Question about ASUS (M2NGREEN) Motherboard
No display I bought an asus m2ngreen board and checked all the connections and checked a geforce and an ati video card but i still get no display. What is the solution?
    Problem Solver:
  • 6 Answers
Can you get any video when booting to safe mode
(aka VGA mode) If so Have you installed the latest drivers from ATI and Nvidia for those specific video cards? Is there an on-board video card for this MB??? that could have conflicting IRQ's when installing the new cards? if so I would disable the on board in the bios. also what kind of card is it.. PCI, PCI express, AGP... You may want to lokk in the bios to make sure that port is enabled for display on boot and that it is set correctly for your type of card interface. Also .. LOL this monitor works right? I need more details from you, this should be fairly easy to resolve tho. Can you see it POST? then when it loads Windows/Linux.. whatever os you are useing the monitor goes black?if thats the case the vidoe resolution is set too high for the current monitor and you will need to boot to safe mode to resolve it. Or it could be a Hardware "ghosting" issue where the card is not displayed in device manager but the system still thinks its there.. so when you remove the card to try to reinstall nothing changes.
Provide more details so I can troubleshoot this better..
Posted on Nov 26, 2007
I have a new geforce 6200 evga hd card and have installed it in a PCI slot after first having disabled my ASUS integrated ATI 3300 video through the device manager before powering down and installing the...
I am presuming that the mainboard is an Asus model with integrated VGA.
In order to perform the following steps you may have to remove your new VGA board and reconnect your monitor to the mainboard VGA in order to have a display on your monitor.
If your new VGA board is an AGP or PCI express, connecting your monitor to the new VGA board should have been detected and applied the VGA output through the new board. If the new VGA board is a PCI type then go to the new steps to make changes to your CMOS via the BIOS settings.
If not the Asus mainboard may have to have the CMOS setup change through your BIOS settings.
Upon bootup you should be able to hit the delte key and the BIOS screen should come one.
Scroll down to the a view that will show "Onboard Settings" or similar wording.
Select and disable the Asus onboard VGA or video.
If problem still persist, then go to the Assus.Com web site for support on your model Asus mainboard for the maunual, or trouble shooting questions on settings.
Good Luck
Jul 02, 2011 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
Need list of compatible Graphics Cards for my ASUS p5s800vm Mother Board. Has to be 8x 1.5v Thank you!
Following graphics will work for you.
ATI Raedon series video cards
NVIDIA geforce series cards.
Nov 02, 2010 | ASUS P5S800-VM Motherboard
I have a Dell Vostro 400 and two video cards. Only one card will work and it is an Nvidia GeForce FX 5200.The other one is an ATI Radeon HD 2400 PRO. These are the specs from the two graphics cards:...
you cant join two different platform vga cards. simply because they have their own platform and have separate drivers, so they conflict each other thus causing one of them shut off or disable..
Jun 01, 2010 | XFX NVIDIA GeForce FX5200 Graphic Card
Conflict between geforce nvidia 7200 with MOBO asus p5pl2
i think you mean you don't see any post readings
you can go into bios setup
and set page to default settings then press f10 to save and exit
let me know if this helped
Dec 13, 2008 | ASUS P5PL2 Motherboard
With ASUS M2N-MX mainboard, ATI Radeon 7000 Series problem.
Your Motherboard has an onboard video chipset made by Nvidia. Nvidia and ATI have a history of not playing nice with each other.
I have 2 possible solutions for you.
1.) Remove the Radeon card and use the Nvidia onboard card (Essentially a Geforce 6100)
2.) Enter the bios (Usually done by hitting <Delete> or <F12> while the computer is booting up) Your Motherboards manual can tell you for certain. Then find the options for onboard video and disable it.
Then boot up the PC, When it say starting Windows press <F8> to bring up the windows boot menu. Select "Start in Safe mode" Once this loads up open the device manager, look under "Display adapters" find the entry for the Nvidia adapter, right click on it and select either "Uninstall" or "Disable this device"
Which you choose depends on your personal preference Whether you like Nvidia or ATI boards better.
If it makes your decision easier a Geforce 6100 is roughly equivalent to a Radeon 8500 in performance.
I hope this helps
Nov 11, 2008 | ASUS M2N-MX Motherboard
Program won't run, error message says it can't find 3d software.
If the error message says "Cannot find any compatible Direct 3D devices" it means that you do not have a supported video on your system, and that you need to upgrade your video card.
The Recommended and Minimum System Requirements for the are game mentioned below your system has to meet at least the Minimum System Requirements for the game to launch on your system.
Recommended System Requirements:
- 3 GHz Intel Pentium 4 or equivalent processor
- 1GB System Ram
- ATI Radeon X800 series, NVIDIA GeForce 6800 series or higher video card
1.2. Minimum System Requirements
Minimum System Requirements:
- Windows XP
- 512MB System RAM
- 2 GHz Intel Pentium 4 or equivalent processor
- 128MB Direct3D compatible video card with DirectX 9.0c compatible driver
- CD-ROM or DVD-ROM drive
- 4.6GB free hard disk space
- DirectX 9.0c (included)
- DirectX 8.1 compatible sound card
- Microsoft .NET 2.0 Framework for toolset (included)
- Broadband connection for multiplayer online play
- Keyboard, Mouse
1.3. Supported Video Cards
- ATI Radeon X1900 series
- ATI Radeon X1800 series
- ATI Radeon X1600 series
- ATI Radeon X1300 series
- ATI Radeon X850 series
- ATI Radeon X700 series
- ATI Radeon X600 series
- ATI Radeon X300 series
- ATI Radeon 9800 series
- ATI Radeon 9600 series
- ATI Radeon 9500 series
- NVIDIA GeForce 7900 series
- NVIDIA GeForce 7800 series
- NVIDIA GeForce 7600 series
- NVIDIA GeForce 7300 series
- NVIDIA GeForce 6800 series
- NVIDIA GeForce 6600 series
- NVIDIA GeForce 6500 series
- NVIDIA GeForce 6200 series
- NVIDIA GeForce 6100 series
- NVIDIA GeForce FX 5900 series
- NVIDIA GeForce FX 5700 series
- NVIDIA GeForce FX 5600 series
- NVIDIA GeForce FX 5500 series
Oct 28, 2008 | Video Game Consoles & Games
Graphics card problem
Hi rovin,
So you bought an XFX GeForce 256MB video card. You're board has 1 free AGP 8x video slot & 3 PCI (White opened slots).
You mention there is not slot for the new card. (What type of video card did you buy)? PCI-E, AGP or PCI?
The only slot you're board does not have is a PCI-Express.
Look in you're manual on page 1-7 for the location of the AGP video card slot.
94565e6.jpg If you bought the wrong card, exchange it for an AGP 8x or PCI.
The ASUS P5PE-VM uses a integrated Intel® 865G chipset with integrated Intel® Extreme Graphics 2 Technology, which uses you're system memory to function.
If you need a manual you can download it from Asus. Click on the link to open to the P5PE-VM download site.
I hope you find this helpful.
May 11, 2008 | ASUS P5PE-VM Motherboard
Graphic Card Support
From asus web you can get the required information.
To download the manual for your board click on the following link.
Click to download manual.
Mar 16, 2008 | ASUS P5VDC-MX Motherboard
I suggest XFX GeForce 8500 GT 512MB DDR2 PCI Express video card. No need for an upgrade & it has a lifetime warranty. The price is great! Your Asus P5VDC will run it. Here is the link:
Please vote........
Jan 14, 2008 | ASUS P5VDC-MX (P5VDCMXGREEN) Motherboard
Your video is integrated into the board. First check that the problem is not your monitor by hooking up another. Borrowing one if possible. Double check the video cable is connected securely at both ends, monitor & at the board. Your board does not support APG but you do have a PCIE slot. As a last choice you'll have to try a PCIE video card. If you finally do get video with a PCIE you'll need to enter your bios and change the video settings to PCIE. Your board is warranted for three years. You can call Asus IL eastern time US at. 1-812-282-2787, listen to the automated options this will connect you with tech support. Write down the boards S/N typed on a white sticker on the serial port. Tech will want this.
These things happen, hang in there!
Please vote...
Nov 26, 2007 | ASUS (M2NGREEN) Motherboard
ASUS (M2NGREEN) Motherboard Logo
48 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
