Question about Nintendo Wii Console
When lighting hit and the wii go out what do i do to make it come on
  • 12 Answers
Usually, after a power outage, a power spike (when the power returns) can disable/blow the fuse in the AC adapter for the Wii.
Try the following steps in this order:
FIRST:
- unplug the Wii's power cord from the wall, and leave it unplugged (from 5 mins. to 5 hours). Then, plug it back into the wall. (Unplugging the power cord from the back of the Wii will not help. You need to unplug the power cord from the wall.)
- This usually helps reset the fuse circuit in the AC adapter, and your Wii should work again.
SECOND:
- open the panel on the AC adapter box in the power cord; since the screws are proprietary, you will need to creatively use existing tools to turn the screws
- check the 3A fuse in that box; if it looks blown, then replace it
THIRD:
- it might be cheaper to replace the AC adapter with another one
FOURTH:
- get the unit repaired
MUST DO:
- buy a good SURGE PROTECTOR power bar, and plug all of your expensive items into it (to prevent this from happening again).
Hope that helps!
Posted on Aug 12, 2009
  • 28 Answers
I hate to say it but the lightning most likely fried your wii
Posted on Aug 10, 2009
My wii remote wont I guess connect it just keep flashing the lights at the bottom anytime I hit anything on the wii remote or try to sync it
Hold both Sync buttons for a period of 5 seconds, then let go. If this does not work, replug everything on your wii and try again. Make sure your Wii is on when syncing.
May 18, 2011 | Nintendo Wii Console
Remotes wont work light up but wont stay on ,hit
The red button, is a sync button and not a reset button. You can try resyncing your wii remotes to your wii follow these steps:
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
You must have batteries in when pressing the red sync button on the wii remote, if your using the wii remote charger system, you must remove it and use batteries until this step is done
Hope this helps. Owen
Apr 20, 2010 | Nintendo Wii Console
My wii remotes switch on and all four lights flash blue for about 30 sec then nothing! Any ideas?
You might want to sync your remotes to your Wii hit thhe sync button under the battery coner on the remote and under the wii special compartment
Apr 12, 2010 | Nintendo Wii Console
Wii remotes don't respond the wii comes on but the remotes do not come on
if you get no light on the remotes when you hit the button..change the batteries
Jan 18, 2010 | Nintendo Wii Console
The wii remote is not working cause the light is not showing .
1. Check the batteries in the Wii remote. 2. Synch the Wii Remote with the Wii Again.
If you are trying to play as a guest. You'll have to let the Wii Remote that is partnered with that machine power it up, and then hit the home button on that Remote and you'll see the batteries aat the bottom of the screen. Click the Wii Remote there.. and then resynch.
Apr 26, 2009 | Nintendo Wii Remote Controller
Two remotes do not work on some games
I would try reconnecting the controler that is the problem to the wii. There should be a button y ou can hit on the front of the wii that is inside of a little door. It is a red button. Right after hitting that there should be a button on the wiimote's bottom, it the battery area. The lights should blink a while and it should finally connect.
Feb 12, 2009 | Nintendo Wii Console
Wii remote
Greetings baggie bird,
You need to resynch your remote to your Wii console.
You hit the sync button under the battery cover on the remote, and then when the lights are flashing on the remote, you hit the sync button on the Wii. The synch button is located under the small cover to the left of the cd/dvd slot.
Thank you,
Dort
Go Ahead. Use Us.
Apr 19, 2008 | Nintendo Wii Console
Setting up 2nd wii remote
Greetings mlsaenz7,
You need to resynch the second remote to the Wii console. To accomplish this you need to hit the sync button under the battery cover on the remote, and then when the lights are flashing on the remote, you hit the sync button on the Wii. The synch button is located under the small cover to the left of the cd/dvd slot.
Thank you,
Dort
Go Ahead. Use Us.
Blue light
All we did was hit reset on the Wii system while on the Wii main menu.
Feb 27, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
395 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
