Miscellaneous Logo
G
Gary Jeanette Posted on May 07, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can you tell me the year the Speery skid steer, L452, serial #607295 was manufactured?
Jean DeLauche
Level 3:
  • Miscellaneous Master 2,911 Answers
  • Posted on May 07, 2018
Jean DeLauche
Level 3:
Answers
2911
Questions
Helped
975792
Points
13030
Hello, Gary -
The Sperry company has a complicated corporate history, which makes it a challenge to determine where corporate archives (which may include a record of product serial numbers manufactured by year) are located.
- The Sperry company acquired the New Holland corporation in 1947.
- The company name was changed to Sperry New Holland in 1973.
- In 1985 Ford Motor Co. acquired Sperry New Holland.
- Eventually, the corporate name was changed to Ford New Holland (and the Sperry name for construction and agricultural equipment was no longer used.)
- In 1991, Ford sold its Ford New Holland unit to Fiat Geotech, creating N.H. (New Holland) Geotech.
- Eventually, Ford, Fiat and other products were grouped under a neutral, globally-recognizable brand name: New Holland.
- In 2017, New Holland changed its corporate name to CNH New Holland.
Therefore, if your skid steer just has the brand name "Sperry" on it, it was PROBABLY manufactured prior to 1973. However, there is still a challenge regarding the location of the Sperry manufacturing records for its agricultural and construction equipment.
Some New Holland corporate records covering 1902-1906 and 1971-1987 are held by the Lancaster County (Pennsylvania) Historical Society:
https://www.lancasterhistory.org/finding-aids/new-holland-records-1902-1906-1971-1987/
Scroll down the web page cited above to see the telephone number and email address for LancasterHistory.org. You will need to contact the archivists there and find out the charge for researching the New Holland corporate records to determine if records of the manufacturing serial numbers have been retained. When you contact (I recommend speaking by phone) an archivist, I suggest you ask if he / she knows where archival records for Sperry (the unit which manufactured agricultural and construction equipment prior to the corporate name change to Sperry New Holland) may be kept. Serial number records prior to 1971 for Sperry agricultural and construction equipment may be held in one or more other archives (if good fortune had them deposited in an archives.)
Note: At one time I worked as a corporate historian and archivist in the USA.
Best wishes.
Need a 1816b Case Skid Steer service manual
A service manual for the 1816b Case Skid Steer can typically be obtained through the manufacturer or a dealer of Case construction equipment. The manual will contain information on specifications, maintenance, troubleshooting, and repair procedures for the 1816b skid steer. Additionally, you can find such service manual on some online marketplaces or forum. It's always recommended to use the original manual that's provided by the manufacturer for accurate information.
2answers
Bobcat 753 Skid Steer. What year is a 753 Bobcat with serial # 514585506
How do I find out what year my Bobcat is?
You can find out what year a Bobcat is by contacting a Bobcat representative. Firstly, locate the Bobcat serial number - usually in the owner's manual or inside the door - and then phone up Bobcat.
Once you provide the representative with the serial number, they will be able to tell you exactly what year and model the Bobcat is.
What year is a 743 Bobcat?
The 743 Bobcat model was produced in the years 1987-1991. If you are unsure what year a Bobcat is - or even what model or series it is - you can use the serial number to find out.
By simply phoning the Bobcat team and telling them the serial number, you will be able to find out the year of your Bobcat in no time.
What year is the Bobcat 753?
The 753 Bobcat is a skid steer model. If you have a Bobcat 753, it will have been manufactured between the years 1999 and 2003.
https://www.google.com/search?q=What+year+is+a+bobcat+753
1helpful
Can you tell me where is the fuse/fuse box located on a Scat Track skid steer?
In the cab under the left window around knee position towards the windscreen is a a covered box that's it.
Where is the serial number located on a bobcat utv model 3400
How to Find the Year on a Bobcat Skid Steer
  1. Locate the VIN or serial number on your Bobcat. ...
  2. Look through the Owner's Manual for the VIN/serial number. ...
  3. Write down all of the numbers that appear in the Owner's Manual or on the skid steer.
  4. Call the Bobcat Marketing Service Department.
Bobcat year
Try this link from what I read all you have to do is call them and give them the S/N that you have and they can give you the year.
https://itstillruns.com/year-bobcat-skid-steer-7213000.html
How to raise the seat on Catapillar skid steer
Give me more information so I may give You more information. Machine parts design constantly changes, being able to identify your machine from the hundreds of thousands of possible CAT skid steers can only be done by having the MODEL & SERIAL # to identify the machine as it left the production line. Without this information, a generalized answer is all anyone can give.
What oil would you use for the power steering
Depends on the vehicle manufacturer, year, and model of vehicle. Older cars used auto trans fluid. Some used power steering fluid of a type manufactured just for their brand of cars. Most today use standard power steering fluid. Check with a local dealer or shop. They can tell you what to use. If you want to tell US the manufacturer, year, and model of vehicle, we may be able to look it up and tell you.
Top Miscellaneous Experts
H Smith
Level 1 Expert
Robert
vince
Are you a Miscellaneous Expert? Answer questions, earn points and help others
