Question about JVC Everio GZ-MG21 Camcorder
Error code a0000006 at end of burn
Job Error Code:68 (VinPower DIgital Unit)
Error Code 68
System error code 68 means "The name limit for the local computer network adapter card was exceeded." This error code may also display as "ERROR_TOO_MANY_NAMES" or as the value 0x44.
I don't know what this has to do with using lightscribe and burning the CD's but perhaps your running this over a network?
Good information here and his solution near the end of the article:
Fix Windows error The name limit for the local computer network adapter...
Hope this helps good luck!
Mar 11, 2014 | Vinpower Digital SharkCopier 1 to 12...
CyberLink Power2Go - trying to copy DVD which plays correctly but error occurs when trying to copy disc 18:15:27, file(cl_DiscCopy.cpp), line(1071) -> End new track: -286331154 18:15:27, File(cl...
the disk may be playing correctly, but that does not matter. but i want you to know that the disc is not 100% good, you can try another disc and see that is going to copy successfully.
Sep 02, 2010 | Computers & Internet
Goes to copy files onto DVD with windows media player, but comes up with a long error code right at the end. Have changed speed down to x4 even though dvd's support 16x
Have you tried any other software for burning files??
I use a couple of free programs.
IMGBURN very good, can burn data and image files, but cant make an audio disc from mp3 files
CDBurnerXP this can do everything
If you are still having problems after using these programs, try write the error code down and we can take it from there
Aug 12, 2010 | Samsung SH-S222A DVD-RAM Burner
Error Code 105-E-1 ???
I'M HAVING THE SAME PROBLEM, ANYONE KNOW WHAT THE DEAL IS?
Oct 24, 2009 | Panasonic SDR-H200 Camcorder
Tried to burn a DVD using Power Cinema by going Create DVD, Author & Burn etc. Get to the end for the buring process and got a error code: FF037303. What does that mean?-
means you have a faulty or failed DVD burner (error is Power Calibration Error, returned through the ATAPI driver). Test with different /branded/ blank media, if none work then replace the drive.If you find one that works, stock up.
Jul 16, 2009 | JVC Everio GZ-MG130 Camcorder
Error Code 4450 When Burning Disc of Playlist (Any Audio)
it is the problem of your RAM serial cable ..get it replaced and it will be working fine hope you are using Nero for burning if not then plz use so
Jul 07, 2009 | Gateway GT5220 PC Desktop
I HAVE ROXIO MEDIA CREATOR 9 AND GET TO THE VERY END OF TRYING TO BURN A SLIDESHOW OF 750 SLIDE VS AND 7 AUDIO TRACKS AND AT THE VERY LAST MINUTE THE BURNING FAILS CODE 800700E ERROR WHILE ENCODING MENU....
You haven't mention which OS you are working with. I guess it is Windowsxp. Download nero and install it. It might help you to burn your files.I think that Roxio media creator is incompatible with your current OS.
Jun 17, 2008 | Computers & Internet
PCM4Everio
Has anyone been able to find out what the error code ff037303 means? Will not allow me to burn video to dvd
Oct 25, 2007 | JVC Everio GZ-MG21 Camcorder
JVC Everio GZ-MG21 Camcorder Logo
69 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
