Question about Saws
KS850 circular saw 'burning' & smoking
Loud rattling/grinding noise from within, smoke and smell of electrical burning.
  • 1,498 Answers
Hi DMilla,
The saw is in need of an extreme makeover. It needs brushes and bearings.
To be honest, it's a toss up between the cost of replacement and the time it would take to revamp it.
Don't continue to use it as is though. It could catch fire, short out, internal components could melt through the casing, etc.
Mike
Posted on Aug 01, 2009
    President:
  • 1,124 Answers
The brushes in the electric motor have failed..
And sounds like bearing are shot too..
The motor is shot..
Note;
Thank you for posting your question on FixYa.com
We are helping people on a points system.
If the information provided here was at all helpful,
please be kind - rate well and close the post.
Thank you – and enjoy your day ;o)
Where will i get new carbon brushes for black and decker KS850 as can,t find anyonr who sells them
Posted on May 15, 2010
  • 305 Answers
Sounds like the carbon brushes have broken up inside the motor.....but they can be replaced
Why does a front loading lg washer smoking in spin cycle
Lg washer smoking - YouTube
? 1:06
https://www.youtube.com/watch?v=vKeIDM78CFI
Mar 29, 2013 - Uploaded by mrsbarney04
Lg washer smoking ... LG Front-Load Washer Disassembly -Washing Machine Repair Help ... Lg Washer model #WM2016CW PARTING OUT! ... Roblox: Chaos Washers -SPINNING IN A GIANT WASHER WITH FANS!
GE Washer Diagnostic - Loud Noise and Smoking ...
? 2:33
https://www.youtube.com/watch?v=a-ONJ2_RQvk
Jul 7, 2013 - Uploaded by ApplianceVideo.com
Service your trusty GE Washer that has these following dilemmas: Loud Noise ... L-G. Samsung Kenmore ,LG, Whirlpool, Electrolux Speed Queen, Amana ... Front Load Washer Repair - Bearing and Seal Failure Mode - Duration: 14:44. ... WasherDiagnostic - Very noisy during spin -GE, General Electric, ...
LG WM1815CS Front Load Washer Smoke burning smell ...
Jan 25, 2016 | LG Washing Machines
On my 2001 jeep grand cherokee larado. when I put it in four wheel drive it make a loud rumbling noise also after driving it in four wheel drive & stop you smell something like burning oil or fluid...
need to look under at the drive train and check the c/v joints the transaxle case seals etc noise can be anything from bearings to gear or seals failing
Oct 18, 2017 | Cars & Trucks
2004 Chrysler Voyager, had an acrid burning smell and a lot of smoke when heater is turned on, also a rattling/squealing noise, all stops when heater turned off?
you more than likely have a sciezed air con compressor. most modern cars have climate control which uses air con even when demisting and when engaged the electric clutch tries to engage but the pump itself will not turn, clutch will get red hot and burn your belts
Nov 25, 2013 | 2004 Chrysler Voyager
Loud noise burning smell
Most likely a belt problem or a worn out tensioner. You left off the year, make, model and engine so it's a guessing gamet. Read this post on how to track down the source of noise
http://ricksfreeautorepairadvice.com/diagnose-squeak-noise-creaks-and-squeals/
Diagnose squeaks creaks and squeals
Oct 05, 2017 | Cars & Trucks
Uncontrolled downshift of 1994 c220
no 4-3 or 3-2 downshift
uncontrolled downshifts outside range of kickdown switch
poor acceleration from stopped position
parking pawl will not engage
selector lever does not engage in r or p
engine will not start in p or n position
smoke in exhaust (fluid loss)
fluid loss between torque converter & primary pump
howling noise when changing gears (under full load)
howling noise which increases as engine rpm increases
1st gear & reverse too loud
3rd gear too loud
rattling noise at 1500 rpm in all positions except r
light grinding noise in p & n positions
rolling noises when driving in reverse
vacuum control circuit
Vacuum Control Valve (E300D & S350D)
Vacuum Amplifier (E300D & S350D)
Dec 02, 2012 | 1994 Mercedes-Benz C-Class
Heater and aircon not working,loud rattling noise and smoke from vent,now not power to fan
It appears your fan itself burned out. When a field coil of an electrical fan burns out it usually makes a lot of smoke. The noise could be something that fell in there that stopped the fan from turning freely. I can imagine it heated up under the strain and burned out.
When you restarted it was burnt out so hence no noise and no fan.
The smell of the smoke should also be clue. Electrical field coils burning has an awful soury type of smell.
Aug 13, 2012 | Peugeot Partner Cars & Trucks
Makes a loud noise like a grinding noise then smokes comes out and it smells like burning rubber? When I take the (rod) brush off with the belt then run the vacuum there is no more noise? Please help me...
Your belt is worn and stretched and so it is slipping on the motor drive shaft. That is why it is noisy and smells like burning rubber. You simply need to replace the belt. You can get replacement belts here:
Replacement Vacuum Belts
Nov 30, 2009 | Vacuums
Saws Logo
761 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
