Question about Saeco Vienna De Luxe Espresso Machine
We have a Saeco Vienna coffee machine and the grinder turns but does not grind the coffee. Can you fix this? Where are you located?
    Problem Solver:
The grinder can be broken This typicaly happens when trying to adjust the grind size without the machine running.
Posted on Aug 22, 2009
  • 80 Answers
Maybe grinder is pluged out,try clean grinder maybe helps
Posted on Aug 01, 2009
2 Suggested Answers
  • 1089 Answers
SOURCE: Saeco Vienna grinds too much coffee.
Hi
If you have the Delux or Digital there are 2 knobs in the bean hopper. Turn the small knob back 1 mark and see if that will help.
Posted on Jul 12, 2009
I just received a used Saeco Vienna SuperAutomatica and I can not get coffee to brew. Drive grounds are shot into discard bin
HI
You must have 2 knobs in the bean hopper, or the grinds are more like French Press (very large grinds) If yoou just have 2 knobs turn the small one towards the minus (-) a little, and see idf that helps. If you hqve very large grinds you grinder has seperated and needs to be replaced.
Oct 06, 2010 | Saeco Vienna SuperAutomatica Coffee...
I have the saeco vienna coffee machine and lately it does not make a good coffee, it looks more like tea. I have the setting set to the strongest coffee and I also notice that the coffee grounds are really...
You can remove top panel and find the grinder.
Remove the limit lock screw and udjust in more fine grinding manualy. So now you can have more fine grinding.
Remeber that you have to move only two step at a time, then make coffee and then move again to more fine, this will avoid blocking the grinder and also burning the grinder motor.
Also before doing the above you can ckeck the grinding burrs if they are in good condition or they need to be replaced.
Sep 03, 2010 | Saeco Vienna SuperAutomatica Coffee...
Our Saeco Vienna Deluxe will not stop grinding. Any ideas?
Hi
3 things
1. Grind is too fine. Move to a very coarse grind, say 16.
2. Move the small knob to the - side and try again.
3. If that didn't work your going to have to clean you grinder.
Need instructions? email me.
Jan 05, 2010 | Saeco Vienna De Luxe Espresso Machine
Hello. I have a saeco vienna superautomatic
This happens due to condensation caused by steam developed at the end of the grinding cycle. Make sure that the grinding chamber is completely cleaned and dried before using the grinder.
  1. Turn the whole bean chamber to the right until it can be lifted off the base. This will allow you to clean the grinding wheel. NOTE: Never use water or liquid for cleaning the lower grinding section of this appliance.
  2. Clean interior recesses with a soft brush (not provided).
  3. Wash the whole bean chamber and lid and the ground coffee chamber and lid in mild detergent and water. These items are only dishwasher safe on the top rack of your dishwasher. Wipe exterior with a damp cloth. Do not immerse mill in water or any other liquid or place in dishwasher. Use only non-abrasive cleaners to remove stains.
  4. After completely drying, replace whole bean chamber. Important: when replacing whole bean chamber, screw on completely before setting grinding rate. Turn chamber clockwise (as viewed from top), until it will not turn. Fill with whole coffee beans for grinding and replace lid.
  5. Replace ground coffee chamber and lid, making sure it snaps securely into place.
Aug 02, 2009 | Saeco Vienna De Luxe Espresso Machine
Hi
Jul 12, 2009 | Saeco Vienna De Luxe Espresso Machine
Long time for drip coffee.
Grinder is set to too fine. Lower grinder settings. Keeping the machine at current settings with drip extraction will result in brew group clogging, gear stripping, and/or dulling of grinder burrs.
Jan 30, 2009 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna grinding issue
I think so, most problem with that the grinder grind to the lamp light up is damp in the grinder or oily beans.
if you have two adjustment knob in the bean hopper then the second problems can be the micro switch in the machine that have to be replaced.
Best regards
/Mirran
Nov 04, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna De Luxe not transferring grounds to brew group?
Make sure there not comming any damp into the grinder and the grinder is dry. If there was some damp in the grinder then you have to clean the grinder.
Aug 07, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco vienna superautomatica
oily coffee residue on the grinder prevent the bean from going down be carefull push coffee down in the grinder with anything except our finger by forcing coffee down will making expresso it should grind if it does remove the coffee cointainer little star screw driver after removing the container inside the grinder where the coffee go down you gonna see a steel piece the coffee goes down the slot remove the old coffee residue on that part clean it good with a tooth brusch or somrthing like that put back without old coffee stuck on the grinder you gonna see the coffee gonna go down in the feeder cheers and if it help you dont forget to rate this cheers
Jan 23, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna De Luxe Espresso Machine Logo
270 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
