Reset component settings. Usually, the problems you
encounter with a projection TV may be resolved through the resetting to its
factory settings. If you experience inaccuracies in the color, reset the
television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab
and then highlight "Perfect Color" using your right key arrow. After this,
press "Enter" and then "Reset" in order to reset to factory settings. If you
have audio / video problems (VCR or DVD player), simply press "Menu" and
highlight the "Reset" option.
First let us remove the No Scan Option.
First try to Scan from HP director or HP Solution Center.
If it is scanning, perform the steps given below to resolve the issue.
Open HP solution center/HP Director: Click on settings: select scan settings from settings.: A Menu Appears. select scan to setup: a new page will appear: you will see all options on the left side: select all the options manually and click on the right arrow to move all the options from left to right side. after perfoming these steps. Restart the printer: and try scanning from printer now. now will be able to scan from printer itself.
Kindly install the Kodak all in one home center on your computer,connect your computer and printer via usb cable and then try 2 scan. Ur issue will be fully resolved.
Click on scan pictures and documents On kodak aio home center and then click on scan now,follow the instructions.
There may be the shutter was not opening. So you need to contact Canon authorised service center.
OR
There may be the CCD is faulty: To resolve this problem, you need to contact Canon Authorised Service
Center. They will replace the faulty CCD free of cost even the service
charges are also not applicable for this perticular problem in some models.
Hello, There may be the CCD is faulty: To resolve this problem, you need to contact Canon Authorised Service Center. They will replace the faulty CCD free of cost even the service charges are also not applicable for this perticular problem in some models.
A rolling picture or loss of vertical sync can be caused by several components including a bad signal board or jack panel assy. You will not be able to resolve this yourself. contact a Mitsubishi authorized service center.
Usually this is a problem in teh vertical circuit and generally results in a thin horizontal line through the center of the screen. If that is the case, look for a small flat IC that may be marked LA7837 or someting similar with about 11 pins. This should be the vertical IC. Try resoldering the pins on the IC first. If that fails to resolve the problem, replace the IC. Please note that defective capacitors in the vertical circuit can cause this as well. The more probable defect is the IC. Update this with your results. Also be aware that there are potentially dangerous high voltages inside the set even when unplugged.
ok this is common problem and a piece of cake to resolve....................the reason why u r not able to see the video what i will advice u to do is to go ahead and uninstall the videostudio 11 plus ....instead u can downlaod vlc player for free i assure u that u will like this and u will enjoy the videos coz vlc is compatible to any kind of videos ...that r realeased nowerdays .......so i asuure that the video problem will be resolved if not then change the graphics card or upgrade it to a nvidia gforce graphics card........................now taking about ur t.v and recording try a system restore if the issue is not resolved then create a back up of ur data and runa recovery from a recovery cd which will take the comp back to factory settings.....................then u can go ahead and download the vlc player fromhttp://en.utilidades-utiles.com/download-vlc-windows-vista.php and then log on to nvidia .com and update the driver if u r using an nvidea graphis card or if u have intel then log on to intel to update the driver ....this will surelyu resolve the issue and u can now watch,record,,etcin ur media center and can view the recorded video in vlc player too.........if the issue is not resolved then mail me at [email protected]
