Question about RCA Televison & Video
I have a 52 inch tv.When I turn it on it never powers up it shuts off. Its a humid room. Does this cause the problem?
  • 585 Answers
Without the model speculatiing is wider, older RCAs (brown cabinet) will do that when the high voltage splitter is bad, suprisingly its only a $50 part easy to install, or possibly bad conncetions on the main CBA (PTK169 chassis). the newer gray cabinet sets can have many issues .
from splitters, convergence ICs, power board HV shutdown issues.
post the full model and chassis to get a more specific answer to your set
Posted on Aug 01, 2009
I have a nuvision 52 inch lcdlp the projection tv with RGB. It will turn on and have picture like it's supposed to but after about 3 minutes give or take the picture and projector shuts off and power
Usually when this sort of thing occurs with a projection unit, the problem is due to overheating. The unit is designed to self-protect if the temperatures get too high. Check to ensure that the air intake/exhaust areas are clear and that the cooling fans are operational. Excessive dust/dirt can also cause overheating. The unit may need to be cleaned. Avoid disturbing too much when cleaning internal parts and ensure that power is disconnected when cleaning.
Dec 25, 2014 | Televison & Video
52 Inch RCA TV Model HD52W55 does not turn on green power light blinks 3 times but does not turn on. ive got it to turn on once before, and left it on since, accidently shut it off and cant get it back on,...
The best assumption, at this point, is that the power supply board has died. You can buy a replacement unit from the link below and have it professionally installed.
Power Supply
Aug 28, 2011 | RCA HD52W58 52" TV
My lg flat 52 inch tv when i switch on then it shut off, i have to try 10-15 times before it stay on and screen comes..what can be the problem?
The tv power supply board is the problems and the causes.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 29, 2010 | LG 52SX4D 52" HDTV
Tv wont turn on... light blinks yellow as if its going to power on.. and just shuts off... for my zenith dlp 52 inch tv
I had this same problem. The Zenith rep told me to unplug the TV, hold the power button down for 30 seconds, plug it back in and then turn it on. It worked and I haven't had a problem with it since. I hope this helps. Good Luck!
Mar 06, 2010 | Zenith D52WLCD 52" Rear Projection...
I own a 52 inch rca projection tv and last week
Most likely the Horizontal output transistor has shorted. When it shorts it causes the power supply to chirp. This is a common problem with this series of TV. Have a shop check it out. It should not be real expensive.
Oct 16, 2009 | RCA P52926 52" Rear Projection Television
52 INCH RCA REAR PROJECTION SHUTS OFF
Your TV is overheating.. easiest remedy is to point a fan at the back of the TV or... clean the inside of the TV, Im sure its full of dust and stuff... this prevents air circulation inside the TV thus creating more heat...
Jun 19, 2009 | RCA HD52W56 52" Rear Projection HDTV
52 inch rear projection tv turns off after a minute
try turning off the auto shut off feature in you set up screens . you can find them through the menu button on your remote. scroll through till you find it and turn it off.
Jan 18, 2009 | JVC AV-56WP74 56" Rear Projection...
Panasonic 52 inch TV turns on and turns off after 2 minutes
thi set will need repair , one of the circuts in the power section is failing and will need test to determine the exact cause of the failure, you will need to call your local electronic repair shop to come and take the board out or they will fix it there
if you need anymore assistance don't hesitate to ask
electech
Oct 26, 2008 | Panasonic PT-52DL10 52" Rear Projection...
Tv loses power
the processor on this et will shut this set down for number of reasons. a technician should be albel to read error codes form the processor to help deterine whatt is cause the shutdown
Nov 02, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
