Question about Karcher 2500 PSI Pressure Washer
Hi i have a honda gx340 11hp washer it has.nt being used in over 2 years i had to change the valves, got it going now its blowing black smoke and running very low on power thanks shane.
  • shanecullen Aug 06, 2009
    thanks very much for that thanks again shane.
  • 10,515 Answers
It would generate smoke if there is too much oil is left in the filter. Check air cleaner and it would fix the issue.
Let me provide you with Service Manual ( Generic ) for all the Honda Engines.
The link would be :-
http://www.electricgeneratorsdirect.com/manuals/NGK%20Generator%20Honda%20engine.pdf
There would a proper troubleshooting chart and steps that you need to take care off.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 06, 2009
Hi my 1999 Honda ace deluxe 750 blows blue smoke out exhaust when warmed up could it be valve adjustment
No that is either poor ring seal or loose valve guides, you need to rebuild the engine most likely.
Nov 10, 2016 | 1999 Honda VT 750 CD Shadow A.C.E. Deluxe
Pentair minimax nt propane heater is blowing black smoke
is heater installed in a shed? how many btu's is your heater. You need 1 square inch per 1000 btu's for combustion air opening. Lack of combustion air will cause heater to under fire and produce carbon dioxide
Mar 16, 2014 | Pentair Minimax NT Heater
Honda xr 250 blowing smoke
Hi, Anonymous your instrument gauges and lights can alert you to most electrical and engine issues they can not warn you about failed engine gaskets or seals so your engine has to resort to old fashion alert methods of colored "SMOKE SIGNALS" here is a breakdown of their meaning:
1. COLORLESS OR SLIGHTLY BLUE SMOKE on start-up means your air/fuel mixture is at the right composition and everything is well burnt in your combustion chamber.
2. BLUE SMOKE on startup is usually caused by failed valve seals dripping oil into the combustion chamber when the engine is not running.
3. YELLOW OR BROWNISH SMOKE at start-up means your air/fuel mixture is too lean. Too lean means that there is low fuel but high air mixture in your combustion chamber.
4. WHITE SMOKE on startup may be caused by a blown head gasket allowing coolant to enter the combustion chamber and may start dripping out of the exhaust pipes or mufflers. Smoke while riding is usually caused by worn out or damaged valves, seals, guides, pistons, rings, or cylinder walls.
5. BLACK SMOKE on startup is usually caused by too much fuel in the combustion chamber this can be due to air/fuel mixture adjustment too rich, accelerator pump improperly adjusted, faulty choke/enrichner or not in the off position, air filter dirty and clogged, faulty carburetor float needle and seat, pilot jet too large, fuel injectors leaking, smoke while riding is usually caused by the main jet being too large or a damaged carburetor.
It should be noted that aggressive or abnormal throttle operation will cause these conditions to manifest themselves exponentially.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the links below. Good luck and have a nice day.
Help xr250 still blowing smoke
Xr 250 1981 lots of smoke
Honda XR250R Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda XR250R Owner Manual
Oct 24, 2013 | 1995 Honda XR 250 R
Misfire and blowing black smoke
Hi Rick,
There is a number of problems,
1. You need to give the car a proper service. Change plugs, filters, brakes, all the oils.
2. clean the valve body with the flow sensors
The black smoke is most properly from the engine oil that is combusting. This will stop as soon as you have change the air filter.
3. make sure that the spark plug wires are in a good condition as well.
Aug 06, 2013 | 1999 Toyota Camry Solara
2002 Honda VT 750 CD Shadow A.C.E. Deluxe blowing smoke
Hi, Maria your instrument gauges and lights can alert you to most electrical and engine issues they can not warn you about failed engine gaskets or seals so your engine has to resort to old fashion alert methods of colored "SMOKE SIGNALS" here is a breakdown of their meaning:
1. COLORLESS OR SLIGHTLY BLUE SMOKE on start-up means your air/fuel mixture is the right composition and everything is well burnt in your combustion chamber.
5. BLACK SMOKE on startup is usually caused by too much fuel in the combustion chamber this can be due to air/fuel mixture adjustment too rich, accelerator pump improperly adjusted, faulty choke or not in the off position, air filter dirty and clogged, faulty carburetor float needle and seat, pilot jet too large, fuel injectors leaking, smoke while riding is usually caused by the main jet being too large or a damaged carburetor.
02 750 ACE is now smoking
Identifying Smoke
Honda 1998 VT750C Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda VT750C Owner Manual
May 23, 2012 | 2002 Honda VT 750 CD Shadow A.C.E. Deluxe
Honda lawnmower GXV 140
I have a similar Honda (with the overhead valves) that someone gave me because it didn't run at all. Turns out it had a stuck open exhaust valve. I got it unstuck and changed the oil. After running it about an hour, the valve stuck again. I think this is an inherent problem with these engines. I cleaned up the valves really well and lubricated them. Then I put a high quality synthetic (actually motorcycle racing) oil in it and have been running it for a year now with no problems. Not sure what your issue is, but with stuff blowing out of the exhaust and loss of power, I'd pull the valve cover off (prop up the front of the mower and you can do this without losing any oil). Check your valves and give them a good cleaning. They may not be seating properly, which would cause the symptoms you describe. I'm just an amateur, but I'm learning every day! Hope this helps and best of luck to you Lou.
James
Oct 31, 2011 | Garden
Blowing black smoke focos 2007 tdci
2 possibiltys.piston rings are wore letting the oil blow by.second could be your valve guides are wore and also blowing by.
Sep 20, 2009 | 2007 Ford Focus (3 Door) Hatchback
Fuses keep blowing out
IF water is not going in the drum It sounds like the water valve coil has finally failled , It has been blowing fuses ,because the ccoil on the water valve was getting weak . change this water valve and you sohould be ok , but before doing so chaeck to see if you have the proper voltage going to this valve when It is calling to open ,if the power is there and the water is turned on the valve should be letting water in the machine . you can also take a ohm meater and check the valve for proper resistance . . If the machine is up in years I would change this valve . from the chack I mentioned earlier . hope this helps you
Nov 03, 2008 | Maytag Atlantis MAV6451 Top Load Washer
2003 Toyota Highlander 4 CYL blows black smoke on startup!
most likley its going to be an one of three things if it is a 1MZ-FE engine #1 air flow meter #2 IAC Valve #3 EGR valve hope this helps
Oct 16, 2008 | 2003 Toyota Highlander
Karcher 2500 PSI Pressure Washer Logo
69 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
