Question about Maytag MLE2000 Front Load Stacked Washer / Dryer
The washer starts. After the tumbler runs for a minute it stops.
This is an MLE2000 AZW S/N 51078407AE
  • 1 more comment
  • dan_manor Aug 01, 2009
    By tumbler I mean the entire drum which rotates in the washer.
    The problem happens in all cycles, in wash, rinse and in spin. When it happens, the LED above START turns off.
    The "door locked" light is above it is OFF during the wash and rinse cycles and ON in the spin cycle. It remains ON even when the washer stops.
    The washer has a newly replaced Timer. Clogged drain pipe should not affect it during wash cycle in which the pump is shut.
    Dan Manor
    Benjamin,
    Did you receive the clarifications I sent you? I had a problem with starting the chat as the website did not give me a place to clarify. I sent a complaint via email to fixya but they said they will answer in 48 hours.
    Dan
    Answer provided was not based upon additional information, which I had difficulty posting. I posted it later.
    The washer has a replaced new Timer. The problem occurs in ALL cycles, wash, rinse and spin.
  • Maytag Master
  • 19,396 Answers
Hi there ,
Unfortunately you wrote the problem in the title box, and we are unable to read it .
In the meanwhile here all parts and diagrams for your model.
I will be grateful if you can describe the problem again, so that we can help.
Many thanks.
G.
Posted on Aug 01, 2009
  • 3,037 Answers
Most likely a drain clog, or a bad timer will cause this without more info as to if this happens on all cycles and whether this is the spin or the wash cycle. Thanks
Benjamin
My Maytag Neptune FAV6800AW top load washer only runs for the first few minutes of the cycle, it will not spin..it just stops..we've tried two cycles, the quick wash...it starts at 33 mins and then stops...
I'm and owner and will try to help. Are you handy and do you want to try a DIY fix?
From the wash times is sounds like the washer is agitating the wash load (tumblers are rotating the wash basket load) is that correct?
If so see if the machine will complete a Spin Only cycle with no clothes in the wash basket. Set the Spin setting to Spin/Hang dry seting and start the cycle. It should take about 10 min complete. Does the Spin Only cycle complete with no clothes in the wash basket?
Some handy links if you are going to DIY.........Service Manual for reference.
Sep 17, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Door lock suddenly does not function when depressing the start/stop button on my Neptune Super Stack SL3 washer-dryer. The locked light is on however. The result is that the washer will not spin or drain.
If you take off the face plate where the knobs are at or if you know how to get to the wax motor you'll find a red solid cable and if you pull this cable it will release the mechanism which is keeping the wax motor engaged
Jun 30, 2010 | Maytag MLE2000 Front Load Stacked Washer /...
My washer will not turn on, my dryer will spin but not heat
Is this a new installation, or has it been running fine and now acting up?
Apr 17, 2010 | Maytag MLE2000 Front Load Stacked Washer /...
My MLE2000 washer will start to spin and then
more likely an itntermitent lid switch problem as the washer strats it's spin cycle the motion is causuning the lid switch to open making the washer think some one has opened the lid and it shuts down to be safe check the switch make sure it hasn't come loose and check the actuator on the lid sometimes a plastic piece near the front of the lid that goes into sort of a key hole Good Luck
Oct 16, 2009 | Maytag MLE2000 Front Load Stacked Washer /...
Dryer turns but doesn't heat. How do I troubleshoot?
Likely causes are:
- broken heating element
- burned/corroded connections in heating circuit
- blown thermal fuse / limit switch
- bad thermostat
If you don't have significant of experience with electrical appliance troubleshooting & reapir, this is a difficult task.
May 08, 2009 | Maytag MLE2000 Front Load Stacked Washer /...
Will not spin, therefore will not drain
Hey Joe,
Let’s check to see if the wash basket will rotate CCW in Spin Only Cycle with no clothes in the wash basket
1. Open the lid and rotate the wash basket by hand Counter Clockwise, CCW. The wash basket should rotate freely with no restriction. The wash basket will not rotate Clockwise, CW by hand.
2. Raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. Raise the top of the machine to observe the wash basket and tumbler action described in step 3. (See page 33 of the Service Manual for putty knife insertion point).
3. With the top raised start a Spin Only cycle with no clothes in the wash basket, observe the wash basket it should begin to rotate CCW does it?. Watch the tumblers, they should not rotate in spin cycle (maybe ½ turn at the start of spin cycle and that’s all). If the tumblers rotate while the wash basket is rotating you have a clutch malfunction. If the basket does spin CCW and the tumblers are rotating then you have a broken clutch spring. Let do those checks and observations and see what the next troubleshooting steps will be. Rich
Apr 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
MLE2000 front load washer
Hi..I had the same problem yesterday...the maching would start when I pushed the button and then stop..I had to push the button again to get it going..My stacked set is around 8 years old.
Here's what we did..moved the washer away from the water source and unscrewed the water intake lines..there is a little screen there...took the screen out of both hot and cold lines..one screen has some debris in it..the other was almost completely blocked..we are on a well and sometimes dirt..etc..gets in the lines..
Today no problems doing the laundry..its working like new..
Oct 26, 2008 | Maytag MLE2000 Front Load Stacked Washer /...
Leak
is it leaking from inlet side of water hose when not running pressure builds up check connects
Sep 03, 2008 | Maytag MLE2000 Front Load Stacked Washer /...
Dryer runs for 5 minutes then stops
look in the vent line for a small disk shaped overload with two wires coming out of it. it may be bad. also check for a lint build-up in the exhaust line out of the blower. check the damper outlet going out of the house for a build-up of lint.
Aug 21, 2007 | Roper REX3614KW Electric Dryer
Maytag MLE2000 Front Load Stacked Washer / Dryer Logo
50 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
