Model: UA43J5100AKXBG Version: DD01. It starts flickering since last 1 month. Ancreasing the rate of flickering day by day. Earlier after 15-20 min flickering stops. But now it takes 80-90 min to stop flickering after TV starting. I have checked there is no jamper like 852 or 854. The only cloae one is JP 855. Should I cut it? Any other suggestion? Regards, Anwar
  • 2 more comments
  • Nurul Jewel
    Nurul Jewel May 21, 2018
    Dont find KBJ6J (6A, 600 V) rectifier. D3SB60 (600V, 4A) is available is it usable as alternative?
    60R580P regulator also not available.
    Please suggest a list of alternative rectifiers for KBJ6J and alternative regulators for 60R580P. It will be a great help for me.
    Thanks in advance.
  •  Russ Hill
    Russ Hill May 24, 2018
    2sk3451-01MR would replace 60r580P. GBK25D should be fine replacing it from KBJ6J its 200v 25a
  • Nurul Jewel
    Nurul Jewel May 25, 2018
    # Can I use 2sk3451-01MR only with existing KBJ6J?
    # Or I have to use 2sk3451-01MR in combination with GBK25D?
    # I can order 2sk3451-01MR and D3SB60 / D25SBA80 from available sourcehttp://bdspeedytech.com/
    Please advise.
  • Nurul Jewel
    Nurul Jewel Jun 03, 2018
    I have replaced both the rectifier diode and the mosfet. Still problem exists neither improved nor become worst. Please suggest if you have any. Could be panel issue?
  • Televison & ... Master
  • 4,033 Answers
If the board does not have jp854 top left of the power board 2 inch down it's not the same power board as the quick fix. also it's not really a quick fix, you need to replace the voltage regulator on the heat disperser, right pin on the 3 pins is the controller for the voltage when the chip wares out it cannot regulate the correct voltage so the voltage goes up and down causing the flicker, on the quick fix its just cutting this connection off so the regulator is working at no adjustable voltage.
Posted on May 07, 2018
  • 3 more comments
  • Nurul Jewel
    Nurul Jewel May 08, 2018
    Thanks for the quick reply.
    But I could not really recognige the voltage regulator. There is a small black square shape device with three pins screwed on aluminium like metal piece (possibly heat disperser). If it is voltage regulator then I have to remove or cut the right pin looking from pin side, right?
    If it fix flickering problem then I have to replace this black square shape device for permanent solution, right?
    Thanks and regards,
    Anwar
  • Nurul Jewel
    Nurul Jewel May 10, 2018
    Please reply.
  •  Russ Hill
    Russ Hill May 10, 2018
    hi sorry i did reply but was not on account as been away. i would need to see the board, or at least have the board number. it will be printed on the board. and don't cut the pin as this will not work as its also a earth.
  • Nurul Jewel
    Please see the attached power board picture. Additional information: now tv flickering remain forever, not fix after some time from switching on.
  •  Russ Hill
    Russ Hill May 11, 2018
    arh right ive not seen this board before but its a simple system, you have a bad voltage regulator and a faulty bridge rectifier. this will case a voltage pulse. if you check the voltage with a meter it will be pulsating on the voltage. if you cannot find the rectifier for the voltaged if you give me the number there are alternatives. same for the bridge rectifier. there are a number of voltage rectifiers. from 1 to 5 amps and adjustable voltage thought pin 3 on the type you need. bridge rectifiers need to be the same fitting i.e left pin - right pin + and vice versa. mians is the middle unless stated on the chip. the diode above the middle transformer will probably need replacing to as this would be for the transformer.
  • 26 Answers
SOURCE: Flicker-Blinking on picture
Too late now but I hope you had it serviced while it was still on parts warranty. With a couple of exceptions, service on those is by major pcb replacement.
Posted on Oct 07, 2007
  • 149 Answers
SOURCE: bad picture
Sounds like a dry solder joint. When the tv is on for 4/5 mins the crack warms up and the gap spreads. When you turn off it cools and when it warms up it starts again.
Posted on Mar 18, 2008
SOURCE: AVOL 15" TV/DVD
i just got a new avol tv and sound is not working i tryed everything but wount work
Posted on Feb 11, 2009
  • 11800 Answers
SOURCE: I have had my Timex
The heart rate is recorded at these abnormally low levels because the sensor has lost its sensibility. This can be caused by only 2 things:
1 - the battery for the watch is almost dried and its voltage has dropped so low that the sensor can't work no more. You will have to replace the battery. because your watch is a sealed type you should take it to a repair shop: they will know how to open it carefully enough as to not damage the rubber seals.; and if they can't open it without damage they will have replacement rings.
2 - the sensor itself (which basically is just a microphone that listens to the beats) is clogged by dirt. Wash the watch in hot soapy water and look very carefully for cracks in the rubber of the strap - if you find one then the sensor has been permanently damaged by the sweat that seeped in. In that case it's time for a new one.
Posted on Dec 15, 2010
SOURCE: i bought philips model no. 47pfl7403d/27 in 2008
Seal deal w/ ours. I took it apart and the power supply board had the burn marks on it. Just ordered another power supply board (pn: 272217100571) for ~ $100. TV back panel comes off fairly easily to get at boards.
Posted on Jul 12, 2011
Cannot set time @ date for Ohsen watch...AD0721...thanks
(A=LIGHT,B=MODE,C=START,D=RESET)
1.How to use the luminescence Any time indication,Press A the Luminescence will last for 3 seconds.
2.How to view date? Standar time indication, press C "month/ date" indication.
3.How to switch 12/24 hour systems In the normal mode, press B twice and press D twice ,then hold C until 24 hour system is actuated, then press B for recovering.
4.How to check alarm ring and alarm time? Standard time indication,press D alarm time indication.
5.How to set alarm time? Standard time indication,Press B twice. The hour area flickers,press C to set the hour. After setting hour ,press D,the minute area flickers, press C to set the minute. Last press B for recovering.
6.How to set alarm ring? In standard time indication mode ,Hold D then Press C this will toggle alarm symbol on & Off.
7.How to set Hourly Chime? In standard time indicationmode, Hold D then Press B DAY OF WEEK area toggle on and off.
8.How to use stopwatch(1/100 seconds) Press B,then Oress C for 1 timing; Press D for multiple timings. Press D once more to continue operation after multiple timing. Press D for 1 timing; press C once and press Dtwice for multiple timing. (1)Max range of the stopwatch is 23 hours 59 minutes 59 seconds. (2)When timing within 30 minutes, the watch indicates: minute/second/1/100 second (3)When timing beyond 30 minutes, the watch indicates:hour/minute/second
9.How to adjust time, date,day of week (1)Standard time indication,press B twice ,the second area flickers, pressC to adjust second. (2)Then press D the Minute area flickers,Press C to adjust minute. (3)Press D the hour flickers, press C to adjust hour. (4)Press D the Date flickers, press C to adjust date. (5)Press D the month area flickers, press C for adjustment. (6)Press D the Day of Week area flickers, press C for adjustment. Then press B for recovering.
Nov 30, 2010 | Watches
I have an ASUS model X83V and my screen has been flickering (not in brightness, but actually going fuzzy and "jumping"). The flicker can take upwards of 1 hour or more before it goes away, but usually...
my son has this same machine and after a year of almost daily use it developed this same flicker you describe, about every 4 secs, then it got much worse, almost like an old tv rolling. i took it all apart and inspected it all. didn't see anything really troubling.
yesterday it worked fine all day while i installed a bunch of updates for another problem. i left it on all night doing some other things. this morn when i got up it was still ok. then after a while it started in again, every 4 secs.
so i've been troubleshooting the damn thing all evening and have come to the conclusion its from over heating, probably cause of the crappy heat sink connection. i noticed if i take it outside in 40 degree weather and leave it a couple mins on the hood of my truck, it goes away. bring it back in and after 5 mins it comes back. take it back out and its fine again in a few mins. also, yesterday my house as much cooler. my fire was out and it was in the upper 60's in here, today as soon as it got to 76 in here, and it was above that all day, it started acting up
so i think my next step will be to try and make a better union between the chips and the heat sink itself. you should try a test with yours. start it up, make sure its flickering, put it in a cold space for a few mins. just be caustious of condensation.
Oct 23, 2010 | Computers & Internet
My screen is going totally white while I am using my laptop
You do not mention the brand or model which would be very helpful. It sounds like one of two things. 1. the inverter attached to the lcd is bad or 2. the lcd cable is lose on the screen. Send me the model and I will get you a better answer pmgibs1@verizon.net
Feb 20, 2010 | Computers & Internet
Purchased a 42-Screen "flickers"
Inverter Board going bad or loose plug, then the backlight board will fail within 3-4 weeks later. Good thing you saved a few hundred on the x-warranty, BB won't do a damned thing for you regardless; it's discontinued & they lie about their 'replacement vouchers'.
A 12" bi-metal blade is recommended for your reciprocating saw so that you can cut this thing into small enough pieces for your trash collection.
Feb 13, 2010 | Insignia 42" LCD Flat-Panel HDTV
The screen on my dell inspiron nootbook started flickering last month, two weeks ago it started to turn completely dark at times and today 3 min after i turned it on a blue screen popped up and it told me...
windows dose not control any flickering unless the driver is being updated if thats not the case your flourecent bulb might be getting old inside the lcd!
Aug 29, 2009 | Dell Inspiron 1525 Laptop
Samsung, same exact problem - flickers on power up for a few min
This sounds like a power supply problem, how old is the monitor? If it is not new in the last year and is used regularly it sonds like a faulty capacitor in the power supply. If you are aware of the precautions necessary when handling capacitors and a moderatly competent solderer then you can replace then yourself - a complete set of capacitors usually costs around £3 or $5
Jun 27, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Flickering or Blueing of Vison V221WD monitor.
Check all the cables, if it is not the cables being loose, then it is a component inside that is starting to fail.
Mar 19, 2017 | TDV Vison F153 Monitor
Bad picturre on toshiba tv
Good Day, pieps57;
Corrective Action: Remove the MVUP13 Hyper Module from the TV chassis, remove the top shield and replace the 10uf, 16v capacitors using Part Number 24619040. It’s recommended that all of the capacitors identified be replaced (Note: These capacitors are low impedance surface mounted aluminum electrolytic capacitors. Care should be taken to avoid damaging the PCB while replacing these capacitors.) CAPS: cx178, cx221, cx230, cx241, cx250, cx261, cx270, cx541, cx670 & c514, c5030.
Good Luck, Big Irish.
Jul 07, 2008 | Toshiba 42H81 42" Rear Projection...
Televison & Video Logo
724 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
