Question about Karcher 2500 PSI Pressure Washer
Borrowing this washer will not **** up the cleaner
Wondering how to get it to syphon the cleaner. Is there a putton or nob?? Can't see one. or what is the secret?
On some models make sure u twist the filter to the max
Posted on Aug 07, 2009
  • 1,498 Answers
It should have come with several different nozzles. The siphon will only work with the low pressure one. It is usually black, and will have a larger opening compared with the others. Use this one to apply whatever you are siphoning, then switch back to one of the others to rinse.
Hope this helps.
Mike
Posted on Aug 01, 2009
Diagram of a craftsman power washer
The only filter on the detergent pickup is usually at the end of the hose you drop into the detergent. To clean the line and syphon attachment only requires a little pressurized air to blow out any debris that may be in the line. Make sure you are using the black, soap tip on the pressure gun when trying to use the detergent syphon system. If you are using any of the high pressure tips there will be too much back pressure in the line for the syphon to work.
Aug 30, 2012 | Craftsman 2500 PSI Briggs & Stratton...
Cleaner will not syphon from bottle
Siphon only works on low pressure. Put low pressure tip on wand to get it working right.All other tips will not allow fluids to flow out fast enough to build siphon pressure / draw.
Nov 17, 2010 | Karcher G2650HHR Gas Pressure Washer
LSR8233JQ0Washer won't fill
The water is syphoning out the drain hose.
Many times when the stand pipe is backing up someone will seal the washer drain hose to the pipe to avoid overflow of the stand pipe.
This causes the water to syphon from the washer.
Or the opening for the stand pipe is just big enough to put the drain hose in and is to tight causing the syphon.
Putting the drain hose to far down the pipe can cause a syphon also.
Jan 20, 2010 | Washing Machines
The washer drains its self will filing up on the rinse cigle
Suspect water syphoning out , raise drain hose , pull out of standpipe a little and fit ant-syphon device if that is problem
Nov 09, 2009 | Washing Machines
Water continuously runs and cycle won't start. The washer tub doesn't seem to be filling with any water.
Probably a syphon problem . Check your drain hose to make sure hose is not stuffed too far down drain and air can get between the hose and the drain pipe . If you have tapped the hose to the drain to keep water from comming out the drain pipe , go to home depot or an appliance parts house , and get a syphon break . When a washer fills , but water level doesn't rise in the machine , it's being sucked out by syphoning thru your sewer pipe .
Aug 08, 2009 | GE WVSR1060A Top Load Washer
How do i fix my bendix washer
hi! you need to un clip orpull the draw out (easy enough!) then give it a good clean, there will be a little tube in the draw that will be gunged up! a pipe cleaner or ear bud wil clean it through, with lots of hot water!
Dec 20, 2008 | Tricity Bendix AW1400W Front Load Washer
LF code on fill. Seems like water is pumping out as fast as it comes in. What do I replace?
I'm not sure if this will help or not. Check the drain hose. Make sure that at part of the drain hose loops above the the machine. There is always a possiblility when the hose is not high enough it will start to syphon the water out.
Dec 05, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Frigidaire Gallery washer is flooding the house
Try turning water faucets off. Does it still flood when done? Does your drain hose empty into stand pipe that is at least 30 inches from floor? Make sure drain hose does not go anymore than a few inches into pipe. If it is pushed too far in, unit can syphon water back into unit.
Nov 22, 2007 | Washing Machines
Pressure switch on stack washer
usually the pressure switch is next to the timer or in front.
Oct 09, 2007 | Frigidaire GLEH1642DS Front Load Stacked...
Karcher 2500 PSI Pressure Washer Logo
205 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
