Question about Vacuums
Wind tunnel two with bag, started with burning smell then shut off with red light on. Belt is fine but cannot get it to start again.
    President:
  • 1,486 Answers
Sounds like your motor.Try replacing the brushes in the motor.If that does not work then the windings in the motor have burnt out.
Posted on Aug 01, 2009
Hoover bagged wind tunnel 2 vacuum turns its self off after about 10 min. of normal vacuuming I can press the power button right away and the vacuum will turn back on and vacuum for sometime as long as 5...
There is a thermal sensor in the motor which shuts power off if it gets too hot but usually it won't turn back on until it cools down. It seems you might have a defective switch
Oct 06, 2013 | Hoover U6437-900 / U6439-900 Windtunnel...
I have the G series Kirby silver vacuum, I was vacuuming and started to smell some burning. Looked down and my green light was off also. What could it be? PLS HELP
Your belt is burning and will eventually wear down and break. The green light comes from copper brushes on your roller creating an electrical current that lights the little green light. As long as the roller is turning, the light will stay on. There may be something jamming the roller (hair, string, paper, etc). Clean the roller off and replace your belt. If you don't replace the belt it will break soon enough. Once you start smelling the "rubber burning" smell it's and indication that your belt has deteriorated at some point and has a weak spot in it. Clean the roller and replace the belt and it should be fine.
Apr 20, 2013 | Kirby Ultimate G Bagged Upright Vacuum
I have a windtunnel vacum cleaner. When I
It might be a slipping rubber belt, is the brush roller moving when you look underneath? If it's a self propelled machine there might be another slipping belt. Friction from fast rubbing rubber can smell like it is burning.
Jan 16, 2010 | Hoover Company Wind Tunnel U53019 Upright...
How to change the V belt on hoover wind tunnel U6435-900 ?
Below I have listed a link to the manual which has instructions and a link to the V belt you need.
Windtunnel Manual
Windtunnel Replacement Belts
Nov 03, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Self Propel wheels not enough power to move machine over carpet.
Sounds like the transmission might need an overhaul. Take it to a local vacuum repair shop and have them look at the transmission.
Sep 03, 2009 | Vacuums
My Hoover Wind Tunnel has a burning smell when running. I replaced the belt, but this didn't help.
its clogged my vax does that burning smell when it gets clogged up thats for the five minutes before it overheats and stops
Aug 03, 2009 | Hoover U5753-900 WindTunnel Bagless...
Vacuum shuts off and has a burnt smell
Try removing the drivebelt, and try running it to test like this. The brush bar will not turn, but it should function normally without smell at this point. If it doesn't, you may need a new motor as I think the brushes may have worn down - producing an electrical type burning smell.
If it runs fine without the belt attatched, then there is probably a build-up of hair or threads at each end of the roller stopping it turning freely. With the hoover off, check it turns freely and easily. A small metal nail file or similar is usually a good tool to clear it.
If the roller is stiff, the belt will not turn easily, and overheat on the motor spindle - causing the burning smell.
Jan 08, 2009 | Hoover Vacuums
Rubber smell, Hoover
Well it sound like you do need a new belt because of how the smell is you might want to stop using it because the smell comes from the burning and over heated belt my solution would be to get a new belt and that should fix it if you need anything else you know whre to find me.
Jun 30, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
42 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
