Question about Pentair Minimax NT Heater
I have E04 error code, fan runs but no ignition or gas or gas smell
Troubleshot vaccum switch determined it was operational (Use Pentair's website for service instructions on the switch) Fan speed too slow due to worn out motor. Replacing blower assembly
Posted on Aug 02, 2009
2 Suggested Answers
  • 368 Answers
SOURCE: Fan runs, no ignition, no
Code E04 is a fan issue. It might be the fan, a tube or the pressure switch. I hope this helps.
Please vote on this answer. Thank you.
Posted on Aug 24, 2011
E04 minimax error code
check to see if you have adequate gas pressure sounds like it running out of gas pressure
Aug 04, 2014 | Pentair Minimax NT Heater
Since you said you replaced the fan, and flow valve. Did you re-install the pressure switch correctly? it will look something like attached image. This is more than likely the cause if you did not replace with the fan or reinstall correctly... or it might have been the cause in the first place...
Have a minimax nt LN heater that won't ignite.. I am getting an E04
possible bad fenwal not letting gas valve open see if ignitor is glowing if not check high limits
Mar 17, 2017 | Pool & Spa
Fan runs, no ignition, no gas smell. E04 on LED. The fan is running louder than normal, but the heater was working up until today.
Aug 24, 2011 | Pentair Minimax NT Heater
Rheem digital gas pool heater fan code
The Fan code would indicate a problem with the combustion air blower. The is a pressure switch to indicate there is sufficent combustion air, and if not then unit shuts down. Either the fan isn't running, or there is an obsturction in the fan or exhaust piping, preventing enough air flow.
cfh would be call for heat, which would be a normal display when water temp is below setpoint
See the link below for a manual. Once you open the page look on lower right side for documents, then install manual
http://www.rheem.com/product.aspx?id=2388EEB7-3DEC-4601-AE76-EC7A07F17630
Jul 04, 2010 | Solar Rheem Gas Fired Pool & Spa Heater...
I have a Pentair pool heater. E04 code
should be the coolant fan thats in front of the raidiator
May 07, 2010 | 2005 Mazda Tribute
No ignition and E04 Code
The HSI (ignitor) has 2 wires, its like a cigeratte lighter, power is applied and it heats then glows red, the single wire you mention is the flame sensor, used by the control board (igntion module) to ensure the burner has lit or it shuts the power to the gas valve off but keeps the fan operating for a period of 1 hour till it resets.
It sounds like your ignitor is defective, it happens often, depending on your location, you may be able to purchase one, but I would advise having a service tech do it.
The manual for troubleshooting and repair can be found at this link:
http://www.staritepool.com/pdfs/MiniMaxNTServiceManual.pdf
Aug 14, 2009 | Pentair MINIMAX NT TSI IGNITER
E04-14 error code
If your standing facing the back of the machine, you will need to change the top right fan that cools the IH,power supp. there are two fans which need to be replaced, the other fan is behind the sc pcb but that will give a different error.
Feb 15, 2008 | Panasonic DP-C354 Copier
Pentair Minimax NT Heater Logo
1,460 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
