Question about Whirlpool Dryers
I have to dry the same load two or three times, not enough heat.
    President:
  • 1,273 Answers
Couple of things can cause this. Let's do the easiest first:
Restricted Air Flow- Unplug the dryer, and disconnect the duct from the back of the dryer to where it goes outside. Take the hose outside, and clean it out. Inspect the rear cavity of the dryer and the louvered vent where it exits the house. Clean both of these too. Pull out the lint screen. Remove any debris below it. If you found a lot of debris in the duct or elsewhere, this was probably the problem.....Reassemble....
BUT, if not,
(The harder of the two)----Broken Heating Elements- Elements are nichrome wire coils, same as the stuff in your toaster, but on a grander scale. They can wear out over a period of time. There are two ways to check them. The first way is to gain access to the terminals in the back, and test each coil for continuity. If it tests open, the afflicted coil needs to be replaced. The second way is to gain access to the coils and visually inspect them. Any damaged coil should be replaced. Coils are readily available from any appliance parts supply house, and are pretty inexpensive.
Hope that this helped. Best Regards, --W/D-- please feel free to rate this solution. thanx!
Posted on Aug 01, 2009
Whirlpool Tumble dryer low heat, taking three cycles to dry one load
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 21, 2012 | Whirlpool Dryers
Takes three cycles to dry towels, displays 45 min. turns off within 30 min. still not dry
2 possible reasons, either the towels have not been spun at a high enough speed and are too wet, or the dryer is not getting hot enough because it is not switched to a high enough heat setting or there is a partial element or thermostat or humidity sensor failure. You should spin your towels as fast as you can, 1000 MINIMUM but 1400 or more is better. Did it ever work? Is it a new drier? Is it getting hot? 45 mins is a short time anyway to dry a full load of towels.
Jan 03, 2011 | Whirlpool Dryers
I have a whirlpool duet dryer bought it in 2003 from best buy. just recently clothes are not drying completely before shutting off. i hear the gas kick on the heat ..i've stopped it to make sure the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Sep 13, 2010 | Dryers
Not enough heat to dry clothes
You may find that they come as a kit, as I had one similar a long time ago.
Mar 13, 2010 | Dryers
There is no heat when dryer is on
you need chek :
if your apliance is gas dryer:
1-thermal fuse.
2-sensor flame.
3-ignitor.
4-gas valve.
if is electric dryer:
1-thermal fuse.
2-heater element.
Oct 05, 2009 | Dryers
Dryer not heating hot enough to dry
Check for a clog in the piping, Make sure the squirrel fan you replaced not backwards, also visually check an see if the heating element is glowing completly red, if not it's probley getting only 120 volts, not getting 240 volts, if that be the case you'll need a new switch. There are about three switches that could cause that problem, the high temp switch, low temp switch or the timer switch.
Apr 11, 2009 | Crosley CDE6000 Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Whirlpool dryer wont dry.
LONG dry time is an indication of a clogged or restricted exhaust. Check the exhaust hose in the rear of the machine and make sure it is not crushed or kinked. The vent pipe should be rigid metal not flexible foil or flexible plastic. If everything in rear looks OK, check the outside vent hood for any blockages. If everything checks out, the exhaust system may need cleaning. Cleaning kits are available at most home improvement centers and at this website:http://www.linteater.com.
Jul 05, 2008 | Whirlpool LEB6200 Electric Dryer
Clothes dryer not getting hot enough to dry in a good time frame
I have the same issue with my DLG3788W dryer. It seem to have only one setting for heat, rather than multiple heat settings. What can I do or do I have to call someone to repair this.
Oct 03, 2007 | LG DLE0332 Gas Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
