Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
My magnavox 37MF321D/37 will not turn on. It
My magnavox 37MF321D/37 will not turn on. It started fading by barely powering up...the power button would flash green. Then it just quit all together. Any advice?
  • Jamie miller May 22, 2012
    I know this is an old thread but I had a friend bring me his tv to be repaired. I've already pulled the power supply apart and checked the capacitors, but none of them are bulging. I pulled capacitors 2074 & 2081 to check them with my meter and they appear fine that way as well. The symptoms of the tv are as follows: plug in to wall outlet and the screen flashes with no pic, power light is on constant green with no blinks. Can anyone please assist me further so that I don't replace parts that aren't bad? Thanks for any assistance. By the way, all the diodes, and other components look fine with no burn marks. The other board next to the power supply board has a few marks that look suspicious though.
  • 4 Answers
I had the same problem with the blinking green light. These are the parts one the power supply I replace to repair it. note: If the power supply is repaired you will get a solid green light and the backlight will light up almost immediately.
My magnavox 37MF321D/37 will not turn on.  It - 5df38cd.jpg
Posted on Sep 10, 2009
  • 4 more comments
  • sd2649 Sep 02, 2010
    I used this advice and made a video tutorial. see it here:
    http://www.youtube.com/watch?v=qSS6ycUxS...
    and here:
    http://www.youtube.com/watch?v=oTOkHKPJs...
    it worked! thanks!!!
  • Frank Fountain Sep 25, 2010
    I just used this same guidance to fix my issue. I had zero experience soldering anything, but I looks through these videos (plus some one that dealt with soldering in general), and I fixed my situation. It totally works.
    Thanks!!
  • wayne_ostran Nov 10, 2010
    What position is the 1n914 going into?
  • wolfvan13 Nov 12, 2010
    I replaced the buldging leaking capacitor, nothing. I replaced the switching diode, nothing. I have triple checked all of my solder joints. There is a red blinking led visable on the left side of the TV, viewing from the back with the cover off. No certain order or code. Any ideas?
  • David2k4 Nov 27, 2010
    My 37" magnavox just went out today as well... only the 2074 cap and 6079 zener diode seem to be bad... Will be going to Radio Shack tomorrow and replacing said parts. I will post as to my success of failure.....
    To answer the above question.... the 1n914 I believe is the 9.1V zener diode at 6079, mine is completely toasted and black.
  • go99edwards Dec 21, 2010
    I also have a 37" Magnavox and the 2074 cap is bulging and venting and the diode in the 6079 position has made the board under it dark. Will replace tomarrow and update my results
    Problem Solver:
  • 6 Answers
I used this advice and made a video tutorial on how to repair the power supply. see it here:
http://www.youtube.com/watch?v=qSS6ycUxS98
and here:
http://www.youtube.com/watch?v=oTOkHKPJsnM
Posted on Sep 02, 2010
  • 1 more comment
  • raechuck43 Oct 24, 2010
    I too studied this clip for the same problem and finally dove into it with no experience in electronics at all. Was able to correctly identify the bad capacitors and ordered them from Mousser Electronics in Mansfield Texas. They came in 3 days and I put them in today and if worked just fine. Thanks to who ever for the video clip.
  • sd2649 Oct 25, 2010
    No problem!
  • tcstemick Mar 02, 2011
    Hi there. I've been working on this same issue, and while helpful, I was wondering if anyone knew what the component was at location 3045 on the back of the power supply board. I can't tell if its a smd diode or cap, its burnt to a cinder in addition to the burnt diode at 6079?
My magnavox has no sound the instruction manual roles on going thru the television, I cannot shut it down. The red and green light is on in front of the tv. I can't change channels, I can't get sound, and I can't shut it off. Have to unplug it.
Posted on Aug 07, 2009
I had the same problem w/the blinking light on my Magnavox. Both 1200MF 35V caps were bad, as well as the 2200MF 25V cap. I replaced the two 1200MF 35V caps with two 1500MF 35V caps I acquired at my local Radio Shack. I then replaced the 2200MF 25V cap with an axial 2200MF 35V cap I also acquired at the local Radio Shack. For ~$15 I fixed my HDTV. Couldnt be happier. Hopefully the new, slightly heavier duty caps will last longer than the original ones did.
Posted on Jun 24, 2012
I have had a flashing green light problem twice on my 42" Magnavox LCD. Less than 5 months, it would power on showing digital video on the screen and a flashing green light. Couldn't view cable or dvd or operate any buttons. To reset, I had to pull the hdmi cables then unplug the tv set. Just cycling the power alone would not reset this television.
Posted on Apr 23, 2010
    New Friend:
I think 3 "NTE NEV1500M35 -CAP1500MFD 35V RADIAL" ITEM# 12436634at https://www.radioshack.com
would work the sameMy magnavox 37MF321D/37 will not turn on.  It - 12_14_2012_12_11_34_am.jpg
and 1 "NTE NEV2200M24FH -CAP 2200MF 25V RADIAL"ITEM#12436638
i think thay will work the same !
goto https://www.radioshack.com and look up the item#!
Posted on Dec 14, 2012
  • risingsun677
    risingsun677 Dec 14, 2012
    i think 3 "NTE NEV1500M35 -CAP1500MFD 35V RADIAL" ITEM# 12436634at https://www.radioshack.com
    would work the same
Awesome. Even with my meager soldering skills this was a breeze. Thanks for the info. Now my tv not only works but it doesn't take 3 hours to turn on!
Posted on Jul 22, 2011
  • 3 Answers
Thank for the help I had to replace the 1200uf @ 35v cap with a 1000 and added 220uf @ 35v could not find the 1200uf @35v local. TV works and need remote to set colors up but it saved me 1200$
Posted on Mar 11, 2010
2 Suggested Answers
  • 8457 Answers
SOURCE: 37 INCH LCD MAGNAVOX TV WILL NOT TURN ON. MUST BE
This problems,very common in LCD tv,after the tv was in used about a year or two.The new technalogy LCD tv don't handle heat very well,not like the old CRT Tube Tvs.The power supply board tend to have bad capacitors componnents leakage,that bulges up it top or puff up gases escape,that why it take times or couples pushes to the power botton to turn the tv on.U know basic electronic's,and have soldering tools and solders?Take the tv aparts,check for these bad capacitors,that bulges,puff up in the power supply board and replaced them,than ur power will work normal again.Or tries Websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Apr 29, 2010
Magnavox 37MF321D/37. suddenly just shut off and would not turn back on, no blinking green light nothing!
Price the board first and then decide, I fix these in our shop but do not like or enjoy working on them at all.
Dec 20, 2012 | Toymax Magnavox 37MF231D 37 in. LCD TV
Magnavox 37MF321D/37 screen flashes with no pic, power light steady, capacitors in power supply look to be fine
I just fixed a similar problem on mine but the power light was flashing at the same time the screen was flashing. I made a video showing what part and how to replace it. I also added a link to the part I ordered. L5973D STMicroelectronics Mouser
May 22, 2012 | Philips 37MF321D 37 in. LCD Television
37mf321d won't turn on- no busted capacitors
Hey Superdave,
Does the whole tv turns off when the picture turns off ??? What you're describing sound like a defective CCFL backlight. This would make since why someone threw it out because the repair estimates of replacing the bulbs would knock your socks off. Most will suggest ordering a new LCD panel assembly which would cost way more than what the set is worth. On some sets, when a CCFL is out, the screen will come on for a few seconds then go out. On other sets, after so many "lamp failures" logged in memory, the set will not power up at all and just flash trouble codes through the power indicator.
May 07, 2012 | Philips 37MF321D 37 in. LCD Television
I have a magnavox 37MF321D/37 and the power wont stay on, just flashes. Replaced the IR sensor, still same thing.
Just fixed that exact problem on mine. I made a video on how I found the bad part and how to replace it. I also added a link to the replacement part below. L5973D STMicroelectronics Mouser
Oct 10, 2011 | Philips Magnavox 42MF521D/37 Television
Magnavox 37MF321D/37 flicking on & off
Sounds like you need to repair the power supply, don't fret, it can be really easy.  Here is a pair of youtube videos I made after following some advice on this website from other posters:
Feb 08, 2009 | Philips Magnavox 42MF521D/37 Television
My magnavox 37mf321d 37 LCD tv
This is a bad power supply and an easy fix. Their are several electrolytic capacitors on the power supply. If one is bad it will have a bulge on the top. Mine had a bad 2200uF and a bad 1200uF capacitor. About $7 worth of parts at Radio Shack. Radio Shack had the 2200uF but it was axial leads instead of radial. (leads come out of each end instead of one end) but It will still fit. They only had a 1000uf capacitor so I combined that with a 220uF capacitor and wired them in parallel. Make sure you put them in with the correct polarity.
Mar 05, 2008 | Philips Magnavox 42MF521D/37 Television
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
5,739 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
