Question about Moen Plumbing
The handles for my bathroom faucet are loose inside. They wobble inside the mechanism. I have unscrewed the handle itself but I don't see how I can remove the mechanism the handle screws in. I believe if I could get inside it I could tighten whatever is loose.
    President:
  • 1,273 Answers
Hi, There should be an easier way here. With the handle off, look down along the valve stem to where it goes on into the valve body. You should see a six-sided nut surrounding the valve stem. This nut is the packing gland. It allows the valve to function without leaking. You should be able to tighten the packing gland and take the wobble out of the valves. It's a trade off though, the tighter tha packing gland, the less the valve wobbles, but the valve will get harder to operate. You'll have to make your own judgement call as to how tight you want it.
Best regards, --W/D--
Posted on Aug 01, 2009
  • woobie dog
    woobie dog Aug 02, 2009
    There is a nut past the packing gland nut I previously referred to. If it your aim to get all the way into the valve, you'll need to unscrew this nut. It is really the upper part of the valve cartridge. When you pull this out, you'll have access to the stem, washer and packing gland. You'll need a thin-walled socket to fit in the hole around the valve unless you have a lot of room. They are available as a set at Lowe's/Home Depot/similar, for ~$15. The packing gland adjustment is still your best course of action, if the valve is only wobbling. Regards again, --W/D--
Replacing the handle adapter on a 4-inch moen monticillo bathroom faucet. Can't get the handle hub to unscrew with a strap wrench. tried using lime away to cut the 15 years of crud around the handle...
Sometimes there is a small set screw located on the handle.It takes a small allen wrench to loosen it.That should enable you to remove the handle assembly.
Jun 03, 2011 | Moen Bathroom Sink Faucet - 4-inch...
HAVE MOEN MODEL INS792A WIDESPREAD 2 HANDLE BATHROOM FAUCET - LOOSE HANDLE ON LEFT SIDE - KEPT INSTRUCTIONS (PICS ONLY) - CAN'T FIGURE OUT HOW TO TIGHTEN LOOSE HANDLE - HELP??? THNX!
There is a cap on the top of the handle which can be removed by popping it out with a knife or a small flat tip screw driver. Inside you will see a screw which holds the handle to the faucet. Tighten this and replace handle cap.
Sep 01, 2010 | Moen & Villeta Two Handle Lavatory Faucet
Glacier Bay bathroom faucet - 2 handle leaks
see if the housing itself will unscrew
Jun 06, 2010 | Garden
Have a 4 inch center moen that has solid handles with a decorative piece on the bottom. How do I remove the handles?
if it is like your picture then you have a monticello faucet. The handles unscrew. The ball looking part of the handle unscrews just like you are loosening a nut. Then you will be able to get to the cartridges,
Apr 10, 2010 | Moen Bathroom Sink Faucet - 4-inch...
Handle is loose water flow weak
to tighten handle, you hold lever(top of handle) while unscrewing round piece below, entire assembly should come off.look down and should be screw down there, tighten it up. flow problem could be the areator, unscrew and clean if need'd. check supply tube's,shut off valve's, (if you have them)make sure they are wide open.
Mar 22, 2010 | Moen Bathroom Sink Faucet - 4-inch...
Ihave a two handle Moen bathroom faucet that the right handle came off showing a broken plastic part inside, how do I get the broken part out?
There is a little cap on the top of the handle, after removing in there is a philips screw under that and that will release the broken plastic part.
Mar 18, 2010 | Moen Kingsley Two Handle Bathroom Sink...
Bathroom faucet drips, I can take the handle off but I can't figure out how to pull the rest of it out to get to the washer. Its a two handle faucet. Some have a clip to pull and then slide it out but...
If it has ceramic cartridges you will need to replace th ecartridge that is faulty.
If it has washers then it should unscrew out of the body of the faucet. Look for any nut that requires a spanner to unscrew.
Jan 08, 2010 | Moen Bathroom Sink Faucet - 4-inch...
The handle is loose and wobbles
Pry out the red / blue plastic piece in the front and tighten with an ALLEN wrench.
Jan 03, 2010 | Dishwashers
Reinstalling a handle on an older Moen 84206
Here is the owners manual for your faucet that will guide you through putting the handle back on. Good luck!
http://www.moen.com/shared/pdf/instruction_sheets/INS060B.pdf
Apr 06, 2009 | Plumbing
Delta faucet is loose ;moves right-left/wobbles. Tightening?
Try tightening the allen set screw behind the spout "you need a special (allen keys) to do this, and one should have came with your faucet". You can also buy or borrow an set of them.
http://www.efaucetscomplete.com/SpecSheets/T2755CBLHP_Install.pdf
Copy and paste this to your address bar for directions.
Jan 30, 2009 | Delta Victorian T2755-NNLHP Bathroom Roman...
Plumbing Logo
393 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
