Question about LG Microwave Ovens
Need operating manual for lg multiwave microwave
Manual LG MOT MG-604W
You may download a copy of the manual (in DjVu format) from http://www.lg.com/za/support-product/lg-MG-604W#
Jan 02, 2014 | Microwave Ovens
Lg combi multiwave
see the troubleshooting section and follow the steps and fix it.
God bless you
Waveguide Cover
If the microwave is sparking or arcing the waveguide cover might be damaged and shorting out. Try removing the waveguide cover and see if the problem goes away. If there are any damaged spots in the microwave ceiling or sidewalls, repair them and paint them with microwave oven paint. Replace the waveguide cover if it is burnt or if it will not stay in place.
Microwave Oven Paint
If the microwave is sparking or arcing on the side walls the paint might have chipped causing pitting in the metal oven wall. Use microwave safe paint to touch up any bare metal spots.
Rack Support
If the microwave is sparking or arcing near one of the rack supports, remove the support, repaint any bare metal, install a new support.
Sep 30, 2013 | Microwave Ovens
I boiled a egg in my microwave multiwave oven 750 watt and after 3 min the egg blasted and the oven stopped working. what could have happen and how can we fix it at home?
Unfortunately this is one of the worst things that can go into the microwave, when it blasted it covered everything on the inside including the magnetron and door switches. The cost will be high because chances are high the magnetron is damaged and the interior cavity is covered in egg not to mention the door latches, I would recommend replacing the whole unit.
Mar 30, 2012 | Microwave Ovens
HOW TO OPERATE MICROWAVE
LG has the manual for the MC7849HS on the product page: http://www.lg.com/uk/home-appliances/microwave-ovens/LG-MC7849HS.jsp . Click on the Support tab and the link to the manual is on the right. The link open in Adobe Reader.
I hope this helps.
Oct 09, 2011 | LG MC7849HS Microwave Oven
I have a Goldstar Multiwave and have lost the manual. Can you defrost by time rather than weight such an a frozen breakfast sandwich?
You can defrost items by time but not with the Q-Defrost or Auto-Defrost functions. (I've found it best to defrost ground beef with timed intervals at power 1. Auto Defrost by weight usually starts cooking the meat. You will need to try it a few times to see how long and what power to use.)
Manage My Life has the manual here: http://www.managemylife.com/mmh/owner_manuals/52491/GOLDSTAR-Countertop-Microwave-L1005548?brand_name_search=MA1011W . Sears Parts Direct may have a copy that you can order. (I didn't see it listed but didn't check the entire set of parts lists.)
I hope this helps.
Jul 10, 2011 | Goldstar MA-1011 Microwave Oven
Manual goldstar multiwave 1000W
Can I use aluminum foil in my oven
May 18, 2010 | Goldstar MA-1011 Microwave Oven
Need an operation manuel for a LRMM1430SW
Click on the link below and select "Download the complete user manual"
Good Luck
LRMM1430SW Owner's Manual
Sep 06, 2009 | LG Microwave Ovens
Manual microwave oven model for ER-761 MD
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
Some L.G. / Goldstar owner's manuals can be downloaded here.
Nov 19, 2008 | Goldstar Microwave Ovens
Lost Coupler/Turnable
you can call at -  1-866-925-7278
or
follow the below link to order coupler -
http://www.partstore.com/Sitemap/LG+Electronics+Incorporated/Goldstar/Microwave+parts.aspx
Good Luck!!
Thanks
Nov 10, 2008 | Goldstar MA-1011 Microwave Oven
Microwave Ovens Logo
549 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
