Question about Toshiba 52HM95 52" HDTV Projection Television
I hear a small fan running even after set has been off for a long time
  • 167 Answers
That fan is supposed to run.It cools the lamp after you have turned the TV off. It should eventually turn off.
Posted on Aug 02, 2009
When air conditioner turns off out doors I can still hear it running in the attic.
Are you sure you are hearing the air conditioner running, or maybe just the blower? The blower may continue to run to further dry the evaporator core and reduce the chances of mold and mildew formation.
-Rod
Jun 03, 2017 | Heating & Cooling
Gnev120w Made a noise, now not freezing.
the fan only controls air circulation. not the function of the motor. sounds like ur fridge is stuck in the defrost mode? check ur cold control thermostat with a multi meter for continuity. the fan does not run while in defrost mode, u can manually check ur defrost timer in the fridge by sticking a small screwdriver into the hole underneath it, and turn clockwise till u hear a click u should hear the fan and compressor come on if not turn 1 more click?
Mar 19, 2015 | Beko Refrigerators
I just bought a Danby Dehumidifier model: DDR6009REE The fan runs constantly even when the humidity setting is reached and the compressor is off. has anyone patched the power for the fan by putting...
All new generation dehumidifiers are designed to have the fans run all the time and the compressor comes on when the relitive humidity rises above the setting that you have chosen. I spoke with the company and asked them why this is so, and they told me that it is more energy efficient to have the machine on all the time so that when the compressor kicks in there is a small draw on electricity.
Apparently when the old dehumidifiers came on it was the compressor that turned on immediately, and the fan, and this caused a very high current draw. The new design has the fan on all the time and this helps to circulate the air evenly around the area being dehumidified - thus more efficient overall coverage.
I understood their explanation, but still do not like this new method of operation.
Jun 26, 2010 | Danby DDR6009REE Dehumidifier
The fan runs continuously, with thermostat set to
When was the last time you had the coils in the condenser cleaned. Dirty coils can insulate the refrigerant tubes, causing the fan to constantly run in order to try and cool down the refrigerant returning from the evaporator coils(a-coils) in supply ducting, But can.t because the condenser coils are insulated not allowing the heat to escape. I would try this first before replacing expensive parts. It is the small things that we overlook that is most likely the source
Aug 22, 2009 | Intertherm P3RA-048K Air Conditioner
Cooling fan won't turn off.
this set has more then one fan; one fan will run all the time to cool the digital circuit board---if it is the actual LAMP fan then you have a problem---the digital fan is very small and not located near the lamp.
Aug 06, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
No cold air and motor works intermittingly.
the fan motor is stuck take front cover off reach inside and turn fan by hand then try agin let me know
May 25, 2009 | Maytag M6X06F2A Air Conditioner
FAN RUNS ALL THE TIME
the fan on the chassis runs all the time, even when turned off.
Apr 19, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Aprilaire 600 humidity level too low
you may try running your blower 100% of the time.this should allow the humidifier to stay on even when your not heating. once the humidity level gets to where you want it, you may be able to put the fan selector back to auto. also you mentioned you have a variable blower. this is great if it is set up to run at approx. 20% fan speed when it is not heating or cooling. at 20% you can circulate enough air through the house to humidify without being able to hear the noise of the blower. it will really increase the comfort level of the house if you tend to have hot and cool spots. if it was not set up this way, contact the installer and ask if they can do this for you.
Jan 26, 2009 | Humidifiers
Hard drive or fan click?
Very unlikely that you are hearing any fan turn off and on since these are temperature controlled varable speed devices, not serviced by a relay that you can hear.
Some hard drives are audible even when working normally so that is not necessarily a sign of a dying drive.
Check your system settings to see if the drive is set to park and turn off too often.
I keep mine set at 30 minutes so it isn't cycling more than needed or running all the time.
Jun 10, 2008 | HP Pavilion dv9000z Notebook
Mitshubishi 52525
Yes, it is a cool down period. The fan will shut off after a few minutes.
Apr 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Toshiba 52HM95 52" HDTV Projection Television Logo
118 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
