Question about Jensen LXA300 Car Audio Amplifier
Amp was working, then it goes out
After i first connected it, it ran just fine. Just today going down the driveway, it went out. The protect light goes on then off, but the green power light does not come on at all, disconnected an reconnected still. Put my old amp back in and it works, its something with the amp.
    Problem Solver:
  • 6 Answers
It could have a short inside of the amp. my old amp did that and i moved my grounding wire and it shot sparks all throughout my trunk..... try to return it. or exchange it. tell them its defected
Posted on Aug 01, 2009
JBL BP600.1 protection
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Using an ohm meter to the sub will confirm whether its bad or not. Invest in a cheap test set of 6.5" speakers.
.A thumbs up would be greatly appreciated if this answer is helpful to you.
Jun 02, 2013 | JBL BP600.1 Car Audio Amplifier
Blue light on top flashing???not powering subwoofers.. was working fine.( blue light stayed on.) When I noticed it I shut the system down immediatley!!! Have'nt turned sytem back on since. What should I do...
You amp went into protect mode from an abnormal condition. Were you hammering on this amp when that started? I might suggest letting up on it a bit if so. Also check your wiring. Make sure all are insulated well and fully connected. It cut the noise off because if it would have continued it would have blown your amp. Make sure the fuse is good as well. Perhaps it is getting weak. Turn things down and turn the amp on. Give it a chance to cool for a bit first and then turn things down and turn it on. Everything a go? Then turn it up a bit then. My guess is it was getting worked a bit to hard and went into protect mode. Give the amp a rest from time to time. Good luck.
Mar 06, 2011 | Pioneer Car Amplifier GM-7100M - Mono Bass...
I have a power acoustic gothic series 1600 watt amp, it was playing fine last night and just went off, protect light on. Today i tried it, there is a very small amount of sound thru the speakers but thats...
There are really only two possibilities here. If you have the gain turned up too high then your amp will get over worked and will go into protect mode. It is a safety feature. You should never really have the gain at much over 50% up. If you have to consistently run it higher than that you are overworking your amp and it will either shut down to protect itself or you will fry it.
Nov 19, 2009 | Power Acoustik LT-980/2 Car Audio...
FUC% the protection light
i had a similar problem with my amp (although a different brand). Check you ground connection and make sure it's not grounded to metal with paint covering it. This is NOT a solid ground connection. You must remove the paint then reconnect it. Without a solid connection to ground, it cant run for very long without going into protection mode. Hope this helps
Jul 27, 2009 | Soundstorm Force F2800 Car Audio Amplifier
AC died, a belt is broken, now no tachometer or power
It probably ran the alternator too and without it the battery ran down so the engine went dead without any power.
Jul 02, 2009 | 2004 Kia Spectra
Memphis PR300.2 Amp protect light on
If it is not turning on your problem is it is not getting power. Check your fuses. The reason an amp goes into protect mode is usually because the subs are not wired up right. Make sure your fuses are good, you have a good ground, and make sure your amp turn on wire didn't come loose when you were putting the deck back in. As for the amp going into protect you probably wired the subs down to too few ohms and the amp you have can't handle it. Try hooking the subs up straight w/o bridgeing them and turn it up to see if it works. If you don't have problems with it then you wired your subs wrong.
Mar 22, 2009 | Car Audio & Video
Protect led light
It appears that the amp is going into protect mode. To eliminate external causes, read through the following page. Let me know if you have any other questions.
Amp in Protect Mode - Troubleshooting
Oct 10, 2008 | Car Audio & Video
2003 grand am
I had same problem. It was fuel pump that needed to be replaced
Jun 25, 2008 | 2003 Pontiac Grand Am
Stuck on standby
Unit is in protect mode there are a few problems that can trigger protect mode the most common is blown channel (shorted outputs). Sometimes one of the 15v regulators may go bad causing imbalance of supplys triggering protect mode. Also sometimes a bad solder connection could cause unit to go into protect also. I work for Denon authorzied repair center in Michigan if your nearby and Shipping to Michigan is economical let me know kstahl65@att.net
Feb 13, 2008 | Denon AVR-1804 Receiver
Jensen LXA300 Car Audio Amplifier Logo
109 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
