SOURCE: CHANGE LANGUAGE ON TELEFUNKEN 7j TABLET
THE best way to fix your problem is go to the shop when you buy you'r tablet. and kindly ask the assistant to help or go to this website...http://www.urlidea.com/www/telefunken.com.html
SOURCE: just bought a disgo 8000 android tablet but it freezes every time I try to use the gallery
Hi there, We are
sorry to hear that the device is freezing and not working as expected. Please
try the following which may help to resolve the issue. Thanks,
mydisgo.com
1) Ensure that the Video/Image files you are trying to view are compatible with
the tablet. Compatible files are located on the packaging and in the User
Manual. You can also locate this information on the website, mydisgo.com
2) If you have not already done so, we would advise that you update the device
to version 2.3. The update procedure can be found at the following page; tinyurl.com/8000update
3) If the Gallery app only freezes when accessing files on the SD card (and
not internal memory), please try using the alternative memory card slot or test
using a different memory card.
I do hope this helps to resolve the issue.
If you require any further assistance, please do not hesitate to contact us at
mydisgo.com/support
SOURCE: i need to reboot my mid android 2.2
push on power + home button on the other side and until it reboots the device.
SOURCE: Onda v711
You need to perform a
hard reset on your Onda V711. Here`s how:
You can perform a hard reset by booting into a special recovery mode.
First, ensure your device is fully shut down. When the tablet is turned off, keep home button pressed.
Now turn on tablet while still holding the home button.
When white android figure appears, release both buttons.
You will get into recovery mode, you can select "restore factory settings" there.
If that fails, try flashing new firmware.
