Question about Sanyo Televison & Video
Warning light comes on, tried unplugging and still doesn't work . Had it serviced 2 weeks ago, had new fan installed, lamp and lamp blaster are ok they said. Help
  • 585 Answers
Check the lamp seating switch and lamp door switches to make sure they are aligned propely
E
Posted on Aug 01, 2009
Suddenly, No tail lights, brake lights, turns signal or back up lights At 83000 miles, 6 months ago, replaced head gaskets. 1 week later, service engine soon light came on. Tech said it was an oxygen...
just look for the blackened/burned pin on the rear light plastic connector and sand it down to re-establish a good electrical connection and save yourself $800 big ones on replacing the multiswitch.
Jun 26, 2011 | 1999 Chevrolet Venture
6 months ago, replaced head gaskets. 1 week later, service engine soon light came on. Tech said it was an oxygen sensor. Cleared code. 3 weeks ago, got oil change, replaced headlights and replaced...
CHECK TURN SIGNAL FUSE.IT COULD BE BLOWED OR YOU HAVE FAULTY TURN SIGNAL SWITCH.BECAUSE BACK LIGHTS AND TAIL LIGHTS SHARE SAME CIRCUIT WITH TURN SIGNAL SWITCH.
Samsung HLN5065W will not start up. Goes through 3 cycles and then lights in center circle blink. A new lamp was installed 2 months ago and it worked fine. The first time it didn't start-up, I unpluged...
Ballast Board ,it connects to the Lamp which is what Powers Lamp on.
First check all fans Lamp fan,ballast fan,DMd Fan, if they are OK then replace the ballast Board.
Encompass Parts Distribution 1-800-638-3328 Go to their website they have Free Service Manual
that you can print out for this Model.
Jan 20, 2011 | Samsung HLN5065W 50" Rear Projection...
Just replaced lamp a week ago and tv worked fine
2 things will cause this Lamp is defective, or Fan to lamp quits running this will shut TV OFF, if the fan quits running while Lamp is on it is design to shut Lamp Off to prevent Damage to Lamp IF Fans are ok It will be the Ballast board It is what turns Lamp on.Look on E-Bay for Ballast board if it turns out thats what you need or call Encompasss Electronics 1-800-638-3328
Sep 19, 2009 | Toshiba 62HM95 62" DLP HDTV
Replaced color wheel
OK, THIS TV HAS BEEN A DOG,IT seems the light engine was going bad to start with so it is a good thing i diidnt replace :LAMP,or Balster,New Color wheel is working,But with BAD Light Engine Lamp will not longer come on either!
Jun 11, 2009 | Samsung HLN5065W 50" Rear Projection...
Panasonic PT43LC14 wont turn on
hi sir im tech in electronics ,if you go to change the lamp for another check the fan that is running cool sounds like the fan does not refresh the lamp and it burn again .
Jan 11, 2009 | Panasonic PT-50LC13 50" Rear Projection...
FFA60 Hotpoint fridge/freezer Red warning light
if i read the english right, the compressor runs but the freezer fan only runs for a short time. no fan then no cooling. there is a fan stat so that the fan only runs when the evap is down to temp. this may be faulty. also on some hotpoint, the fan switches off when door opened. check door switch operating ok. this may also explain problem with fridge lamp
Mar 11, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Televison & Video Logo
32 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
