Question about GE Refrigerators
I just bought a top freezer used. The freezer is
I just bought a top freezer used. The freezer is cold the fridge isnt. It was working at the guys house.
    President:
  • 1,273 Answers
I have an older unit that sounds similar, so try this: Look at the bottom back of the freezer compartment. You are looking for a piece of plactic that looks like a shelf, covering the duct that connects the freezer compartment to the fridge compartment. It may have been jostled closed in the move. The adjustment is easy; open the plastic more for colder. Mine has tabs on it that fit into grooves on the back of the freezer, and they were broken, so I made a replacement out of plexiglas from Lowe's. If you have a similar arrangement, you can make a lot of different things work. Please look and re-post here if necessary. I'll check back.
Best regards. --W/D--
Posted on Aug 01, 2009
Freezer cold fridge isnt
freezer working,fridge not working,condenser fan ok, compressor running very hot.
Dec 14, 2011 | Whirlpool GS6NBEXR Side by Side...
Freezer works fine but fridge isnt getting cold
make sure there isn't food blocking the vents that bring the cold air into the frig from the freezer. and make sure they're open enough.
Jul 16, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
My freezer isnt as cold as it should be, top part of fridge isnt as cold and ice maker isnt freezing water
find the air vent and see if there is anything in front of them to prevent the air from recirculating. ice could be in the vents to,
Apr 13, 2010 | Freezers
Fridge works freezer does not Zannussi
the fridge will soon stop to! all cooling goe to the freezer first! look to see if there is frost in back of the freezer if not it might be low on charge
Apr 11, 2010 | Freezers
My Samsung Freezer isnt working but the fridge is fine
without checking equipment you can only assume things that may go wrong...1st..try fully defrosting complete unit,clean all vent/drain holes then switch back on and let unit do its thing for 24 hours.then check temperatures are minus 18-20c for freezer and plus 2-5c for fridge (approx)unless you have electrical meters to check, this is just about all you can do..
Feb 19, 2010 | Samsung RS2630SH Side by Side Refrigerator
Frigidaire top/bottom fridge is on, but not cold in either the fridge or freezer.
We bought a small used Frigidaire refrigerator-freezer on top--Freezer is cold but items in frige are not...what could cause this
Feb 09, 2010 | Frigidaire Refrigerators
Kenmore refrigerator top freezer
sounds like the freezer is frozen solid and not lettting the cold air down to the fridge. Make sure the freezer is going through the auto defrost cycle.
Jan 01, 2010 | Kenmore Refrigerators
Top Freezer works fine but there is no ice building up in freezer the bottom fridge not cooling properlyThings are not as cold as they should be
Remove the back panel from the freezer to verify no ice behind the freezer panel. Look inside the air vent on the freezer panel for ice buildup. Make sure the freezer control is set to minimum not coldest freezer.. Make sure the freezer fan motor is working.
May 28, 2009 | Electrolux Refrigerators
Whirlpool side by side freezer not working fridge is fine
Pull out the fridge and unplug. Remove the back cover. Clean the condenser coils and fan. If they're difficult to get to, use compressed air to blow out. (you can get a can from walmart). That should fix the problem. If that doesn't work, then write back.
Doug
Jan 05, 2009 | Whirlpool GC5SHEXNS Side by Side...
Fridge and Freezer losing cooling
we bought a f&p fridge freezer and in summer noticed it wasn't cooling and the freezer wasn't freezing, when the service guy came out he noticed our ducted air con was blowing onto the fridge, once we had redirected the air con outlet the fridge started working as normal, apparently f&p's work on air being convected around the cabinet of the fridge and air blowing on the fridge can effect the temperature of the convected air. hope this helps you or someone
Nov 23, 2007 | Fisher and Paykel Active Smart E522B...
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
