Question about Ricoh Office Equipment & Supplies
A ricoh 1045 sc990 code says about Hard Drive problem. Where is this located? also please tell me what is and where is located a developer? Thanks in advance.
  • Ricoh Master
  • 1,294 Answers
SC 990 is a software performance error.The software attemted to perform an unexpected operation.Software defective,internal parameter inncorrect or insufucient working memory.SC 990 occues when printing a message dtored in the information box.Avoid by firmware upgrade.This information can be cheked by using SP 7-403.The hard unit is located in rear right side up position of by pass.The developer is under toner botle in developer unit.
Posted on Aug 01, 2009
How to fix 990 erro code without changing a drum ?
what model is it. that sounds like more of a hard drive issue than a drum issue.
Nov 22, 2014 | Ricoh 888073 Genuine Aficio 1035/1045 Type...
Update firmware for MP 1600
SC990 means that the hard drive has failed..... It needs to be replaced with a new one or a hard drive from another copier of the same model. Or you can disconnect the finisher.
Jan 12, 2014 | Ricoh Aficio MP 1600 Black and White...
I have problem in Ricoh AF 2045 SC 990 pl z help me out from it
this is software performance error.but this in most cases will appear on life over of either drum or developer.
Jul 26, 2011 | Ricoh Aficio 2035 Copier
Hello I'm in Brazil can not resolve error in my SC990 Ricoh Aficio 2045eSP. This error pops up after 10 copies or printing. Already exchanged cylinder, blade, developer and toner new. Please help me.
Why change the drum, blade, developer ????? You had problems with print quality?? I think it was just spending money ....
You have a network problem or machine firmware. To remove the doubts plug a laptop directly to the machine with a cable (Not necessary a croos cable). This may be a virus network or a broken swith.
Good luck
Feb 11, 2011 | Ricoh Aficio 450 Copier
Sc990
sc990 is the software problem. replace the HDD of the machine and it should be fine. don't format the hard drive as it might result in laser error code.
Oct 22, 2010 | Ricoh Aficio 1035 Copier
I have A problem of SC990 in the ricoh aficio 2035/45 and also I get light copies and over tonning problem.
The light copies and overtoning is probably caused by the developer going bad. Do you have a service contract on your copier? It's likely time for a whole PM (preventive maintenance) procedure.
The sc990 is probably caused by the copier's condition as well. Once you have the PM done (or at least replace the developer, rebuild the photoconductor unit, and clean or rebuild the transfer unit) the sc990 codes should go away along with the poor copy quality.
Jun 19, 2010 | Ricoh Aficio 1035 Copier
What is the cause of error sc990 in 2054 copier and what is the remedy
SC990: Communication error between BICU and IOCSS board
This board will need to be replaced as a remedy and frankly to tell you the truth and nothing but the truthh so help me God you going to be neck deep into a repair bill.
I would do what i got to do here or pull out of that situation most people purchase repair contracts to help them foot the cost.
sorry to break it to you but facts are facts and they need to be stated up front.
for my FREE info today can you leave a rating and some feedback on how well i serviced your free question today?
thanks
Apr 28, 2010 | Ricoh Aficio 450 Copier
My home Aficio 2035 often displays sc 990. Please help solve
Generally changing the cylinder (blade and developer) and adjust normaly TD sensor and ID sensor, usually it is solved. If it is not thus it proves the following thing: press point and numeral (enter) simultaneously for more than 10 seconds until this is extinguished clarifies the service call. If the problem persists can be the hard disk, change.
Aug 27, 2009 | Ricoh Aficio 450 Copier
Ricoh 1045 sc990
Generally changing the cylinder (blade and developer) Initialize td and id sensor usually it is solved. If it is not thus it proves the following thing: press point and numeral (enter) simultaneously for more than 10 seconds until this clear the service call. If the problem persists can be the hard disk, change.
Jul 31, 2009 | Ricoh Aficio 1035 Copier
Service code SC546 on a Ricoh Aficio 1045
Try to go into service mode to reset the code...
Clear yellow botton
7
then press and hold the red stop botton till the display changes and then turn the main Power switch Off then back ON... You do not have to do any thing in service mode, just get to that display.... Don't change anything unless you know what you are doing. sc546 has to do with the fixing unit. You may be able to reset it.
Jun 03, 2008 | Computers & Internet
360 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
