SOURCE: How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Testimonial: "Thanks for the link. Unfortunately, I was not able to locate anything regarding my problem because I could not figure out the search feature. Thank you for your help."
Ok, there is a tube running from the fill switch to the tub, as water fills the tub the air in this tube will activate the switch. If there is a hole in this tube the switch will not stop the water. I fill the tub about 1/4 full, take the tube off the switch and blow through the tube, If you hear air escaping patch the hole or replace the tube.
