something jamming in the rotor , lift the spray arm and try spinning the blue fan , or if u havent used the btm drawer in ages it is a seized rotor , around 80 $ to buy new
Oct 27, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishdrawer model DD603 gives fault F2 (Motor). Unit has only been used a few times. What to do? Out of warranty.
Ok this is what you do you need to swap over the motor rotors from top drawer to bottom drawer. check for anything jammming the rotor etc when you take it out. if it works with the other drawers rotor then you need a new motor rotor. cheers
PLEASE GIVE ME FEEDBACK
Mar 25, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
F2 flashing on lower drawer
F2 means "motor not sensed to be rotating"
You said "very rarely used" also. The two go hand-in-hand in most cases. If you leave the drawer sit unused for months and months, this can ruin the motor rotor. The rotor comes out with no tools. Remove the dishrack, the wash arm (both simply lift off) and then the stainless steel filer/cover. This is removed by rotating the collar counter-clockwise and lifting it up. Now rotate the collar for the rotor counter-clockwise and lift the motor rotor out of the pump base. See if it spins freely. it;s probably frozen. You also can try swapping the rotor from the upper drawer into the bottom and see if that will work for you. if the rotor is bad, it is a part number 525884P and you can get them here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=231
If you find this info to be accurate and correct, please rate my answer as a FIXYA.
Thanks...
Feb 01, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Water pump on F&P DD603
behind the bottom drawer taped on back wall of inside of unit is atech sheet, with a pretty good troubleshooter. to remove the drawer push in rectangler hinge locks in hte bottom front corner of drawer front, just below the circles(no noeed to remove the circles)push themin and slide back the drawer will lift off and your able to set it aside(wont come out to far its connected by the hoses but itll come out enough(reset the door unto the hinge slides and pull hte lock latch foward to lock back into place
Feb 28, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
520 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
